Electronic Flash and the R Series
Started 1 month ago | Discussions
phcd Forum Member • Posts: 93
For indoor events DSLR cameras and electronic flash worked quite well using Manual (M, 1/125 or 160 sec.) settings.
With the R series the viewfinder is too dark in Manual.  What is the best strategy to use electronic flash indoors with the R series cameras?
Franz Kerschbaum
Franz Kerschbaum Senior Member • Posts: 1,242
Re: Electronic Flash and the R Series
You only have to disable "Exposure Simulation" for the viewfinder to avoid a dark screen in manual settings.
 Franz Kerschbaum's gear list:Franz Kerschbaum's gear list
Canon EOS 5D Mark II Canon EOS 7D Mark II Canon EOS M6 Canon EOS Ra Canon EOS R5 +30 more
Steve Balcombe Forum Pro • Posts: 15,571
I have no problem using flash on my R5 and R7 - the body detects the flash and automatically adjusts the viewfinder brightness when I half-press the shutter button. I may have forgotten something but I don't think I had to make any special settings, it just worked out of the box. I didn't have to disable Exposure Simulation, the camera overrides it automatically when using flash.
I mostly use M exposure mode and ETTL-II flash, but sometimes manual flash.
Franz Kerschbaum
I have also a R5 and R7 and I want to have a permanently(!) bright finder when in M mode with my canon 600ex ii rt flash independently of my manual aperture, time and ISO settings. This is possible only with Exp.Sim. OFF. When ON the finder emulates the brightness that would be present without the flash. I've used this for many thousends of pics.
If you insist on 'permanent' then yes, obviously you have to turn Exposure Simulation off. But you don't need to, because the R5 and R7 are smart enough to turn it off temporarily for you when the flash is attached and switched on, and you have half-pressed the shutter button. I've used this for many thousands of pics.
Gam3r01 Contributing Member • Posts: 572
My RP and R6 both behaved the same way with my 430EXII. If the flash was off (or asleep) the simulation would be dark, but on a half press it woke the flash up and the exposure sim adjusted to include the flash as well.
 Gam3r01's gear list:Gam3r01's gear list
Canon EOS R6 Canon RF 35mm F1.8 IS STM Macro Canon RF 24-240mm F4-6.3 Canon RF 16mm F2.8 STM
Franz Kerschbaum
If I halfpress then I do AF. Something I dont want to do before I aim the camera...
I agree it can be inconvenient sometimes. But so can having to explicitly switch Exp Sim off and on - it's way too useful to just disable.
deebatman316
deebatman316 Forum Member • Posts: 65
With a Canon speedlite mounted exposure simulation is disabled automatically. A 3rd party speedlite may NOT disable exposure simulation.
-Demetrius
 deebatman316's gear list:deebatman316's gear list
Canon EOS 40D Canon EOS 5D Mark IV Canon EF 85mm F1.8 USM Sigma 17-50mm F2.8 EX DC OS HSM Canon EF 24-70mm F2.8L II USM +5 more
PicPocket Veteran Member • Posts: 5,897
This is a good use case where exposure and AF don't need to be on same button. I have them decoupled and do each when I need to
PicPocket
 PicPocket's gear list:PicPocket's gear list
Canon EOS R5 Canon EF 24-70mm F2.8L II USM Sigma 135mm F1.8 Art Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +16 more
