R5: keeping EVF open
Started 1 month ago | Questions
Chuck6345 Regular Member • Posts: 220
Is it possible to keep the viewfinder of my R5 open all the time (ready to view and shoot); and if so, then will that hurt my sensor?
Canon EOS R5
Zeee Forum Pro • Posts: 25,627
Re: R5: keeping EVF open
Yes in the yellow menus you can program the sensor to do that and LCD for how long you want to to stay on. There are all type of options.
No, it won't hurt the sensor.
Don't Look Up.
 Zeee's gear list:Zeee's gear list
Canon EOS R7 Canon EOS R6 Mark II Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +1 more
drsnoopy Senior Member • Posts: 1,216
It won’t hurt the sensor, but it will use more battery power, and the camera will run a bit hotter, which may be an issue with low light/long exposure images.  Maybe neither of these are an issue for you.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
Leigh A. Wax Senior Member • Posts: 1,621
As Drsnoopy says, the EVF is very battery intensive, much more so than the LCD.
With my R5, provided the camera is powered ON, the EVF functions instantly when I bring my eye up to it, however, you would have to set Auto Power to Disable to prevent Start-up delay, and that would also use up battery power, but likely, not as much as continuous EVF.
Of course, with an external power source, or adequate spare batteries not a problem either way.
One other thing to consider is the start-up time from sleep, when touching the shutter button to wake the camera. I’ve found this is quicker if you put the camera in flight mode, i.e. both Bluetooth and Wireless are turned off. With quicker wake-up and eye activation of the EVF, you may find you don’t need to set the camera/EVF to always active.
I was doing a little experimenting last week. I set my power savings up like this. The LCD shuts off in 5 seconds but the viewfinder is not on because after you pull the camera away from your eye it flips to the LCD. The IS does not shut off but it does not use much power.
When I bring the camera back to my eye the EVF wakes up almost immediately. If you let the camera power down you need to press the shutter or menu to wake it up and there is a delay.
This is with my R7 but I'm sure the R5 has the same. You can keep the EVF on all of the time but it has the greatest drain on the battery. More than the LCD. Hope this helps.
I left this at the factory settings.
Don't Look Up.
Re: Forgot to say
Since I don't shoot video I mapped the movie button to put the camera to sleep but I'm sure there are other buttons available for that.
Don't Look Up.
