Fujifilm xt100 still good ?
zakaria
zakaria Veteran Member • Posts: 6,556
Hello .. I would like to ask a question to those who own the XT100 and use other types of Fujifilm such as the XT20. Do you find a big difference in colors rendering and sharpness? I'm not talking about anything other than the Jpeg file. Do you think the XT100 is better? Why am I asking that because I am in the process of buying a new XT100 at a good price. I have an XT3 and I have heard a lot of talk about the traditional Bayer sensors compared to the modified Fuji ones.
I will use the camera for static things and maybe with manual lenses.
pentaxian .
 zakaria's gear list:zakaria's gear list
Fujifilm X-H1 Pentax K-1 II Fujifilm X-T3 Nikon D780 Pentax smc FA 31mm F1.8 AL Limited +8 more
Fujifilm X-T1 Fujifilm X-T10 Fujifilm X-T20 Fujifilm X-T3
sprouty115
sprouty115 Contributing Member • Posts: 618
Re: Fujifilm xt100 still good ?
The XT100 is as good as it ever was and the XT3 won't make a "better" image.
There are probaly slight differences, but this is neither better nor worse.
So do a YouTube search for X-Trans sensor differences - there are probably a thousand videos like this:
https://youtu.be/yF790-vReJU
Then when you're fully confused, just go buy whatever camera you prefer using and forget about it.
 sprouty115's gear list:sprouty115's gear list
Ricoh GR III
WeirdSheep Regular Member • Posts: 220
Most criticisms of the X100 were about it's speed of operation when it came out, these have long since been resolved. It's no speed demon but I don't have any issues with AF speed personally, it's just not as zippy as more modern cameras. In terms of IQ, it has it's own subtle rendering, I find the colour to be excellent and it's particularly good for black and white in my experience. The lens is also exceptionally sharp from F2 onwards, it's a bit softer for close up semi macro stuff but that's no issue to me either. All in all I still love mine to bits, it's the only camera I've ever bought twice ( I regretted selling the first one so bought another ). The sensor is good up to ISO 3200 in colour, 6400 in black and white. Enjoy it when it arrives, it's cracking camera whose images completely hold up for large prints, no problem, despite 'only' being 12mp.
zakaria
OP zakaria Veteran Member • Posts: 6,556
Thank you so much for your time and your experience about " X100 " .it is really informative though I was talking about " XT100 ".
pentaxian .
Apologies, I misread your post, though I'm sure what I said equally applies, none of these 'old' cameras were ever anything other than excellent, though you did mention a bayer sensor, and the XT100 is X-trans.
zakaria
Thank you again. I think it is Bayer sensor as xf10
pentaxian .
The XT100 is definitely X-trans, the only bayer sensor X100 is the first one.
Joe Hotshoe Forum Member • Posts: 57
This is the problem with similar camera names!  I think you're thinking of the X100t.  The XT-100 is an entry level camera with the same Bayer sensor as the X-A5.
 Joe Hotshoe's gear list:Joe Hotshoe's gear list
Canon G7 X II Fujifilm X-S10 Fujifilm XF 23mm F2 R WR Fujifilm XF 16-80mm F4 Fujifilm XF 70-300 F4-5.6 R LM OIS WR
Ah yes, that's right, and I agree, it does get confusing with so many similar names.
Fz2000user uk Senior Member • Posts: 1,509
the xt100 is not xtrans though
It’s all about the zoom
 Fz2000user uk's gear list:Fz2000user uk's gear list
Olympus OM-D E-M1X Fujifilm FinePix IS-1 Fujifilm X-S1 Sony RX10 II Nikon Coolpix P1000 +5 more
rla1022 Contributing Member • Posts: 762
And it’s functionally garbage now.  So many early xtran cams that are and were so much better.
 rla1022's gear list:rla1022's gear list
Fujifilm X-E4 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 35mm F2 R WR Fujifilm XF 16-80mm F4 Fujifilm XF 27mm F2.8 R WR +1 more
sprouty115
I stand by my point that it was as good as it ever was and regardless of whatever sensor it has that is no reason to discount it.
Ricoh GR III
Lettermanian
Lettermanian Senior Member • Posts: 2,389
It is indeed a Bayer-array sensor, not X-trans. I had one for a little while a few years ago, and I quite liked the images out of it; can't really say better or worse than X-Trans though. It is quite basic in its features and functions, nowhere near the features and capabilities of the X-T3 (my current camera). If out-of-camera jpegs are what you're after, I'd stick with the X-T3 for its abilities to customize jpegs, severely lacking in the X-T100.
Over the years I've seen several comments about how useable its lcd design was: basically a hybrid flip and tilt screen. The camera has also been praised for astrophotography, yielding a very clean image with no baked-in "star-eating" noise reduction. While its video capabilities are low, it can render in-camera a 4k/30p timelapse video from up to 999 still images using the built-in intervalometer. The camera can also save the still image files separately from the rendered video file; the images aren't lost when the video is rendered.
Personally I couldn't recommend it as a "main" camera if you like the more classic Fuji experience offered by the X-T3, but it could indeed have its uses for certain types of shooting.
"Be yourself. No one can say you're doing it wrong." -Charles M. Schulz
"I love mankind... it's PEOPLE I can't stand!!" - Linus
 Lettermanian's gear list:Lettermanian's gear list
Fujifilm X-T3 Carl Zeiss Touit 2.8/12 Tamron 17-70 F2.8 Di III-A VC RXD Fujifilm XF 70-300 F4-5.6 R LM OIS WR
zakaria
Thank you so much. It is very helpful and informative reply.
I have been a fujifilm user since the great and last fujifilm dslr X pro 5 .and from XE1 to xt3 . I shoot  only jpeg. I noticed that x-trans sensors are more badly effective on jpeg files. Files tend  to have  a  plastic fell. Details are absent when zooming pictures.
pentaxian .
DarnGoodPhotos Forum Pro • Posts: 11,881
I think it will be fine for your intended use of static shots.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
sshapiro Senior Member • Posts: 1,018
I got one a couple of years ago and used it for about six months along with an X-T3. The camera is slow, but it should be fine for static shots. I had mine converted to infrared, and it has worked fine for that purpose. I have read that some people prefer the X-T100 for astrophotography because the sensor uses contrast detection instead of phase detection, which has some positive impact on the quality of the captured image. I don't know much about astro, so I can't explain how contrast detection helps, but I think it has something to do with heat or noise.
Image quality is very good but it’s a bit laggy and af is very pedestrian.
I just got a new in the box with kit lens £499 today
zakaria
Mine will arrive tomorrow. It is new also body only 300$
pentaxian .
A good price.
UsherFellig Regular Member • Posts: 174
I love the rendering and color results of the Bayer-sensor Fujis, the original X100 and the X-T100 being my favorites. The caveat being, they excel for considered shooting of static subjects, which is largely my use case so it's a fit. The detractors were unhappy with their limitations for moving subjects and\or run-and-gun, from-the-hip "street" shooting. My XF10 and X-A5 also give lovely results for static shots but I underuse them due to lack of vf.
