I'm On a Mission and Need Lens Suggestion(s)
BondTrader
BondTrader Regular Member • Posts: 124
Returning once again to Costa Rica.  Have photographed much wildlife there over the years.
This next trip (in May) I will be on a specific mission to find and photograph a Margay.  Unlike Ocelots of which both are similar, Margays are Arboreal and mostly live in trees in dense rain forest.  That means Low Light.
I'll have my Canon R6 with me.  Last year I bought the new Canon RF 100-500mm which I love.  I still also have my 100-400mm Ver. II.
I worry a bit about whether the RF 100-500mm will perform the best for me in these low light conditions, especially if I'm zoomed to 500mm.
Is there a better alternative that I might consider renting that would enhance the prospects for a better photograph given what I've described?
Thank You.
 BondTrader's gear list:BondTrader's gear list
Canon 6D Mark II Canon EOS R6 Canon EF 70-200mm f/2.8L IS USM Canon EF 100mm F2.8L Macro IS USM Tokina AT-X Pro 11-16mm f/2.8 DX +5 more
Canon EOS R6
quokka Regular Member • Posts: 250
Re: I'm On a Mission and Need Lens Suggestion(s)
The Canon 200-400mm f/4 would get you an additional stop of light but at the expense of a lot of weight (and rental fees).  I think the 100-500mm will be hard to beat.
Q
 quokka's gear list:quokka's gear list
Canon EOS 6D Canon EOS Rebel SL1 Canon EOS 7D Mark II Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM +9 more
CameraCarl Veteran Member • Posts: 9,204
Any of the super telephoto lenses ought to be ideal. Maybe a 300 mm f/2.8 with a 1.4x converter or a 500mm f4.
John Crowe
John Crowe Veteran Member • Posts: 3,476
Buy a used EF 500 L prime.
I would buy one of the several used EF 500mm L primes.  If you choose not to keep it, sell it for not much loss.  There are no other zooms worth considering.  The two lightweight RF primes are horribly slow, with not great resolution.  The 400/2.8 and 600/4 are extremely heavy and big.
Canon EOS 5DS R Canon EF 70-200mm F4L USM Canon TS-E 17mm f/4L Kenko Teleplus Pro 300 AF 1.4x Venus Laowa 12mm F2.8 Zero-D +15 more
SG2014 Forum Member • Posts: 84
This video is a little dated, but it might be helpful.
https://www.youtube.com/watch?v=Ssd-gzMrBA8
MarshallG
MarshallG Veteran Member • Posts: 8,968
Re: Buy a used EF 500 L prime.
LensRentals charges $400 to rent one of those for a week... so buying a used and reselling is probably less expensive.
 MarshallG's gear list:MarshallG's gear list
Canon EOS R5 Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF 16-35mm F2.8L II USM Canon Extender EF 1.4x II +4 more
Dave
Dave Veteran Member • Posts: 6,231
How high an ISO can you comfortably use with the R6?  And will you have opportunities to shoot stationary cats using low shutter speeds?  The camera's and lens's stabilization will be your allies there.  I recommend evaluating the lenses you're considering by shooting objects in shade trees near where you live.  Good luck and have a great trip.
 Dave's gear list:Dave's gear list
Canon EOS 80D Canon EF 135mm F2L USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-300mm f/4-5.6L IS USM +10 more
