R7 occasionally bricks
Started 1 month ago | Discussions
SteveinLouisville
SteveinLouisville Senior Member • Posts: 1,586
When it bricks, taking the battery, then putting it back in brings it back to life. Happens maybe once every couple of weeks. Anybody experience anything similar?
 SteveinLouisville's gear list:SteveinLouisville's gear list
Canon EOS RP Canon EOS R7 Canon EF 17-40mm f/4.0L USM Canon EF 40mm f/2.8 STM Canon EF-S 24mm F2.8 STM +9 more
Canon EOS R7
rmexpress22 Senior Member • Posts: 2,304
Re: R7 occasionally bricks
This happened with my R5 when I used it with an old battery and a Viltrox EF adapter. I never bothered to figure out which one was the problem but no issues with OEM adapter and battery.
 rmexpress22's gear list:rmexpress22's gear list
Canon EOS 5D Mark IV Canon EOS M6 Canon EF-M 22mm f/2 STM Sigma 85mm F1.4 Art Canon PowerShot G16 +20 more
SteveinLouisville
OP SteveinLouisville Senior Member • Posts: 1,586
Battery today was the OEM that came with the camera.
bodeswell Senior Member • Posts: 1,378
Hasn’t happened to me … yet. I have been using my R7 pretty steadily since I got it last summer. Do you do a lot of button reprogramming?
 bodeswell's gear list:bodeswell's gear list
Canon EOS R Canon EOS R5 Canon EOS R7 Canon EF 135mm F2L USM Canon EF 200mm f/2.8L II USM +4 more
John Photo Senior Member • Posts: 1,371
It hasn't happened to me (I'm still running the same firmware it came with 8 months ago).
SteveinLouisville
I have the exposure lock button set up as the silent shutter toggle on/off, but that's it. The camera has the latest firmware too.
Ok, that’s one more button change than I made. I have the latest firmware too. I don’t use the full electronic shutter.
BirdShooter7 Veteran Member • Posts: 9,127
Yes I occasionally have similar lockups. Maybe once every four or five days of use. Using OEM adapter and has also happened with RF lens mounted. Happened with OEM battery and Neweer battery. Has happened with multiple SD cards including Sony Tough v90, Sandisk Exterme Pro v90 and several other cards. Firmware is latest. No buttons reprogrammed.  Thankfully it doesn’t happen very frequently. I have had similar lockups with the R5, also very infrequent.
Some of my bird photos can be viewed here: https://www.flickr.com/photos/gregsbirds/
Frank I Reiter
Frank I Reiter Regular Member • Posts: 158
Locking up would be a better way to describe that.  Bricking means your hardware is no longer usable.
Frank.
 Frank I Reiter's gear list:Frank I Reiter's gear list
Canon EOS R7 Canon EF-S 18-135mm F3.5-5.6 IS USM Sigma 70mm F2.8 DG Macro Art Canon RF 24-105mm F4L IS USM Sigma 40mm F1.4 DG HSM +1 more
Adam2 Veteran Member • Posts: 7,615
Never encountered a single hiccup.  What lenses?  EF vs. RF?  What adapter if any?  My 100-500 lives on this camera and I've shot well north of 10k images without a pause and my R7 is highly customized in terms of buttons.
gipper51 Veteran Member • Posts: 5,901
Are you using a USH-II memory card? If so I'd suggest trying a different memory card (even UHS-I speed) and see what happens. For me personally, I've had terrible luck with so far with UHS-II cards. 2 years ago I got the R5 and a Sony Tough UHS-II card, and the camera had frequent card errors that caused several lockups. I abandoned the Sony and went with a Sandisk UHS-1 Extreme Pro and issues went away.
The R5 was sold long ago, but fast forward to today and I had another bizarre issue with a Kinston UHS-II card on the R6II. I won't elaborate on the "weirdness" here (it never locked up, but had other problems), but the card was the cause and I exchanged it. I'm now using a Lexar 1800x UHS-II card and so far it seems OK.
I don't know if I've just been unlucky or there's still some teething problems with UHS-II cards and compatibility with Canon? I've had more media card issues with UHS-II in the last 2 years than in all the previous 20 years of shooting digital combined.
 gipper51's gear list:gipper51's gear list
Canon EOS 5DS Panasonic Lumix DMC-GX85 Canon EOS R6 Mark II Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM +20 more
Bramble9 Regular Member • Posts: 211
My R7 occasionally gives me an "ERR 80, shut down camera or drop battery " message and there is no going on until I do that.  So, I just do it, the camera starts, and I go on shooting.  I don't know what causes it-- I use Lexar Pro cards, or Sandisk Pro but I don't think it has to do with the card.  Lately I've just been using the 100-500L and it does it with that lens too.  This doesn't happen very often-- Sort of a mystery to me too.
Bramble9
 Bramble9's gear list:Bramble9's gear list
Canon EOS R5 Canon EOS R7 Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 14-35mm F4L IS USM +1 more
I have a UHS-2 Lexar Pro in my R7. No problems yet.
SteveinLouisville
I was using the RF-S 18-150 when the freeze occurred.
