Lens recommendations for Alaska Cruisetour
Started 2 months ago | Questions
Mahin Regular Member • Posts: 107
Hello everyone,
I’ve got a trip to Alaska coming up end of July. It’s probably going to be a once-in-a-lifetime trip for me. I would like to lean on the collective knowledge and experience of this forum on what kit I should take with me.
The trip will include:
  • a few days in Vancouver
  • 4d in Denali Park
  • 7d cruising through glaciers with stops at Skagway, Juneau and Ketchikan
I currently own the following kit:
  • Canon R6
  • 17-40 f4L
  • 24-70 f4L IS
  • 70-300 f4-5.6 IS
  • 100 f2.8 macro IS
  • 135 f2
  • x1.4 converter
As you can no doubt tell, I use these all with the EF-RF adapter. From what I’ve read, I’m thinking of taking the following, though I’m hesitant to use the x1.4:
  • EF 17-40 f4L
  • EF 24-70 f4L IS
  • EF 70-300 f4-5.6 IS
  • EF x1.4 converter
I was wondering if renting the RF 100-500 would be a better option than the 70-300, but would it be worth the £400+ cost.
Another lens that might be an option is the RF 24-240mm, but I’ll still have a gap at the wide and tele ends, so whilst it might be a good travel lens, I’m not sure it’s for this trip.
Thank you in advance for your help. I look forward to seeing what suggestions come.
 Mahin's gear list:Mahin's gear list
Canon EOS R6 Canon EF 135mm F2L USM Canon EF 17-40mm f/4.0L USM Canon EF 100mm F2.8L Macro IS USM Canon Extender EF 1.4x II +2 more
Canon EOS R6
CameraCarl Veteran Member • Posts: 9,204
Re: Lens recommendations for Alaska Cruisetour
You've got the wide end covered,  but will find 300mm way too short for any wildlife images or photos of the shore (or glaciers or whales) from the deck of the ship. The last time I was in Alaska well over 50% of my images were taken with a 100-400 zoom, and many of those with a 1.4x converter attached.  Rent or buy whatever you can afford, but you need at least 400, but far better would be 500mm -- or more. I would advise, however, against the 800mm f11. Unless you have several days to learn how to use the lens before you leave on the cruise, you may get disappointing results. I borrowed one for a few hundred bird images and found it was challenging to locate my subject in the viewfinder and even harder to get keep it there and to get sharp images hand held. My ideal Alaska set up would be to cover the range of 14-16mm on the wide end to 500mm on the long end, with a 1.4x converter for extra reach when needed. And I would do this with the minimal number of lenses possible.
OP Mahin Regular Member • Posts: 107
Thanks! It's good to know that the 300mm is not enough - helps to take it out of the equation.
I fully agree on keeping the number of lenses to the minimum
Actually, another lens that I've come across that might be an option is the Sigma 150-600mm f/5-6.3 DG OS HSM Contemporary. It's 100mm shorter than the RF100-500, but if it means I don't have to also use a x1.4 as well, then that feels like a win.
https://mdesilva.myportfolio.com
John Crowe
John Crowe Veteran Member • Posts: 3,476
Canon EF 400mm f5.6 L.
I will assume the 70-300 is not the L.
For not much more than that rental you could buy a used EF 400/5.6 L. It would work extremely well with your 1.4x and is easy to handhold. In a pinch the R6 would probably AF well with it and an EF 2x very well.
The 400/5.6 is very close in IQ to the RF 100-500, and you already have a bunch of zooms.
Canon EOS 5DS R Canon EF 70-200mm F4L USM Canon TS-E 17mm f/4L Kenko Teleplus Pro 300 AF 1.4x Venus Laowa 12mm F2.8 Zero-D +15 more
Re: Canon EF 400mm f5.6 L.
Ah, my mistake! It is the L lens, though I don't think that changes your view on the 400mm. I've updated my gear list (didn't realise that was a thing).
Thanks for the suggestion. The concern I have with primes is fixed range. There's only so much zooming out I can do with my feet on a ship  That and the lack of IS.
John Crowe
There is nothing wrong learning how to change lenses on the fly. You already have an excellent zoom, so why add another. When you see a whale that your zoom simply cannot reach, you switch out for the 400 and 1.4x. It takes less than one minute, depending on size of lenses.
You could put a Kenko 1.4x on your zoom, but I can tell you from experience that they are not nearly as good as any of Canon's.
People continually over estimate what IS can do, and you already have IBIS. Neither will help with yaw and roll of a ship, or the breaching whale.
You will be surprised by what a good affordable prime can do. When you have primes you just learn how to manage your photographing experience.
Have an awesome trip!
P.S. Your lens selection seems to cover everything.  I don't think your EF 1.4x can be used on any of them though.
