Can you change either dial on the R8 to ISO?
Started 1 month ago | Discussions
Nunataks
Nunataks Regular Member • Posts: 229
I remember this being a huge frustration with the RP and since it uses the same body I figure they haven't updated it. Setting ISO control to a button or the control ring doesn't work for my workflow before anyone suggests it either, and it's why I sold the RP.
Ricoh Caplio R8
cocoanud
cocoanud Contributing Member • Posts: 699
Re: Can you change either dial on the R8 to ISO?
I think it is possible https://cam.start.canon/en/C013/manual/html/UG-09_Custom_0030.html
On the RP only the control ring on a RF lens could be assigned.
Also, of late I have adapted to Fv mode so that also helps moving between different bodies.
 cocoanud's gear list:cocoanud's gear list
Canon EOS R6 Canon EF 100-400mm F4.5-5.6L IS II Canon EF 70-200 F4 II Canon RF 24-105mm F4L IS USM Samyang AF 85mm F1.4 RF +3 more
Brian Slater Regular Member • Posts: 432
The Quick Control Dial can be set to control ISO. You can use Fv mode to set ISO (or other exposure settings) on demand.
 Brian Slater's gear list:Brian Slater's gear list
Canon EOS 6D Canon EOS M6 Canon EF 17-40mm f/4.0L USM Canon EF 70-200mm F4L USM Canon EF-S 60mm f/2.8 Macro USM +4 more
