Touch Bar on EOS R
Started 1 month ago | Discussions
Perambulator
Perambulator Regular Member • Posts: 147
Touch Bar on EOS R
I just received my "back-up" shooter, the EOS R, with the R6 as primary.
I quite like the touch bar. I use it for ISO, since the ISO functionality using the m-fn button causes the histogram to disappear.
Do most users really find the touch bar to be that aberrant? I think it's clever.
Canon EOS R6
Arthur Stanley Jefferson Contributing Member • Posts: 809
Re: Touch Bar on EOS R
It’s like marmite….some love it, some hate it…there’s not many who are ambivalent
 Arthur Stanley Jefferson's gear list:Arthur Stanley Jefferson's gear list
Canon EOS 5D Mark III Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F4L IS USM +4 more
Canon_Guy
Canon_Guy Senior Member • Posts: 1,486
My experience with that weird thing fully consents with DPR's review findings:
At first blush, the M-Fn Bar seems a creative solution to adjusting a parameter with a wide range of values - AF Area modes, ISO values, or white balance presets. But it comes with three fatal flaws; it's imprecise, it's easily activated by accident, and it simply appears buggy in its operation.
The M-Fn Bar is a solution in search of a problem.
The first issue is perhaps the most damning. It's far too easy to swipe past your intended selection, necessitating a reverse swipe or some taps to get where you wanted to go. If you disable the swipe functionality and use the bar as two soft-touch buttons, you'll still be accidentally hitting the bar and changing the value all the time. You can enable a two-second 'touch to unlock' ability, or have the dedicated 'Lock' button prevent inputs when you don't want them, but that takes added time and misses the larger issue: In its current state, the M-Fn Bar is a solution in search of a problem.
Almost every staff member that's used the EOS R has ended up disabling the M-Fn Bar altogether. With the possible exception of silently controlling audio levels while recording (heavily cropped) 4K video, the M-Fn Bar basically accomplishes the same thing that a standard rear jog dial could accomplish, only in a less precise, less useful and more time-consuming fashion. It's the last control you'll want to deal with if you're trying to catch a fleeting moment
For me the M-Fn bar was the reason why not to buy R, keep the 5D mk III and wait for the R6 to come.
 Canon_Guy's gear list:Canon_Guy's gear list
Canon EOS R6 Canon EF 70-200mm F2.8L IS II USM Sigma 14-24mm F2.8 DG HSM Art Sigma 105mm F1.4 DG HSM Art Canon RF 24-105mm F4L IS USM +6 more
Sittatunga Veteran Member • Posts: 5,406
I use it as a viewfinder control since that can't affect exposure settings and lets me leave it unlocked and undelayed with no worries about accidents.  I'm usually in Fv mode where the exposure compensation and ISO controls are very quick to find anyway and was never a fan of Canon's DSLR joysticks.
DannH Contributing Member • Posts: 640
I don’t get all the hate towards it. I’d probably of preferred a joystick but still find it really useful.
I use the ef adapter for changing my iso. The main function I use the Touch Bar for is too quickly switch between eye af and single point af.
Perambulator
OP Perambulator Regular Member • Posts: 147
I’m taking the R out on a shoot tomorrow so I’ll put it to the test. So far it’s working just fine, and I don’t find the small lag in activating it a problem. As far as how accurate/sensitive it is, I can see that as a potential problem.
davel33 Senior Member • Posts: 2,974
I think it depends on the weather, yea I really do .  Its a capacitive sensor and moisture has a large effect on it.  I have mine set for ISO with the left button set to 100 iso and the right button set for auto ISO.  Sometimes it sorta works and  sometimes it does not work at all and it changes with the seasons
I have not used it for months but after reading this thread I gave it a try and guess what, NOTHING.  what's new?
"Just one more Lens, I promise....."
Dave
 davel33's gear list:davel33's gear list
Canon EOS R Canon EOS R6 Canon RF 35mm F1.8 IS STM Macro Canon RF 24-240mm F4-6.3 Canon RF 85mm F2 Macro IS STM +29 more
drsnoopy Senior Member • Posts: 1,216
An extra dial would have been more useful. I do find it annoying that Canon keep experimenting with different ergonomic layouts.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
Canon_Guy
They also very quickly resigned from that weird touch bar. It also speaks for itself.
