Which Canon EF-EOS-R?
Started 1 month ago | Discussions
Solinthor Forum Member • Posts: 54
Hi
Which one to choose?
- the simpliest/ cheapest one?
- the one with the ring?
- any feedback for the ones with filter?
 Solinthor's gear list:Solinthor's gear list
Canon EOS 7D Canon EF 70-200mm F4L USM Canon EF 100-300mm f/4.5-5.6 USM Canon EF-S 60mm f/2.8 Macro USM Canon EF 40mm f/2.8 STM +15 more
Peter Kwok
Peter Kwok Senior Member • Posts: 2,635
What are you asking?
Are you asking about camera bodies or lens?
Ring?  Do you mean the red rings on Canon's professional L lens?
Please be specific with your need and background.  Otherwise we cannot help you.
Peter Kwok
Click here for my PBase gallery
WYSIWYG - If you don't like what you get, try to see differently.
 Peter Kwok's gear list:Peter Kwok's gear list
Canon EOS 5DS Canon EOS R5 Canon EF 16-35mm F4L IS USM Canon RF 14-35mm F4L IS USM Canon EOS M6 +8 more
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
Re: Which Canon EF-EOS-R?
Solinthor wrote:
Hi
You're asking about the adapter. I initially bought the one with the control ring. It works fine. But then I sold all my EF lenses. I just bought the R6II from a Canadian store that included the regular adapter. I sold my control ring adapter, because I found that I hardly ever used the control ring on it, but I'm keeping the free basic one, in case I ever get another EF lens (maybe I find a used one really cheap that I otherwise wouldn't get in RF mount). The thing to be aware of with the control ring adapter is that the control ring will be right next to the camera body. On RF lenses, the control ring tends to be close to the front. Whether you should get the control ring adapter depends on how many EF lenses you'll be using, and how much you think you'll use the control ring. It's a neat feature, but I haven't found myself using it much, partly because all the R cameras I've had so far (R, R7, R6II) have so many other customizable buttons and dials.
I have no experience with the filter holder adapter.
“When I die, I want to go peacefully in my sleep like my grandfather. Not screaming in terror, like the passengers in his car.” Jack Handey
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
coberg Forum Member • Posts: 68
Re: What are you asking?
My guess is that he's asking about which of the three Canon EOS EF to R lens adapters would be the best choice.
In my case I went for the basic one because:
it's cheaper;
I've never never used a control ring on a lens, so I won't miss having one;
and, generally, I already have filters for the front of the EF lenses that I use filters with.
However, there is one lens where the adapter with drop in filters may be useful at times, so I won't rule out buying one of those at some point.
DivaDreamer New Member • Posts: 20
The adapters, I think is what is meant.
I guess it really depends on your style of shooting and budget. Are you buying an adapter for each lens or one to share? Have you tried an RF lens with a control ring? Did you like the functionality? Do you shoot mostly landscapes where consolidating various filters into one set only for all ef lens would save you money?
I have a limited budget, and while I would have liked the control ring adapter, I found a lovely used copy of the basic adapter which saved a bit of money. Thus, my decision was made. It has worked just fine so far.
I hope answering the above questions helps you decide which adapter might work best for you. Cheers!
José B
José B Forum Pro • Posts: 20,482
Solinthor wrote:
Hi
I just went with the simple adapter. I've got a lens (another mount) with an aperture ring and I don't use it so for an adapter I went with the simple and also the cheapest.
 José B's gear list:José B's gear list
Canon EOS R6 Mark II Canon EOS-1D Mark III Canon EOS 5D Mark II Canon EOS 5DS Sony a6500 +16 more
antonio-salieri Regular Member • Posts: 208
They all work the same. Do you like the control ring a lot? Then you can get that one. Otherwise, the regular one works perfectly. Very simple and it's all more or less seamless.
I have a filter adapter (mine is a Kolari one, but they all work the same). Wonderful with a Breakthrough drop-in polarizer. Great to control the polarizer from near the camera body and it works with all EF lenses.
