Longest exposure R5
Started 4 weeks ago | Discussions
Andy Pol
Andy Pol New Member • Posts: 2
Longest exposure R5
How I can use 30 seconds exposure on R5 without remote? I check preferences. 30 seconds exposure is available, but when I try to take longest exposure - I can take only 0''5. What do I do wrong?
Canon EOS R5
Polcastrol New Member • Posts: 7
Re: Longest exposure R5
Change to mechanical shutter. Electronic first curtain might also work but full electronic is limited in shutter time
Basil Fawlty
Basil Fawlty Regular Member • Posts: 237
That's good to know, thanks.
 Basil Fawlty's gear list:Basil Fawlty's gear list
Panasonic LX100 Canon EOS 5D Mark IV Canon EOS R5 Canon EF 50mm F1.4 USM Canon EF 135mm F2L USM +8 more
Tazz93
Tazz93 Veteran Member • Posts: 3,473
There was a bug that allowed you to use e-shutter in bulb for as long as you wanted, but the last time I checked that got patched away.
 Tazz93's gear list:Tazz93's gear list
Canon EOS-1D Mark II N Canon EOS 5DS Canon EOS R5 Canon Extender EF 2x II Canon EF 70-200mm F2.8L IS II USM +11 more
Quarkcharmed
Quarkcharmed Senior Member • Posts: 2,713
'might work'?
Electronic first curtain is the default shutter mode in the R5 and there's only one use case for mechanical shutter: shooting wide aperture and high shutter speed.
Long exposure probably means landscape photography and there is literally zero reasons to shoot landscapes in mechanical shutter mode or electronic shutter.
Apart from this 0.5s limit, ES also reduces the dynamic range, it enforces 12-bit raws.
 Quarkcharmed's gear list:Quarkcharmed's gear list
Canon EOS R5 Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM Canon EF 50mm F1.8 STM
apersson850 Senior Member • Posts: 2,076
Yes, it's only the more advanced sensor in the top-of-the-line R-series camera that keeps the number of bits with electronic shutter.
Anders
 apersson850's gear list:apersson850's gear list
Canon EOS 40D Canon EOS 400D Canon EOS 7D Canon EOS-1D X Canon EOS-1D X Mark II +26 more
Andy Pol
OP Andy Pol New Member • Posts: 2
Thanks! It works!
