now what??
Started 1 month ago | Discussions
xpatUSA
xpatUSA Forum Pro • Posts: 23,017
Re: now what??
jbr wrote:
Looks like stuck pixels to me.
Not to me, sorry Joe. See:
https://www.dpreview.com/forums/post/66905366
Look at that big circular black spot with the white ring round it about 9 px diameter. Definitely not a stuck pixel, IMO.
I'm hoping that Ole can take another shot with no lens and the dust-cover in the lens mount removed and post it as a PNG.
Have you looked at the raw data? Joe
How would he do that?
what you got is not what you saw ...
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
wood_gnome
wood_gnome Regular Member • Posts: 200
Re: now what??
xpatUSA wrote:   ...
Can the SD9 take shots with both the dust-cover and the lens removed?
Yes, of course.
 wood_gnome's gear list:wood_gnome's gear list
Sigma DP1x Sigma DP2s Sigma DP2x Sigma SD9 Sigma SD10 +2 more
wood_gnome
Re: now what??
I am sooo curious what causes this effect!
xpatUSA
Re: now what??
wood_gnome wrote:
xpatUSA wrote: ...
Yes, of course.
Thanks, I couldn't remember.
Maybe Ole will try just to be completely sure that it's on the sensor ...
jbr Regular Member • Posts: 404
Re: now what??
ole kekkonen wrote:
jbr wrote:
Looks like stuck pixels to me. Have you looked at the raw data? Joe
specific please?
Just thinking that to get to the bottom of this it would be useful to see what the sensor data looks like before processing into an image by SPP.  A program like DCRAW can extract the raw RGB info as created by the camera.  (I have used it on SD14 x3f files). X3ftools/Kapilinka should be able to do that too.  It may not be the answer but at least you would be able to eliminate the possibility that it is sensor related.  Stuck and dead pixels often occur in sensors and they are mapped out by software.  If they are not they can cause image artifacts especially bad in Bayer demosaicing process.  Not sure what they would look like in Foveon images but some of the spots in your image look suspect. And there appears to be sharpening halos around them. Another good reason to look at the raw data.  If you have a way to post the raw x3f file maybe that would help.  Joe
 jbr's gear list:jbr's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Sigma SD14
Re: now what??
could be but some are a bit strange looking for dust
maybe DCraw, x3ftools, Kapilinka. I assume they can open SD9 raw files
xpatUSA
Re: now what??
Agreed. Some here are thinking that an optical effect is involved because of the circular nature of the items.
A reasonable assumption.
xpatUSA
Re: now what??
jbr wrote:
ole kekkonen wrote:
specific please?
Agreed that permanently bad pixels can show up in DCraw and other raw converters but not in the proprietary converter. The X3F metadata has a bad pixels list for just that.
The Merrill top layer is particularly prone to bad (over-sensitive, not stuck) pixels that can make a dark sky look like starry night when viewing only that layer in RawDigger. I posted an example long ago here.
That would really help us, I reckon ...
xpatUSA
Re: now what??
maybe DCraw, x3ftools, [Kalpanika]. I assume they can open SD9 raw files.
Looks like Ole is otherwise occupied.
ole kekkonen
OP ole kekkonen Contributing Member • Posts: 607
Re: now what??
sorry I missed this but I dont think it will work on Macintosh
xpatUSA
Re: now what??
DCraw is available for Mac:
https://www.startpage.com/do/dsearch?query=dcraw+macintosh&cat=web&pl=ext-ff&language=english&extVersion=1.3.0
https://en.freedownloadmanager.org/Mac-OS/dcRAW-X.html
RawDigger is available but not free:
https://www.rawdigger.com/download
ole kekkonen
Re: now what??
Thanks!
