X-T2 or X-T3 as second body: colors, build quality, low light
al404
al404 Contributing Member • Posts: 827
I did read quite a lot about X-T3 vs X-T2 AF even if it was pretty much old stuff but from what I understand AF it is faster on X-T3 and face / eye detect works. On X-T2 the subject needs to be in ideal conditions.
It is not a price issue but mode about difference in sensor and colors in RAW but without editing.
And also about build quality, are both WR at the same level?
As far as I know X-T3 it is build in Japan but X-T3 is not, not sure if does make any difference.
I also own an X-T5 and this camera it a second body that I would use for smaller files, every day shoot or when I need to shoot a lot of pictures like it happened last week with carnival.
 al404's gear list:al404's gear list
Fujifilm X-T3 Fujifilm X-T5
Fujifilm X-T2 Fujifilm X-T3
dwalme Regular Member • Posts: 414
Re: X-T2 or X-T3 as second body: colors, build quality, low light
X-T3 is the better camera with the more accurate sensor.  This made it much easier to work with raw files to get the results with color that I wanted when making my own camera profiles to use with the various raw editors.   If you are only using film emulations this is less of a benefit but it still is.  Even Fuji themselves mentioned they were able to improve the film sims in the newer cameras (at the time the XTrans IV cameras were released) due to the better tech.
Having owned both I fail to see a single scenario where I’d prefer an X-T2.  It has been some time though so it’s hard to remember.
Lots of fans here of the X-T2 so expect many will chime in with all the reasons that they prefer that camera.
 dwalme's gear list:dwalme's gear list
Sony a1 Fujifilm X-T5 Fujifilm XF 14mm F2.8 R Fujifilm XF 50-140mm F2.8 XF 90mm +9 more
a_c_skinner Forum Pro • Posts: 13,047
They are both excellent.  I don't think the T2 is as good at sky colour as the current 40Mpix sensor.  Otherwise build is excellent and colours good, difficult to see the difference.  Higher ISO is pretty much the same.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
Erik Baumgartner Senior Member • Posts: 6,893
Face/eye detect is better with the 3, but not really all that reliable with either. AF-S is very good with both.
There’s no such thing as RAW without editing. SOOC jpegs are typically going to be better than RAW at default import settings (which can look significantly different with different editors). Either camera can have excellent color using the right profile and other settings. The X-T2 files are a bit cleaner at higher ISOs, especially with the electronic shutter but, again, at default settings you probably won’t see much difference.
I don’t see why they wouldn’t be.
Probably not. The X-T2 has much better command dials (IMO) and I prefer the taller top dials as well, but I don’t think that has anything to do with where they were manufactured.
If I had one, I’m pretty sure I’d want to use the X-T5 here as well.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
DarnGoodPhotos Forum Pro • Posts: 11,881
The X-T2 is better in low light due to a bit less noise. Not a huge difference mind you, but it’s there. Then again the X-T3 has better AF with the same type of better tracking in your X-T5.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
biza43 Forum Pro • Posts: 15,074
Raw without editing is a contradiction. Can you clarify?
I have used both, never had a problem.
No difference.
www.paulobizarro.com
http://blog.paulobizarro.com/
 biza43's gear list:biza43's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
Heinz Senior Member • Posts: 1,905
I guess build is on both better than X-T5  X-T3 has much better video, better AF. I would say its a steal for current prices.
 Heinz's gear list:Heinz's gear list
Fujifilm X-T3
Threaded Veteran Member • Posts: 4,180
XT3 has all the advantages really, better sensor (more dynamic range), better AF across the whole frame and in lower light, more reliable AWB IMO, hard to think of anything that’s not either the same or better on the XT3.
Don’t be misled by the XT2 being made in Japan, from what I’ve seen and read the XT3 seems to have the same or better build quality, if anything.
 Threaded's gear list:Threaded's gear list
Fujifilm X-Pro3 Fujifilm X-E1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 23mm F2 R WR
Morris0
Morris0 Forum Pro • Posts: 32,175
Think about what it will be like shooting with two different cameras.  While they are in the same family, there are subtle yet important differences in the controls positions and also settings that can cause errors when you are in a hurry.  You will also need different batteries and charges meaning more  to bring with you on an outing and when you travel.  I vote a second X-T5.
