Impressed with RF 100-400. Am I the only one?
Started 4 weeks ago | Discussions
Seb P
Seb P New Member • Posts: 21
Re: Impressed with RF 100-400. Am I the only one?
Ember88 wrote:
I’m constantly impressed with the RF 100-400 for its weight advantage over the RF 100-500 L and the quality I can get.
Aside from the aperture differences and the weather-sealing, what else am I sacrificing by not using the RF 100-500 L? Has anyone done tests to compare the two on IQ? The RF 100-400 seems pretty good for a consumer lens.
Thanks!
I’m also impressed.
I wonder: are you satisfied also when you use it with x1.4TC ?
thx
 Seb P's gear list:Seb P's gear list
Canon PowerShot S120 Canon EOS R10 Canon RF 100-400mm F5.6-8 IS USM Canon RF 24mm F1.8 Macro IS STM
Seb P
Bramble9 wrote:
I'm a big fan of the RF 100-400 too-- and I've also got the 100-500L and RF 600mm f11. They all fill a niche, but the 100-400 easiest to use and most versatile because of its friendly size and weight.
Bramble9
Hello Bramble9. You use the RF600 f11 with your R7 or R5 ? Do you think RF600 f11 is better than RF100-400 with x1.4TC ?
thx
Bramble9 Regular Member • Posts: 211
Assuming both are used on a tripod I can't see much optical quality difference unless I look at more than 100% or greater magnification, and then yeah, the 600 f11 is very slightly better.  I don't pay much attention to corners though.  Also, I only use the 600 on tripod but often use the 100-400, with or without the 1.4xTc, while hobbling around.  The 100-400 is optically a very good lens.
Bramble9
 Bramble9's gear list:Bramble9's gear list
Canon EOS R5 Canon EOS R7 Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 14-35mm F4L IS USM +1 more
L a r s New Member • Posts: 24
The RF 100-400mm lens is awesome for landscapes, too. I use it all the time.
 L a r s's gear list:L a r s's gear list
Canon EOS R5 Canon TS-E 17mm f/4L Canon RF 24-240mm F4-6.3 Canon RF 85mm F1.2L USM Canon EF 135mm F2L USM +8 more
Wildlife Guy
Wildlife Guy Senior Member • Posts: 1,956
I have the RF 100-500 and bought the RF 100-400 as a backup for big wildlife trips.  The 100-500 is definitely better than the Rf 100-400,, but most people wouldn't notice at normal viewing distance.  Very sharp lens for the price and the weight is awesome.  I do find I need to up the contrast and sharpening a bit to come closer tothe 100-500, but overall worth the money.  I wouldn't hesitate to shoot the 100-400 if I didn't have the 100-500 available.  My main reason for the 100-500 is the sealing and rugged lens construction.  The 100-400 is great as a walk around for casual trips when you want to cut weight.  This is a hobby, but I mainly shoot outdoors and use the 100-500 because I don't want to worry about a little moisture or dust.
David
 Wildlife Guy's gear list:Wildlife Guy's gear list
Canon EOS R6 Mark II Canon RF 24-105mm F4L IS USM Canon RF 24-105mm F4.0-7.1 IS STM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 85mm F2 Macro IS STM +4 more
JoeSchmoe007 Contributing Member • Posts: 502
No, you are not the only one.