I'm not sure how often you have tried to photograph whales in the wild, but my experience on four whale watching trips, two of which were on boats I chartered, is that I barely have time to locate, zoom in or out to frame the whale and then make an image before the whale disappears. I would have thousands of great whale images if they stayed around for the "less than a minute" it takes to change a lens. Unfortunately most of my whale encounters lasted for a few seconds. If I were to spot a whale far enough out that required changing lenses, that whale is sure to have been long gone before I make the switch. Plus I would never try to change lenses out on the deck of a boat in the wind and spray that one encounters in typical conditions.,
John Crowe
I suppose there are different situations. I know one can go on small boat type tours, where they approach the whales, which I would assume means that even a 70-300 would be sufficient. No, I would not want to be changing lenses in a small open boat at sea. Though I do it all the time on lakes. From a cruise ship, which I assume the whales stay well away from, a much longer lens, probably beyond typical zooms, may be required? I am going by my few ocean ferry ships that I have been on, and not specifically for whale watching. Just curious.
P.S. Actually you pretty much said in your post what I have been saying. Sounds like zooms are getting zoomed to max, and still adding teleconverters. Seems to me a good duty zoom like the OP has combined with a long prime could still be ideal.
pixseal
pixseal Veteran Member • Posts: 4,061
  • EF 17-40 f4L
  • EF 24-70 f4L IS
  • EF x1.4 converter
I've been on a couple of Alaska land tours and many Inside Passage tours.  In Denali, the longer the better; 500mm might not be enough.  Will the 1.4X even work with your 70-300?
 pixseal's gear list:pixseal's gear list
Canon EOS R7 Canon EF-S 10-22mm F3.5-4.5 USM Canon EF 100mm F2.8L Macro IS USM Canon EF 500mm f/4.0L IS II USM Canon EF 100-400mm F4.5-5.6L IS II +14 more
Chesapeake Imagery
Chesapeake Imagery Contributing Member • Posts: 605
Mahin wrote:
Hello everyone,
I don't know anything about whale-watching trips, but I do know that if I was going on a "once-in-a-lifetime" trip, I wouldn't go with only one body. With two, you can have two lenses mounted for changing situations, and G_d forbid if one body breaks down, you have a spare.
 Chesapeake Imagery's gear list:Chesapeake Imagery's gear list
Canon EOS R5
Andy01 Veteran Member • Posts: 5,191
No, it won't. The EF 70-300L doesn't take a Canon TC, though I seem to remember that one can be fitted if the lens is zoomed out to almost 300mm. A Kenko TC may work, but the IQ is likely to be less than great.
 Andy01's gear list:Andy01's gear list
Canon EOS M5 Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM +5 more
pixseal
My suggestion for whale watching is something like a 70-300 zoom (full frame equivalent); you will not want to be changing lenses.  At 300mm it may be difficult to maintain a subject due the the rolling of the boat.  70mm might be required to capture close action, if that should occur.
70mm on an APS-C body (112mm FF equivalent), uncropped.
Chesapeake Imagery
Pixseal, you probably didn't mean to reply to me. The only thing I know about whales is Moby Dick was a book I read in high school!
Canon EOS R5
Yep, you are correct, it does not  Well, it does at 300mm, but it's obviously not designed to be compatible.
That's a good point! I'll have to bring my Canon 7D along for the ride.
Well, as it happens, that 70-300 range is exactly what I have at the moment. I do get the feeling from what I've read and said here, that it'll probably be a bit short at 300mm though
Mahin wrote:
Hello everyone,
  • 4d in Denali Park
  • Canon R6
  • 17-40 f4L
  • 24-70 f4L IS
  • 70-300 f4-5.6 IS
  • 100 f2.8 macro IS
  • 135 f2
  • x1.4 converter
  • EF 17-40 f4L
  • EF 24-70 f4L IS
  • EF x1.4 converter
Thanks everyone for your input thus far. Based on what's been said, I think I need to change my view on what to to take to be:
  • Canon R6
  • Canon 7D (backup + x1.6 crop)
  • EF 17-40 f4L
  • EF 24-70 f4L IS
  • EF 70-300 f4.5-5.6L IS OR <a zoom covering a better range>
  • <maybe a prime>
Given that I need/want lenses that could fit both bodies in an emergency, the RF 100-500 is out. T
The EF 100-400 f4.5-5.6L II is currently very high up the list. However, 70-300 on my 7D gives me an effective range of 112-480, so perhaps the dual camera setup removes the need for another lens altogether?
BirdShooter7 Veteran Member • Posts: 9,134
I’ve never done a cruise in Alaska but I have visited several places on your itinerary for photography and I definitely appreciated having 500mm handy. I’d rent the 100-500L. My guess is that and your 24-70 should cover things nicely.
Some of my bird photos can be viewed here: https://www.flickr.com/photos/gregsbirds/
Dave
Dave Veteran Member • Posts: 6,231
You can get by with 300mm, but you'll be much happier with more reach.
Practice on your local bird (even if they aren't eagles) before departing.
 Dave's gear list:Dave's gear list
Canon EOS 80D Canon EF 135mm F2L USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-300mm f/4-5.6L IS USM +10 more
The RF100-500 is out because I want to make sure the lenses I take will fit both bodies I have - namely, the R6 and 7D.
I'm contemplating between:
  • Sigma 60-600mm f4.5-6.3 DG OS HSM Sport
  • Sigma 150-600mm f5-6.3 DG OS HSM Contemporary
  • Tamron 150-600mm f5-6.3 VC USD G2
BTW - your photography of birds is fantastic...well done!
