Sharper images using ES with the 10-24mm WR?
Started 2 months ago | Questions
jonikon Veteran Member • Posts: 7,433
I just picked up a new XF 10-24mm f4 WR yesterday and I have been taking a lot of random test shots around my home, (the weather is too cold and nasty for outside testing).  Very impressed with the build quality of the lens so far and based on my indoor shots it appears to be a keeper. However it appears to me that shooting with the electronic shutter produces consistently slightly sharper images than when using the mechanical shutter.
Is this a case of shutter shock affecting the image perhaps? My camera is the X-T2.
Fujifilm X-T2
Erik Baumgartner Senior Member • Posts: 6,894
Re: Sharper images using ES with the 10-24mm WR?
At what shutter speeds?
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
OP jonikon Veteran Member • Posts: 7,433
Less than 1/60 sec.
Less than 1/60 sec.
It's certainly possible, that's where you'd see it. I don't notice any sharpness difference between the shutters with my X-T2, but I rarely shoot below 1/60'.
Clive99 Senior Member • Posts: 1,389
Less than 1/60 sec.
Yup, it's possible. I've seen this with the 18-55 and 16-80 before. Have not noticed it with my 10-24, but I think there's a lot of sample variability when it comes to shutter shock and OIS.
 Clive99's gear list:Clive99's gear list
Fujifilm XF10 Fujifilm X-E3 Fujifilm X-T3 Fujifilm XF 18mm F2 R Samyang 8mm F2.8 UMC Fisheye +16 more
Rightsaidfred
Rightsaidfred Senior Member • Posts: 2,179
Possible IMO & Proposal for a test
Yes that is possible that you introduce some shutter shock with the MS in a certain ss range.
I have potentially had this very occasionally with the X-T20 and the XF 18-55. I am not completely sure, but it is my hypothesis. I am also not sure what role floating lens elements play.
I have thought about a test, and this would be to put the camera on a hard surface (just lay down, no use of tripod screw mount), using a cable release, and comparing MS and ES at different ss. Use MF to keep the focus setting constant. I haven't done it yet.
Martin
 Rightsaidfred's gear list:Rightsaidfred's gear list
Fujifilm X-T20 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +5 more
Truman Prevatt
Truman Prevatt Forum Pro • Posts: 14,596
At 1/60 that is very possible.  It could result from the OIS also.  Run some test , first with MS and OIS on, then with OIS off.  Repeat with EFC and repeat with ES.
EFC does have an impact on the image but that usually doesn't show up until about 1/1000. However, the impact of EFC is related to the bokeh and with an F4 wide angle I'm not sure one would notice it.
"The winds of heaven is that which blows between a horse's ears," Bedouin Proverb
__
Truman
www.tprevattimages.com
 Truman Prevatt's gear list:Truman Prevatt's gear list
Leica Q2 Monochrom Fujifilm X-H1 Fujifilm X-Pro3 Fujifilm XF 35mm F1.4 R Fujifilm XF 50-140mm F2.8 +12 more
After taking dozens of shots indoors with half using ES and half MS with all shutter speeds below 1/60 second I'm convinced I get more consistently sharp images using the ES with these slow shutter speeds.  Others may have a different experience with the 10-24 using a different camera other than the X-T2 with a different shutter mechanism. IMO this is not a serious problem with the 10-24,  but good to know.
thxbb12 Senior Member • Posts: 2,211
Yes, it's highly likely a consequence of shutter shock.
I noticed that shutter shock can be a real issue at certain shutter speeds, with certain lenses and bodies.
I don't own the X-T2, but a X-T20, X-E4 and X-S10.
The X-S10 with the 16-80 is particularly prone to shutter shock for instance. It's actually so bad that I never shoot with the mechanical shutter anymore. I don't like surprises and I don't enjoy zooming on the photo after each shot to check whether it suffers from shutter shock or not. Since I only shoot with the electronic shutter, I haven't had a single instance of blurry picture.
 thxbb12's gear list:thxbb12's gear list
Fujifilm X-T20 Fujifilm X-S10 Fujifilm X-E4 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R +5 more
baobob
baobob Forum Pro • Posts: 18,248
It all depends if you are steady at slow speeds. with the 10-24 I can shoot MS tacksharp handhold at 1/4sec (50% tack sharp)
But ES makes things much better without the shutter shock.
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
