Fuji X-H2 resolution?
Started 1 month ago | Discussions
sw88 Forum Member • Posts: 56
Re: Fuji X-H2 resolution?
There's absolutely no difference in IQ for fuji sensors for a decade. My XE-1, XT-2 and XH-2 gives the same image quality when pixel peeping. The only improvement is dynamic range. So dont worry so much.
sprouty115
sprouty115 Contributing Member • Posts: 618
Re: Poor Test Samples?
DJF55 wrote:
ETTR by 2/3 to ! EV: is that -or + exposure compensation?
Watch the histogram as you turn the EV dial, all will be revealed...
 sprouty115's gear list:sprouty115's gear list
Ricoh GR III
JNR
JNR Veteran Member • Posts: 4,652
Re: Thanks for the replies
Erik Baumgartner wrote:
There are lots of bad examples, and good examples with bad processing out there. A 40MP sensor is going to be more reliant on good lenses, and shooting/post processing technique for an optimal result, but will never be softer than a 26MP sensor with the same lenses. A lot of people are processing with the same sharpening/NR settings as with their old sensors which can significantly limit the rendering fine detail. While diffraction can be resolution limiting factor, it will never produce a worse result than with 26MP, it will only limit how much better it can be.
Exactly correct.
Another way to understand diffraction is if you had a perfectly sharp lens (with no aberrations) and an infinitely dense sensor then the only limiting factor would be diffraction which would only further decrease sharpness upon stopping down (the perfectly round aperture). In other words, diffraction exists no matter the aperture (because the aperture is the only source of the diffraction in an otherwise perfect lens).
That's why a really good relatively fast crop sensor prime lens can peak overall at f/4 or even wider and show diffraction sharpness loss already by f/5.6. A more typical crop lens often peaks at f/5.6 simply because it just isn't quite as sharp at f/4.
JNR
 JNR's gear list:JNR's gear list
Fujifilm X-T2 Fujifilm 50mm F2 R WR Phase One Capture One Pro Pentax K-01 Pentax K-3 +22 more
sprouty115
Re: FYI The OP has Opted for the A7IV
BobsYourUncle wrote:
Ya win some, ya lose some!
I'll be the first to say it...that is one ugly camera...
Ricoh GR III
baobob
baobob Forum Pro • Posts: 18,248
It is +  In RAW it is easy  to get highlights id they are a bit to brilliant but on the contrary in underexposed photo pushing shadows create noise.
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
pidera Senior Member • Posts: 1,033
I'm sorry the image can be good enough for the intended use but for me the per pixel sharpness is just not there. The lens can be an issue, or the X-trans smearing or the processing starting from the RAW file (in camera or not). A good test would be if you shoot an image in both the large (40 MP) and the medium format (20 MP) and upres the 20 MP image to the same size as the 40 MP image and compare them. Or else downres the 40 MP image to 20 MP and compare those. Kr, P.
 pidera's gear list:pidera's gear list
Nikon D800E Fujifilm X-E1 Fujifilm X-Pro2 Nikon AF-S Nikkor 14-24mm f/2.8G ED Tamron SP 70-300mm F4-5.6 Di VC USD +10 more
craigwell47 Senior Member • Posts: 1,197
New sensor technology making a difference but trade-offs. EXAMPLE: CANON R3 with 24mp stacked sensor advantages for sports photographers; not as sharp as CANON R5 with 45mp sensor in some situations. FUJI APS-C cameras with 40mp sensor but not on Fuji XH-2S proves something. Such minor image quality changes just to increase prices.
DJF55 Regular Member • Posts: 402
Oh, I didn't know that turning the EV dial has an influence on the histogram And you do not answer my question, do you?
DJF
Thx Bob, I saw the same initial comment in another thread, and there you had added the +
DJF
baobob
For more details and infos Google ETTR
sprouty115
Apologies, yes, it does. So let me be more specific:
- set your camera to automatic.
- Make sure the display (LCD) is set to show the histogram.
- Point camera at a scene and turn the EV dial
- The histogram will shift according to the direction you turn the dial
+ moves it to the right...
- moves it to the left...
Ricoh GR III
sprouty115 wrote:
DJF55 wrote:
sprouty115 wrote:
DJF55 wrote:
ETTR by 2/377 to ! EV: is that -or + exposure compensation?
Guys, I perfectly well know what ETTR is, since many years, and how to set the camera to show it, including the RGB histogram, or not. And I hardly ever use the cameras in automatic, but in A priority and manual ISO. So no need to use the EC dial. But I was not sure about the term "ETTR 2/3 to 1 EV". As I answered Bob, I now know that it means 2/3 to 1 EV overexposure. I am all good.
DJF
sprouty115
DJF55 wrote:
Oh, I didn't know that turning the EV dial has an influence on the histogram...
Guys, I perfectly well know what ETTR is, since many years, and how to set the camera to show it, including the RGB histogram, or not...
My work is done...
Ricoh GR III
Dylan10
OP Dylan10 Regular Member • Posts: 200
Ya win some, ya lose some! 😁
Just to clarify Bob, I did already have the A7IV and A1 when I dropped by the Fuji store in London. I had the A7IV with me and the new 20-70 but was curious to see the X-H2/X-T5, as I could still have been persuaded at that point, to have a different second body to the A1.
After reviewing the A7IV image files I am indeed very happy with A7IV image quality and although I'm not sold on the 20-70 f4 I don't consider the Fuji aps-c as a viable option for me anymore.
Thanks again for everyone's input.
 Dylan10's gear list:Dylan10's gear list
Sony a1 Samyang AF 50mm F1.4 FE Sony FE 24-105mm F4 Samyang AF 18mm F2.8 FE Tamron 70-180mm F2.8 Di III VXD +5 more
Dylan10
What a peculiar comment..............
talking_goose Junior Member • Posts: 25
I know, right - they're definitely not the first to say it
 talking_goose's gear list:talking_goose's gear list
Canon PowerShot A590 IS Fujifilm GFX 100S Fujifilm X-T5 Fujifilm 16-55mm F2.8R LM WR Fujifilm GF 50mm F3.5 +3 more
Dylan10
sprouty115
Ok, before this blows up - it was meant to be a little joke...along the lines of "he didn't pick our team, so (insert insult here)".
Now I realize that type of "poke" may not translate.  No harm intended.
Ricoh GR III
