Viltrox 13mm for astro, done better? And quite possibly a thumbs up
2 months ago
In the thread below, I did tests, posted results, and I think I was wrong :-P. I hate doing tests like this, so bear with me; I'm not a shoot pictures of a brick wall type usually.
https://www.dpreview.com/forums/post/66883085
If you don't want to read any further, I have come to the conclusion that at f2.8, the Viltrox 13 mm that I have may well be the best choice for astro over my other lenses.
I lucked into some lack of cloud cover last night (Pacific Northwest) and did some more tests, and came to different conclusions **based on the lenses I have**, YMMV.
To make a long story short, I have with me at present: Laowa 9mm f2.8, Rokinon 12mmf2 (and a Samyang copy as well), Fuji 14mm f2.8, Samyang 14mm f2.8 (FF lens), Fuji 16mm f2.8. X-T5 is the camera.
After trying different things, I decided to be a bit more thorough, aim the camera at the same portion of the sky (my last test, I had to move around due to clouds), and try each lens at f2 if available, f2.8, and f4. 13 seconds exposure which it turns out may be too long for best results across the board, but it worked for these tests.
What I reported as field curvature issues on the Viltrox 13 was actually star movement in the corners which appeared to be radiating in towards the center simply because I was pointed mostly eastward and up some.
I ended up focusing on f2.8 as the sweet spot simply because f2 showed poor results in the corners on all my options.
However, I accidentally shot the Viltrox at f2.5, and it did okay there, so I will have to see where it actually breaks down. F2 was not good in the corners.
Other things I have noticed is that the Fuji 16 f2.8, and that Laowa 9mm both do reasonably well at f4 (images not included) as does the Rokinon 12., and in a pinch might be okay for some work at f2.8. The Laowa has fierce vignetting as is known. My Fuji 14, sadly, shows coma even at f4.
Prior to this, I was using an X-T3, so I think the greater resolution may be showing some of the weaknesses of some lenses like the Rokinon 12.
Here are the boring pics, full size if you want to peep them. 50% JPG to reduce the size:
Laowa 9
Rokinon 12
Viltrox 13
Fuji 14
Samyang 14 f2.8
Fuji 16 f2.8
X-T5, X-T3, IR converted X-T20
Lenses: Too many
You keep using that word; I do not think it means what you think it
means -- Inigo Montoya, The Princess Bride