Personally I find the three on body dials + joystick as the best combination for fast and reliable (gloves included) operation of time, aperture, ISO and AF points.
It's a control I use almost every time I take the camera out. I could adapt to an extra dial, but it's not useless, it's unique, so I needed to learn how to use it.
That's innovation for you, something manufacturers are damned for not doing.  They can stop doing that when they have perfected mirrorless camera controls.  I don't think anybody's there yet.
That’s a fair point about innovation.  But when you have two or more bodies to work with, it can cause problems.  The R’s touch bar and the R7’s rear wheel are sufficiently unusual to make one wonder how extensively they trialled the ergonomics before release.
The manufacturers would like to tell you to buy duplicate bodies.
I've handled the R7 for perhaps 5 minutes, but I think the rear wheel is fantastic. After 35 years, a rear wheel with a central button that I can use without changing my grip.
Perambulator
I can't argue with that.
JConrad Regular Member • Posts: 318
5
I think it's the single worst camera interface control ever put on a camera.  It's horrid.  First, it's finicky as heck, and when using it with ISO, it is difficult to switch between auto ISO and selected ISOs. The 'lock' function on it is just hit or miss.  It can't be used with gloves, and there is no tactile feedback at all.  Also, it takes up space that should have been used for a focus joystick.  I was relieved when Canon abandoned it for all future models.
 JConrad's gear list:JConrad's gear list
Canon EOS R5 Canon RF 24-105mm F4L IS USM Canon RF 70-200mm F2.8L IS USM Fujifilm X100V Canon EOS RP +9 more
Perambulator
So, you're saying you don't like it?
It's very useful with one end toggling the histogram, the other toggling the level and the swipe controlling viewfinder magnification. I wish I could do that with my other cameras, but yes, it would be wasted as a horrible ISO control. It's impossible to switch between a selected ISO and auto ISO anyway if the metering is switched on. The R has better controls for ISO already.
GammyKnee Contributing Member • Posts: 985
I really wanted to like the bar, but every time I've put a critical setting on it, I've ended up regretting it. The problem for me is that without the lock it's too sensitive and gets unintentionally  nudged all the time, while the lock seems temperamental to put it mildly.
Now, about the only thing I trust it with is the level meter, but even then it manages to annoy me sometimes.
Bottom line for me: the bar was an interesting idea but I just don't find it to be practical.
 GammyKnee's gear list:GammyKnee's gear list
Canon EOS R Canon EOS R6 Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM Canon EF 17-40mm f/4.0L USM +4 more
ilikeit13
ilikeit13 Junior Member • Posts: 26
I actually like it, I use it to switch quickly from single-point AF to eye AF (with a swipe). Then, one side toggles the level, the other toggles the histogram, and I think that's super helpful instead of toggling through viewfinder modes - I just have the right amount of information when I need it.
I've tried other settings, but it's too sensitive for exposure settings.
RDKirk Forum Pro • Posts: 16,545
To make everything better....
Whatever use you find for the touch bar, it makes everything better to turn off the touchbar's own lock and set the top panel lock button to lock only the touch bar. That button is precise and operates instantly.
RDKirk
'TANSTAAFL: The only unbreakable rule in photography.'
 RDKirk's gear list:RDKirk's gear list
Canon EOS 5D Mark II Canon EOS 70D Canon EOS 5DS R Canon EOS 80D Canon EF 24mm f/2.8 +7 more
BPLOL Regular Member • Posts: 173
I use the touch bar to change WB, something that I will not use often. I leave ISO control to the EF/RF Control Adapter (bought the EOS R just to use EF glass).
However, I do think the touch bar really shines in image playback. VERY, VERY fast way to navigate to the picture you want it. Way better than an traditional dial. And you don't have to "unlock it" in playback mode.
Peace! Hakuna matata!
http://www.flickr.com/bplol
 BPLOL's gear list:BPLOL's gear list
Canon EOS 6D Canon EOS R Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF 17-40mm f/4.0L USM +5 more
