"P" Mode defaults?
stevet1 Senior Member • Posts: 1,300
"P" Mode defaults?
I was reading comments from people who use the "P" Mode, or Program  mode on their camera.
Now, I myself don't ever use it, but I thought I'd experiment a little. It was a fairly bright day. It was a little hazy, but not too bad.
I metered the scene, and the camera selected f/5.6 and set an ss speed of 1/250.
I swung the camera around and selected another scene.  I got the same results: 5,6 and 1/250.
I put the camera in Av Mode and set the aperture at f/7.1.The camera dropped the shutter speed to 1/160, which is to be expected; but it got me thinking, does Canon choose f/5.6 as a default and go from there?
If it does, it seems like you'd be spending an awful lot of time tweaking the initial settings.
I personally do not like 5.6 very much. I'd rather choose a smaller aperture like 7.1 or f/8 for its depth of field or a wider aperture like f/2.8 to isolate a subject. I can see using 5.6 when taking a group photo and you want to get everyone in focus,  but I find f/5.6 gives me "soft" photos.
But, that's just me.
Any thoughts?
Steve Thomas
 stevet1's gear list:stevet1's gear list
Canon EOS Rebel T8i (EOS 850D) Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF 50mm F1.8 STM Canon EF-S 18-135mm F3.5-5.6 IS USM
Dunlin Senior Member • Posts: 2,611
Re: "P" Mode defaults?
For my first few months of shooting with a DSLR (the Canon 1200D), I didn't bother myself with focusing whatsoever. I just left it up to the camera. I also stayed in Auto mode.
Recently, looking back at those photos, I see that literally 90% (not exaggerating) of the photos were front-focused.  It wasn't just a focusing issue; the camera did generally choose f/5.6, which usually wasn't enough.
 Dunlin's gear list:Dunlin's gear list
Canon PowerShot SX410 IS Olympus OM-D E-M10 II Canon EF 35-80mm f/4.0-5.6 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Gimp +6 more
OP stevet1 Senior Member • Posts: 1,300
Dunlin,
About the one and only time I ever used the Auto setting, the camera chose f/5.6, and I've wondered about that ever since. It was also a bright, sunny day. It may be because 5.6 is a mid-range setting, and the camera starts from there.
Steve Thomas
Digirame Forum Pro • Posts: 41,857
I'll use F3.5 to F5.6 mostly only when I have a very short focal length. Some of my street photos taken at night were like that. During the day, my default F-stop usually is F9. I'll increase or decrease it, depending on what I want to do.
guinness2
guinness2 Veteran Member • Posts: 4,617
Re: "P" Mode defaults?j
Any thoughts?
Steve Thomas
Hi,
the logic of P mode is “take the easy and safe way”, satisfy the most of situations and could differ between the camera models.
If it is not aligned with your needs, just use the Av (or Tv) mode.
Av is the most used by enthusiasts, not P.
Additionally , you omitted the other two parts of equation, ISO, chosen by P mode and the FL ( lens) you used.
 guinness2's gear list:guinness2's gear list
Canon EOS Rebel SL3
guinness2 wrote:
Hi,
guinness2,
You're right.
I think 5.6 is an average setting for an average scene.
I just looked at a couple of other scenarios in P Mode:
Pointing the camera at a black curtain using evaluative metering, the camera brought in a setting of f/4. Pointing it at a white cloud brought up a setting of f/10.
Pointing it at the horizon, which brought in a lot of the sky, but some of the ground too, the camera set an aperture of f/7.1.
I was using a 55-250mm lens that runs from f/4 - f/5.6.
So, again, I think 5.6 is an average setting for an average scene when using evaluative metering.
Thanks.
Steve Thomas
guinness2
stevet1 wrote:
guinness2 wrote:
Hi,
guinness2,
You're right.
Thanks.
Steve Thomas
Well, I think it’s a bit different. The P mode has some logic behind, but not this one. It can differ on various models.
It tries the lowest f-stop it can  and  when  in risk of overexposure, it stops the lens down.
By using this particular lens , f/4  (f-stop) corresponds to the maximum aperture at 55 mm , respectively f/5.6 at 250 mm.
Canon EOS Rebel SL3
guinness2
Hi Dunlin, few clarifications, if you don’t mind.
Focusing in “Auto” mode , or better, the automatic choice of the focusing point used makes, that camera uses the focusing point which is aiming to the closest subject in the scene. So it focuses on the shape most in the front.
The term “Front-focusing “ is used when the focusing system has a systematic frontal deviation from the point it should be in focus. It is just a discrepancy between the body and the particular piece of lens, some more advanced cameras allow to correct it in settings.
None of these has anything to do with f/5.6 at all.
Canon EOS Rebel SL3
Cheapo Marx
Cheapo Marx Senior Member • Posts: 2,544
How are Results with Your Prime Lens?
Are your P mode shots typically sharper with your 50/1.8 than with your zooms?
Personally, I won't shoot my zooms wider than f/8 but my primes are sharp beginning at f/2.8 (I never shoot them wide open if I can help it). Using my zooms often means popping some flash.
Without flash, P mode is fine with primes but mush with zooms because the camera tries to keep a hand-holdable shutter speed thus requiring the zoom's wider apertures.
I know that now. Little did I know then.
Of course, you are correct. Thanks for pointing out my error.
guinness2
Hope I helped
Canon EOS Rebel SL3
