Impressed with RF 100-400. Am I the only one?
Started 4 weeks ago | Discussions
Ember88 Regular Member • Posts: 120
I’m constantly impressed with the RF 100-400 for its weight advantage over the RF 100-500 L and the quality I can get.
Aside from the aperture differences and the weather-sealing, what else am I sacrificing by not using the RF 100-500 L? Has anyone done tests to compare the two on IQ? The RF 100-400 seems pretty good for a consumer lens.
Thanks!
 Ember88's gear list:Ember88's gear list
Canon EOS R5 Canon Extender EF 1.4x II Canon Extender EF 2x II Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +3 more
BirdShooter7 Veteran Member • Posts: 9,127
Re: Impressed with RF 100-400. Am I the only one?
I’m also impressed
https://www.dpreview.com/forums/post/65597055
Some of my bird photos can be viewed here: https://www.flickr.com/photos/gregsbirds/
davel33 Senior Member • Posts: 2,974
One other advantage for the rf 100-400 is its the only lens other than the GREAT WHITES that work with the RF extenders the 100-500 only works at the long end.
"Just one more Lens, I promise....."
Dave
 davel33's gear list:davel33's gear list
Canon EOS R Canon EOS R6 Canon RF 35mm F1.8 IS STM Macro Canon RF 24-240mm F4-6.3 Canon RF 85mm F2 Macro IS STM +29 more
OP Ember88 Regular Member • Posts: 120
For sure! I can’t believe they didn’t engineer the 100-500 to work along the whole zoom range with the extenders!!! If they can do it on the 100-400, surely they can do it in the 100-500. Wouldn’t you think?
FarmerPhotos Forum Member • Posts: 64
as a beginner hobbyist its great guess if i was a pro might see it different.
 FarmerPhotos's gear list:FarmerPhotos's gear list
Canon EOS R6 Canon EOS R6 Mark II Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 100-400mm F5.6-8 IS USM
Andy01 Veteran Member • Posts: 5,188
Thanks!
I don't have either (I still have EF 100-400L ii), but TDP testing shows that 100-500L appears to be very noticeably better at all focal lengths and apertures - sharper and less aberrations.
https://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=1572&Camera=1508&Sample=0&FLI=4&API=1&LensComp=1510&CameraComp=1508&SampleComp=0&FLIComp=3&APIComp=3
But perhaps in the real world the RF 100-400 would be perfectly adequate for most people in most situations - at a fraction of the price.
 Andy01's gear list:Andy01's gear list
Canon EOS M5 Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM +5 more
Thanks!
I forgot to add this…I’m assuming contrast and sharpness is improved in the 100-500 L, but has anyone compared whether there is a noticeable improvement when viewing images side-by-side? (Not just from charts).
robgendreau Forum Pro • Posts: 10,917
Thanks!
I know from shooting with friends that especially at the long end their 100-500 L is a bit sharper; less diffraction maybe since my shots were at slower apertures. It's expected given the prices. But it's still a terrific lens given the price. In good light it would probably give the 100-500 a run for its money for most uses.
There are some good actual photo comparisons in this video by Dustin Abbott: https://youtu.be/Tc1FFLT09hU Go to about 8:00 to see the conclusion. Spoiler: the 100-400mm is good in the middle, and stopped down some depending on zoom setting. But the 100-500 is better out to the corners, and wider, and across the zoom range.
 robgendreau's gear list:robgendreau's gear list
Pentax 645Z
GraphAD Regular Member • Posts: 133
Thanks!
I have that lens, a Tamron 150-600 G1, a Canon 500mm F4 Gen1, and I mostly use the 100-400, so much lighter and a great image quality.
My friend has the EF 100-400 Gen 2, the RF 100-500 and the RF 100-400, we did many tests in the field and the difference is really minimal, I was going to buy the 100-500 but the price is not worth it to me. Each is own preference. This lens is so much fun to walk around. And the minimal focus distance is also great, even better with a extension adapter. Also great focus speed.
