Image Stabilization experiment just for fun
1 month ago
Experiment:
The IS capabilities of newer cameras is nothing short of mind blowing. Just using the old standby rule, without any IS, you should shoot with a shutter speed of at least 1/(focal length) to avoid camera shake-induced blur when shooting hand held. Based on that guideline, with my 24-105mm RF lens, shooting at 105mm, sans IS, I should be able to get good sharpness handheld with any shutter speed above 1/105th. So, for this experiment, I'm going to shoot a static subject at 1/125th handheld (trying to stay as fixed as possible, hold breath, elbows in, etc).
Now, according the the marketing propaganda, the combination of the R5 IBIS and lens IS of the RF 24-105L should yield 8 stops of image stabilization. This means, if I can get a sharp image at 1/125th, I should be able to get a similarly sharp image at 8 stops slower shutter speed, or 2 seconds.
I shot the below series, first at 1/125th. Then I shot 8 stops slower at 2 seconds. Note I was about 8 feet from subject at 105mm, hand held and not braced against anything. For Each shutter speed I'm showing two images - one is full size (scaled to allow upload of course) and the second image in zoomed in about 500%. The full size image doesn't look too bad compared to the 1/125th, but when I zoom in to 500% you can see some shake blur, though not terrible (I probably could have done better had I braced against something like a wall.
The next two images were shot at 7-stops slower or 1 second. Then the last two images are 6-stops slower. At this shutter speed (.5 sec), with IBIS and Lens IS on, I feel like the sharpness is pretty darned close to shooting at 1/125th.
Conclusion: I'm impressed with the IBIS/IS capabilities of this camera / lens combo. I also ran the 2 second exposure through Topaz sharpen, (see last two images) and the results were amazing (I think).
Shutter speed 1/125th Not cropped in.
1/125th cropped in about 500%
2 second shutter speed. Not terrible in my opinion for completely hand held (could probably do better with practice and better technique)
2 second exposure cropped in. Here you can see pretty clearly some camera shake. Might be able to do better with practice.
1 second (7 stops slower than 1/125th). Not perfect but better.
1 second exposure cropped in 500%. The camera shake blur is not as noticeable.
1/2 second exposure. This is still 6 full stops slower than 1/125th and I'm pretty happy with this result.
1/2 second exposure cropped in 500%. This is pretty amazing to me for such a slow shutter and hand held by an old guy!
Ok, Now, I took the 2 second exposure and ran it through Topaz AI Sharpen. Pretty amazed at the result:
This is a hand held 2 second exposure after running it through Topaz AI sharpen. Maybe I'm just easily impressed, but I was impressed.
The same 2 second exposure first run through Topaz and then cropped.
