Re: Best budget 50mm equivalent for G7 lowlight cinema?
Kylefowler85 wrote:
thinkinginimages wrote:
Kylefowler85 wrote:
I’m gearing up to start test shots & planning for some guerrilla style horror and dark drama films in low-light scenarios.
I’m using the LUMIX G7. In the past (on Canon 70D) I’ve enjoyed the freedom and results of using a “nifty 50” for most shots, space allowing. I’m looking for something that will be a 50mm equivalent on Micro 4/3 and is less muddy than the 7 Artisan lenses I got when learning the camera, and hope to cut down some noise.
I am on a very tight budget and really don’t want to spend too much more than $300 on a lens. I know that keeping the aperture open wide enough for low-light will result in some background blur but I’m not really trying to lean into bokeh artistically.
My research has led me to believe that the Voigtlander 25mm F/0.95 Nokton and Samyang Cine 24mm T.15 with an EF to m43 adapter might be solid options. I’d also looked at a meta bones speed-booster but I don’t have many great 35mm options handy.
Any advice? Much appreciated, Cinematography and color grading have never been my strongest suits but I often find myself doing hand-made projects and operating the camera by default
You're mentioning some fine all manual lenses but I don't know what your shooting style is. The Panasonic 25 1.7 is a bargain - but there's no aperture ring. You control that thru the interface. The autofocus, if you want to use it, is almost silent.
There's a lot of "trendy" lenses out there. I tend to notice trendy buzzwords like "T stops" and Cine. "T stops" are typically used with hand held meters. "Cine" is a bit too "Charlie Chaplin. The Nokton at least has some history and reputation behind it.
I always use manual focus. I may have benefitted from exploring auto focus more but I understand it's not great on G7 anyway? I mostly use sticks, very occasionally pan & tilt with the fluid head. I recently acquired a Weebill S gimbal which I've used for some casual videography but no cinematic storytelling as of yet, I believe the lenses I've been using are too light for its optimal settings anyway. I should run some more tests with that
I can live with controlling aperture in camera, you've enjoyed the Panasonic 25 1.7?
I'd heard that T-stop was standard for a lot of lenses used in cinema and those lenses tend to be designed to get a slightly softer image than still photography lenses?
I think it depends on the scene/situation to go with manual or autofocus, even experience. Crazy enough I don't have a preference. I look at the boards, the lighting and have a "yep, like that" moment.
I've got the 25 on my GX1 right now, a much older camera than the G7. It's a grab and go. The AF is fine and nearly silent. Not sure where you heard the G7 is bad. There are a few people out there that swear that a camera is bad and not a "real camera" without PDAF. Sure, whatever.
T stops came about with cine film and lenses on turrets. Check out the cine camera below. You need the exact same exposure from all three lenses (short, medium, long/zoom). The lenses are calibrated for actual light transmission. Example t/8 is the same on all 3 lenses. f/stops would be different. The long lens has less light transmission. T/ is not all that relevant on cameras with built in meters, it just sounds "important".
Getting back to reality and the present: To keep it on the cheap, find a used 25 1.7 with a great return policy and give it a go. I didn't notice where you're located. In the US KEH and MPB are good.
Side note: You can probably adapt these old lenses to your camera... I think it's C or PL mount. It depends on the cine camera. It's been a while since I thought about it...
