Meike MK320
Started 1 month ago | Discussions
Jason Yao New Member • Posts: 9
Meike MK320
I own a Meike MK320 with a Nikon DSLR D7500 body. I bought the Meike MK320 second hand and it says 'for lumix', can the TTL work with the Nikon? I tried the TTL but sadly didn't flash, although manual works.
Nikon D7500
Joseph S Wisniewski Forum Pro • Posts: 35,461
Sorry, no
Unfortunately, nothing about the two flash systems is compatible except (as you've already seen) the large trigger contact.
The data contact arrangements are different: Lumix has four data contacts below the main trigger, Nikon has a more robust system with two contacts above the main trigger and two below. The way the flashes signal "hey! I'm connected!" differs between the two systems, and the messages they send and the way they send them differs.
The term "mirrorless" is totally obsolete. It's time we call out EVIL for what it is. (Or, if you can't handle "Electronic Viewfinder Interchangeable Lens" then Frenchify it and call it "LIVE" for "Lens Interchangeable, Viewfinder Electronic" or "Viseur électronique").
Stanley Joseph Wisniewski 1932-2019.
Dad, so much of you is in me.
Christine Fleischer 1947-2014.
My soulmate. There are no other words.
Rahon Klavanian 1912-2008.
Armenian genocide survivor, amazing cook, scrabble master, and loving grandmother. You will be missed.
Ciao! Joseph
www.swissarmyfork.com
 Joseph S Wisniewski's gear list:Joseph S Wisniewski's gear list
Nikon D90 Nikon D2X Nikon D3 Nikon D100 Nikon Z7 +48 more
Richard Dutton Contributing Member • Posts: 572
Re: Meike MK320
I have a Meike Olympus TTL and as the previous poster  points out - the varoius TTL systems are not compatible,
Don't despair - I use mine in slave mode with Nikon TTL flashes sometimes and it is easy to set up and adjust.  Its very useful.
BUT - if you need a TTL main flash then it has to be Nikon compatible - either GODOX if you need multiple flashes or just something like a SB910 - very cheap now used - but very capable.
Bas Hamstra Senior Member • Posts: 2,069
Re: Meike MK320
I noticed per accident that my wireless trigger works with Canon as well as Olympus. It only has ONE contact somehow, the rest is plastic. You would think that if a wireless trigger can fire on both systems, why couldn't the MK320, beit in manual mode? Not that I have dared to try (I also have the MK320).
Bas
 Bas Hamstra's gear list:Bas Hamstra's gear list
Canon EOS 5D Canon EOS 6D Olympus OM-D E-M10 Olympus E-M1 II Canon EF 35mm F1.4L USM +11 more
