OP
ABCMO
Regular Member
Re: Astrophotography with the OM-1 and the Oly f/5.0-6.3 100-400mm
Bialykot wrote:
Thank you (and another great picture). Good to know the GTI can handle the 100-400 plus OM1 payload. I have a GTI tracker on order (and already have the OM1/100-400) but am completely new to Astrophotography, although keen to try. Auto guiding might be of interest at a future date if I take to the new hobby, but want to keep costs low for the moment. But you’ve certainly proved that the kit is capable of good results (in the right hands of course), so that’s very encouraging.
Thank you for commenting positively about the Pleiades image. Because you have a GTi on the way, I thought I should share a couple of things I have learned that might help you avoid some significant problems with it.
First, never, I repeat, never use a planet to perform any of the star alignments one performs for maximum accuracy before using the GOTO capability. I thought I had a defective unit because during the three-star alignment, on the second or third object, the GTi would slew and end up pointing the camera and lens toward the ground! I finally called my vendor, High Point Scientific, for techinical support, and the advisor I spoke with figured out what was causing my problem when I mentioned that I had been using Jupiter and Mars as objects in the star alignments. He told me never to do that, and that the problem wasn't limited to the GTi as it was a general problem with these kinds of equatorial mounts. He said the manuals don't say anything about this, but he has experience with several different mounts, and using planets for the alignment is trouble. Big trouble. I had used those two planets because they are so bright and would be easier to identify on the camera's back screen after the GTi would slew to them. The target object needs to be identified because although it may be in the frame, often it is necessary to use the SynScan software controls to place the object in the exact center of the frame. Sometimes the object will be almost exactly centered, but not always. So only use stars for star alignment even though the software will list Jupiter or Mars right now at the top of the list of available target options.
Second, and again the manual is silent on this point, the mount has two locations on the front for attaching the counterweight shaft that holds the 5.5-pound weight used to balance the camera-lens assembly. One location is for middle and fairly high latitudes and the other is for lower latitudes. What I discovered is that using the attachment point for the middle latitudes--I'm at 39 degrees north--the counterweight must be positioned so high on the shaft that it will come into contact with parts of the mount during slewing. The solution is to use the attachment point for lower latitudes. The counterweight must still be positioned high on the shaft, but it will be well out of the way and not come into contact with any part of the GTi during slewing. This is not just me suggesting this solution, but there are at least two video tutorials on YouTube that note this problem and recommend this solution, one of them being from High Point Scientific itself. The advisor I spoke with also endorsed this solution. This entire problem is caused because the OM-1 and 100-400 lens together form a relatively light combination, around 3.8 pounds. Even when I add a vixen dovetail plate and my guide scope and camera along with lens warmers, my total payload comes in around 5.6 or 5.7 pounds, and the GTI's maximum load is 11 pounds.
I hope these two recommendations will save you from having several fruitless nights under the stars. And good luck as you begin this journey.
Al