I also have a Metabones speed booster, which is useful mostly for video on the R7, or in Super 35 5K RAW/4K crop mode on the R5. I wrote a mini-review of it here before. https://www.dpreview.com/forums/thread/4682659
 antonio-salieri's gear list:antonio-salieri's gear list
Canon EOS 5D Mark III Canon EOS R5 Canon EOS R7 Canon EF-S 18-55mm f/3.5-5.6 IS STM Sigma 50mm F1.4 DG HSM | A +14 more
OP Solinthor Forum Member • Posts: 54
A sorry, yes, the ring
The one to adapt EF lenses on RF body
Hi
Sorry everyone for the confusion, yes I meant the Adapter for EF lens on a R body.
From what I see, the ring is nice, but very usefull, unless you really like to use the ring on RF lens to have the same type of customization.
Thanks for your reply
R2D2 Forum Pro • Posts: 26,536
I really like having the control ring programmed to change AF Method. Bam Bam, quick and easy.
R2
Canon_Guy
Canon_Guy Senior Member • Posts: 1,486
Solinthor wrote:
Hi
Please no offense, but how should we guess your shooting needs, habits, preferences when you do not describe any of it? You should know best how you use your stuff and therefore which of these would suit you the best.
But sure I understand that you want to be inspired by other who might have bigger experience and that is of course very fair.
I have the basic adapter on every EF lens as a standard for most usual use. Plus I did buy the filter adapter with variable ND and polarizer filters since its use is moch more convenient with my lenses: my EF lenses have 3 different filter threads (77, 82 and 105mm) and one lens does not even have any filter thread (Sigma 14-24/2.8). Also operating especially the polarizer filter is MUCH easier on the adapter than on the lens with lens hood attached. For example with 70-200/2.8 it is near to impossible.
The basic adapters I bought are Canons, the filter adapter is from Meike. Its build quality is very equal to the Canon but is WAY cheaper and also its VND filter is a bit better quality (less color shift near max ND settings).
And I never opted for the control ring adapter since I find the ring fully useless with my R6. In other words I can not find any suitable setting which I would need to transfer to the ring since I already have all important settings spread conveniently on the R6's buttons and dials.
 Canon_Guy's gear list:Canon_Guy's gear list
Canon EOS R6 Canon EF 70-200mm F2.8L IS II USM Sigma 14-24mm F2.8 DG HSM Art Sigma 105mm F1.4 DG HSM Art Canon RF 24-105mm F4L IS USM +6 more
Steve Balcombe Forum Pro • Posts: 15,571
Solinthor wrote:
Hi
TL;DR - it depends.
I've ended up with four adapters, but not entirely from choice! My first EOS R System body was the R5, which included a free adapter but it wasn't bundled, it was one of those that you had to apply for and wait for it to arrive. And wait. And wait. In the meantime a local bricks-and-mortar camera shop knew of my problem and was kind enough to contact me when they had a control ring adapter. All the EF-RF adapters were as rare as rocking horse poop at the time, so I grabbed it while I had the opportunity - I figured I might be glad to have two adapters, and to try out the control ring version. Three months later I finally had the plain adapter as well.
I did like the control ring adapter, and actually it had one advantage over the RF lenses' built-in control rings in that it was always in the same place. But as time went on I began to realise that I just wasn't using it. The R5 has three wheels so the control ring was a fourth that just wasn't needed. What had seemed like a great innovation back when I learned about it and tried it for the first time - at an EOS R launch event - had become surplus to requirements.
So the answer to your question, is that it depends which body you have. If it's one which doesn't have three wheels, the control ring is useful and possibly worth the extra cost. But if you have the R5 or any other which has three wheels, the plain adapter is honestly all that you need. It's interesting that Canon has now launched four RF mount big whites which have no control ring! The assumption must be that these lenses will only be used with high-end bodies, and that is probably true.
For the very small number of people who (a) noticed that I said I had four adapters, and (b) won't rest until they learn about the other two: the third was bundled with the R7, and that also took three months to arrive (because it was in the box with the R7 - which took three months to arrive...). The fourth is a drop-in filter adapter, the Meike one which I picked up recently and haven't had much chance to use. I'm hoping it will work really well with my EF 16-35/4L IS, but I don't think I would want it as my only adapter.
