Need R5 L bracket
Started 1 month ago | Discussions
Cyberbo
Cyberbo Junior Member • Posts: 43
Need R5 L bracket
I am looking for an L bracket to connect a flash to my R5. I don’t like flash on top of the camera and I love it on the side. I have a Godox 360 ii and would to use it on camera as well as off camera .   Thanks
Canon EOS R5
CameraCarl Veteran Member • Posts: 9,193
Re: Need R5 L bracket
There must be at least a dozen brackets on the market now. Search at B&H for a start.
BobKnDP Senior Member • Posts: 3,140
Intended to move a flash off the hotshoe?
pawn Veteran Member • Posts: 3,261
Try the L-bracket from Promedia Gear and see if it works for you
BisonOz
BisonOz Forum Member • Posts: 95
I second the ProMediaGear L Bracket.  I just got it and it is well designed.  The L part is moved forward away from the ports (USB, HDMI, etc).  It also has a shoe mount on top.
Canon EOS R5 & R3 / RED Komodo
 BisonOz's gear list:BisonOz's gear list
Leica Q2 Canon EOS R5 Canon EOS R3 Leica M11 Canon EOS R5 C +10 more
Atta-Boy Regular Member • Posts: 129
may be search for "flash bracket" instead of narrowing for R5 specific L-bracket ... $0.02