 GraphAD's gear list:GraphAD's gear list
Ricoh Theta S Canon EOS 6D Canon EOS R5 Canon EF 500mm f/4.0L IS USM Canon EF 100mm F2.8L Macro IS USM +11 more
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
8
I love this lens. I'm not a serious wildlife photographer, so I can't justify buying something big, heavy, and expensive in this range. But the RF 100-400 is so small, light, and cheap, that it's pretty much a no-brainer to get it. Here's one I took yesterday, trying it out on my new R6II:
And with the R7:
And with the 1.4X extender on the R7:
It's plenty sharp enough for my purposes. It's also a pretty good outdoor sports lens.
“When I die, I want to go peacefully in my sleep like my grandfather. Not screaming in terror, like the passengers in his car.” Jack Handey
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
Thanks!
A while after I bought my RF 100-400 I bought the 100-500 L and when comparing photos I took of birds/wildlife on my 32” 4K screen I really had a hard time telling what photos came from what lens (I tested using the R5 and) and viewing distance of about 3’.  There might be significant differences in certain situations but for my personal uses, image quality wasn’t really an important differentiator when choosing which lens to keep.
The extra focal length, faster AF, much better build quality and weather resistance are reasons to go with the L.
11
Yesterday.
Steve-P
Steve-P Senior Member • Posts: 1,344
This Australian pro agrees with you.
Crikey what a ripper.
Cheers
Steve
"A camera is a tool for learning to see without a camera."
(Dorothea Lange)
http://www.pbase.com/steve_p/galleries
 Steve-P's gear list:Steve-P's gear list
Canon EOS 90D Canon EF 70-300mm f/4-5.6 IS USM Canon EF-S 18-135mm F3.5-5.6 IS USM Tamron 18-400mm F3.5-6.3
JustUs7 Senior Member • Posts: 4,327
6
One of my favorites.
 JustUs7's gear list:JustUs7's gear list
Canon EOS 1000D Canon EOS Rebel SL1 Canon EOS RP Canon EOS M6 II Canon EF 75-300mm f/4.0-5.6 III +10 more
GraphAD wrote:
Yesterday.
Great shot!
Kokopelli_Rocks
Kokopelli_Rocks Veteran Member • Posts: 3,661
I am sure they could, but probably choose to keep the lens a small as possible. My guess is the lens would be 1-2 inches longer if they supported extenders for the whole range. Personally I wish they had made the choice. I love my 100-500, works great with and without extenders. I also have the RF 100-400 for when I want to go lighter.
I really light the RF 100-400, but the RF 100-500 is easily the best lens I have owned in my 40+ years of photography.
 Kokopelli_Rocks's gear list:Kokopelli_Rocks's gear list
Canon EOS R5 Canon EF 70-200mm F2.8L IS II USM Sigma 14mm F1.8 Art Canon RF 24-105mm F4L IS USM Canon RF 15-35mm F2.8L IS USM +15 more
Bramble9 Regular Member • Posts: 211
I'm a big fan of the RF 100-400 too-- and I've also got the 100-500L and RF 600mm f11.  They all fill a niche, but the 100-400 easiest to use and most versatile because of its friendly size and weight.
Bramble9
 Bramble9's gear list:Bramble9's gear list
Canon EOS R5 Canon EOS R7 Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 14-35mm F4L IS USM +1 more
Ember88 wrote:
GraphAD wrote:
Yesterday.
Great shot!
Thanks!
have to reinterate im a beginner/hobbyist
have r6 and r6ii not into tech side of cameras to much a broad understanding.
rf100/400 seems to be better on r6ii than origanal r6
gut feel looking at photos
Rock and Rollei Senior Member • Posts: 2,902
I think it's great. I own the EF L II lens, and love it - but don't love carrying it just in case. This RF lens, though, can go with me wherever. I use it loads for landscapes and travel when I just can't take the weight of the EF lens. If I'm shooting sport or wildlife, then I would want the 100-500, and use the EF L II, but the fact is that the RF 100-400 gets more use simply because I'm happy to carry it.
 Rock and Rollei's gear list:Rock and Rollei's gear list
Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS R Canon EOS M6 II Canon EF 50mm f/1.2L USM +29 more