RONIN022 New Member • Posts: 3
My suggestion would be the one with the ring but a refurbished one for Canon direct its $129. At that price you only $30 over a brand new regular adapter. I have both, one came with my RP. I later found the deal on the ring one which I use the most. I have both on EFs lens so they can be used on the RP and R6.
Here is he link to the site... https://www.usa.canon.com/shop/p/refurbished-control-ring-mount-adapter-ef-eos-r .
Edit: Sorry just realized it's out of stock. It does come back in stock often so keep a look out and sign up for updates.
Axel
 RONIN022's gear list:RONIN022's gear list
Canon EOS M Canon EOS M6 Canon EOS RP Canon EOS M6 II Canon EOS R6 +12 more
Well, it seems these EOS EF lens adapter are pretty difficult to find here in Canada.
I took nochance and was lucky enough to have one with the ring in the store where I preorder the R8.
charlyw64 Contributing Member • Posts: 717
Just two tipps:
- Stay clear of 3rd party control ring adapters (they don't get new firmware that is needed to support newer cameras).
- Stay clear of the Canon original filter adapter, the Meike one has much better filters and is much cheaper.
StefanD Contributing Member • Posts: 577
I went for the one with the control ring because it's only a bit more expensive than the simple one and it doesn't have any other drawbacks.
I use it on an RP and I think the additional €80 for an extra control ring is well worth it.
If you plan to use filters, the adapter with drop-in filters could be a wise investment.
Bryan Conner
Bryan Conner Forum Member • Posts: 99
I agree completely.  I have the adapter with the control ring and almost never use the control ring...and I only have EF lenses, no RF lenses yet.  I recognize that the ring is very customizable and that it offers some useful features, but I simply forget to use it.
So, if I had it to do over again, I would probably buy the standard adapter without the ring.
Ravensburg, Germany
 Bryan Conner's gear list:Bryan Conner's gear list
Sony RX100 III Canon EOS R Canon EF 70-200mm F2.8L IS II USM Sigma 105mm F2.8 EX DG OS HSM Tamron SP 24-70mm F2.8 Di VC USD +1 more
Rock and Rollei Senior Member • Posts: 2,902
Yeah. I got the basic ring free when I bought the R about 4 years ago now, and as the control ring one was available on special offer at the show I bought the camera/adapter/24-105 L and 35 from, I go that as well, thinking it would be the one I would use most. And - well, I don't. I don't often use the control ring. I do find it handy for pro work if I'm using a mixture of EF and RF lenses to have an adapter per lens, but if I'm only shooting EF glass, I leave the adapter on the camera, but most of the time, I'm shooting either EF L glass for paid stuff, and the cheaper RF lenses for more personal stuff where I don't want the extra weight.
 Rock and Rollei's gear list:Rock and Rollei's gear list
Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS R Canon EOS M6 II Canon EF 50mm f/1.2L USM +29 more
borgefjell Forum Member • Posts: 72
Got my basic adapter with my RP and am using that one so far.
I like to control my aperture on the lens and will probably buy the one with the control ring one day - but from my experience this makes only sense if you are using primes or zooms with fixed apertures
For the version with the drop in filter: what kind of filters are you using and how many lenses do you use with filters + do you already have the filters - drop in makes sense for polarizing filters + nd-filters but is no solution for nd-grad... might on the other hand be the only solution for ultra wide lenses with curved front lenses or telephoto lenses
RDKirk Forum Pro • Posts: 16,545
The ring is useful with the EOS R
Solinthor wrote:
Hi
The ring is useful with the EOS R. That body can make good use of another control.
Many people use the ring to control aperture. I use it in manual exposure mode to control ISO and in auto-exposure mode to control exposure compensation.
I especially like using it to control exposure compensation while shooting stage productions with exposure simulation turned on. I can ride exposure with my left fingers while controlling focus and shutter release with my right fingers.
RDKirk
'TANSTAAFL: The only unbreakable rule in photography.'
 RDKirk's gear list:RDKirk's gear list
Canon EOS 5D Mark II Canon EOS 70D Canon EOS 5DS R Canon EOS 80D Canon EF 24mm f/2.8 +7 more