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
al404
OP al404 Contributing Member • Posts: 827
Button layout it is basically the same
For RAW without editing I mean the colors of the same photo taken with AWB or fixed WB with same shutter speed / ISO and so on
I just found a deal on a X-T3 and pulled the trigger, I will compare it with X-T2 and decide who is leaving
With what color profile? Even the same profile (Provia/Standard for example) can produce slightly different color with different cameras at default settings - the X-T2 might look better with one and the X -T3 with another. I don’t tend to use the standard profiles but, with them, I tend to prefer the X-T2 for skin tones in Lightroom/ACR, with the X-T3 sometimes being a bit yellow/green in comparison.
al404
I did try with flat and standard
LDJS Photography Contributing Member • Posts: 711
For me it would simply depend on AF needs and video.
For commercial video obviously go for the T3 if you have the editing gear and demand for video work. For AF I guess the T3 will be better in continuous high shooting.
Otherwise for single shot (how I shoot) It would for me just be a matter of condition, shutter count and price. If the new one handles as well or better and the price difference wasn't much, no reason not to go for it. If on a budget and video and high speed AF (the T2 is no slouch the reviews it got on release are still real now) not a concern you go with your wallet
In my country the difference for mint condition used low shutter count and boxed is £499 for the T2 VS £699 for the T3. For my needs (street, travel, doc, some events) I'd get the T2. If I was shooting commercial sports or wildlife I'd get the T3 for the better AF or the T5 simply for the IBIS.
It really boils down to AF and Video T2 4k 30p / T3 4k 60p....
Not a real lot in it.
Image quality seems the same - Fujifilm X-T3 Review: Digital Photography Review (dpreview.com)
Buffer may be better?  AF works in -3ev could be useful.  Yeah for me if commercial T3, if not T2.  Simples.
wy2lam Veteran Member • Posts: 3,364
I've had both at one point.
X-T3: AF is quite a bit better if you do any tracking, allows ES-preshot, higher FPS, longer battery life, more customizable controls if you configure the swipes.  Locked diopter knob.  Doesn't need battery grip to access all boost mode features.
X-T2: very marginally smaller and lighter.  Cheaper.
Some like the command dials on the X-T2 better.  I like the X-T3's clickier dials.  I found the X-T2 dials easily clicked by accident unless I made an effort to scroll gently.
IQ is practically identical.  EVF feels identical even if the X-T3's has more dots.
X-T3's shutter count on the EXIF files are actually meaningful, unlike that on the X-T2.
Unless you can find one for *cheap*, there's no reason at all to pick the X-T2.
 wy2lam's gear list:wy2lam's gear list
Fujifilm FinePix HS35EXR Fujifilm X-E2 Fujifilm X-T1 Fujifilm X-T3 Fujifilm XF 35mm F1.4 R +9 more
Felice62 Veteran Member • Posts: 5,072
Can only spend a few comments on the x-t3, which is a very nice cam. Built as tank. The t3 has a very likeable EVF.
If we follow the idea that any new product brings some improvements (t4 - t5...) Than the x-t3 must be an overall better cam than the x-t2.
For some reason (probably due to the existing fan base) second hand street price seems even to be in favour of the x-t3, though this is not a deciding factor for you.
If only closed minds came with closed mouths..
 Felice62's gear list:Felice62's gear list
Olympus Stylus 1 Olympus Stylus Tough TG-850 iHS Olympus Tough TG-3 Panasonic ZS100 Olympus OM-D E-M5 +36 more
craigwell47 Senior Member • Posts: 1,197
My FUJI X-T3 made in PRC Cost 1.500 euros in March 2019. My FUJI X-T2 Graphite made in Japan. Cost 1.900 euros in June 2017. Prefer FUJI X-T2 with no demands on AF. My FUJI X-T2 the only reason staying with Fuji plus Fuji 16mm f1,4 lens. Both Fuji XT cameras with Fuji L-bracket for balance.
NOTE: Fuji X-T3 at 539g / Fuji X-T2 at 507g with batteries.
al404
Got X-T3 and it seems to me that WB it is cooler shifting -1 blu seems to match X-T2
Also not sure but using the same lens images seems less sharp on X-T3 vs X-T2
