Advice needed on live view in screen/viewfinder for R5
Started 1 month ago | Discussions
Sb1202 New Member • Posts: 3
Hi folks,
I'm a long time dslr user and been used to the OVF for composing etc. I have a couple of sony a7iis and the liveview through the EVF is amazing - almost like an OVF. When I bought an Eos R recently, I was expecting the same but I've been hugely disappointed and frustrated by the EVF screen dimming when recomposing. i.e if I focus on a dim area in a landscape, then recompose to include more sky, the viewfinder dims way to dark. Same with panning widlife or sports and its making me miss shots I would otherwise have caught with the sony or dslr. I've tried every setting in the R to fix this but no joy.
I'm now thinking of getting an R5 but I need to know if this can be dialled out to behave more an ovf.
Canon EOS R5
cnyphotoguy Contributing Member • Posts: 817
Re: Advice needed on live view in screen/viewfinder for R5
Do you have exposure simulation turned on? If so it can be turned off in the menus.
 cnyphotoguy's gear list:cnyphotoguy's gear list
Canon EOS Rebel T6i Canon EOS RP Canon EOS 90D Canon EOS R7 Canon EF 100mm F2.8L Macro IS USM +15 more
OP Sb1202 New Member • Posts: 3
Yeah, turned off but it doesn't make any difference. If I move between sky and forground, it still dims the VF. It's also upgraded to the latest firmware.
Mike Engles Senior Member • Posts: 2,573
If it is off the EVF brightness should remain reasonably constant, except at twilight times.When on it does depend on your settings, which the OVF, did not
Sadly the VF simulation does also depend on the picture style in use to some degree.
Abbott Schindler Veteran Member • Posts: 3,099
This is the case with Live View and the LCD on DSLRs as well. Both the rendering on the display and the histogram are dependent on the Picture Style.
Curiously to me that did not seem to matter on the DSLR LCD,but I do dislike the EVF rendering in a R5. It is I guess because the dynamic range in the OVF is huge in terms of bits, but the R5 EVF is only 8 bit. Realy difficult to use in backlit situations. I have made a special Picture Style to try to deal with this. Sadly this can skew the AF and the metering
Thats what I was hoping for, but I've tried it on and off and saw no difference in the EVf.
Really? I always assumed they had no effect as I only shoot raw. I never use them tbh but I'll check this out and see if it has any effect.
jonby Regular Member • Posts: 399
Sb1202 wrote:
Hi folks,
This sounds like normal behaviour if you are in one of the auto or semi-auto exposure modes. The camera is just adjusting exposure to compensate for bright areas entering the frame, and the EVF follows suit. The only 'problem' is that in very contrasty scenes, darker areas can become hard to see for composition because the EVF preview has limited dynamic range.
There are a number of workarounds/things which may help:-
1: adjust settings so that the preview image has less contrast - this could be picture style settings and/or auto lighting optimizer. These will affect JPEG output but not raw. I think their effects will show up in the EVF preview (haven't tried it though).
2: use centre-weighted metering rather than evaluative. Canon place a high degree of exposure emphasis on the area around the active AF point. If, when recomposing, your AF point goes over a bright area, exposure will change substantially. Centre-weighted metering is likely to result in milder changes to exposure.
3: set the shutter button to lock both AF and metering (I'm assuming you have the shutter button linked to AF). This will lock exposure when you set focus, and as you recompose, there will be no change in exposure. However, this may result in blown highlights.
4: use your exposure lock button (*) to lock exposure appropriately first, and then lock focus and re-compose. Generally, you should lock exposure so something a bit brighter than your 'dim area', so that you can both see to compose, but also don't blow your highlights.
5: first compose and set exposure correctly, either using exposure comp or manual mode. Then point down to your subject to set focus and finally recompose.
6: move your AF point to the right point in the frame rather than recomposing.
I think you should be able to find a way around your issue with some of the above.
It is part of the process of making JPEGs embedded in the RAW and also effects the LCD and EVF..Picture review shows the embedded JPEG
I use auto ISO which keeps the exposure close to optimum,as well as screen brightness, but can clip highlights. I also use -1/3 to -2/3  manual exp comp to mitigate this
