Quintesential M43 lenses
Mark N Contributing Member • Posts: 529
Re: Quintesential M43 lenses
Just bought into the m4/3 universe. Got an E-M5 ii and a Panasonic GM5 for a companion pocket camera.
My more pedestrian/budget/starter lenses than most listed here:
What I have that I would not want to do without:
Pan 12-32 - so small, light, & flexible
Pan 14mm f/2.5, unless I could get a 1.7 or 1.4, though the 2.5 is nicely tiny on the GM5.
Pan 12-60 3.5-5.6EZ - flexible and weather sealed for use on the sealed EM-5 ii
Would like to have:
-Pan 20mm 1.7
-25mm 1.4
-Olympus 12-100 f/4
-either Pan or Oly 100-400mm 4-6.3/5-6.3 respectively since I like to shoot the moon & planets. (any advice which is better?)
Thanks, It's been a while.
Mark N
 Mark N's gear list:Mark N's gear list
Canon PowerShot SD800 IS Casio Exilim EX-S20 Fujifilm X20 Canon G1 X II Panasonic LX100 +11 more
gary0319
gary0319 Forum Pro • Posts: 10,540
The f/4’s
Over the last year, or so, I have replaced both my 12-40 f/2.8 and 40-150 f/2.8 with the f/4 versions and have realized that for my preferred shooting venues and camera (OM-5) the smaller and lighter lenses are a much better fit. I also have the 12-100 f/4 but that is sitting home most times and might be swapped for the 8-25 f/4.
I suspect that OMDS will eventually run out the clock on the f/2.8 lenses and f/4 zooms will be the standard, being complemented by the  faster primes.
 gary0319's gear list:gary0319's gear list
Olympus OM-D E-M10 IV OM-1 OM System OM-5 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ +7 more
A_Mist
A_Mist Contributing Member • Posts: 988
Definitely 12-100, for me it’s the essence of mft system.
 A_Mist's gear list:A_Mist's gear list
OM-1 Canon EOS R6 Mark II Olympus 12-100mm F4.0 Canon RF 50mm F1.2L USM Canon RF 24-105mm F4L IS USM +4 more
Isola Verde
Isola Verde Forum Pro • Posts: 10,640
thinkinginimages wrote:
Some 1st gen Panasonic 14-42's (H-FS014042) had unusually stiff zoom rings. I had one of them. It was very noticeable if you had a 14-45. Three years later Panasonic released the 14-42 II (H-FS1442A )to replace it.
Perhaps getting down to the last few now, but at least a couple of reliable retailers here in Britain claim to still have stock of the G7+14/42 bundle... priced at £449 - which is £80 less than that camera paired with the 12/60 kit lens.
Peter
 Isola Verde's gear list:Isola Verde's gear list
Olympus OM-D E-M10 IV Olympus PEN E-P7
Mark Thornton Veteran Member • Posts: 4,570
Re: The f/4’s
Though I have just acquired a second hand 35-100 f2.8 which seems quite useful. About the same size as the 40-150 f4 at its most compact, the 35-100 is internal zoom. I also realised that when I needed longer than 100mm, the 150mm of my 45-150 f4/5.6 was rarely sufficient. So I am tempted to add the 100-300 Panasonic.
Mark
 Mark Thornton's gear list:Mark Thornton's gear list
Panasonic Lumix DMC-GX1 Panasonic Lumix DC-GX9 Olympus Zuiko Digital 11-22mm 1:2.8-3.5 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +8 more
Larzac Forum Member • Posts: 60
Re: 17/1.2, 45/1.2, 40-150/2.8..
Sam Bennett wrote:
DailyPlanet wrote:
Sam Bennett wrote:
What are yours?
  1. 17/1.2 - My favorite "general purpose" prime. Superb optical quality, absolutely gorgeous bokeh wide-open (where I sit with it probably 95% of the time). Wide enough to get good "context" in environmental portraits while the DoF is shallow enough to help with a bit of separation.
Robin Wong, the youtuber and Olympus ambassador, says the Olympus 17mm f/1.2 lens gives the user a feathered bokeh that is creamy. That is a convincing endorsement.
I have a Panasonic Leica DG Summilux 25mm f/1.4 II ASPH that I'd like to pair with the above lens. Does this make sense, or should I budget for both the Olympus 17mm-f/1.2 and 25mm-f/1.2? This lens combo would have to work well in video recording applications, as well.
I've never used the 25/1.4, so I can't comment on that. But to be honest, I find the 25/1.2 underwhelming - it doesn't really have the "magic" that the 17/1.2 and 45/1.2 have. Apparently it's a simpler optical design, so it makes sense that it doesn't have quite the same qualities.
I never found the 25 1.2 to be not as good as the 45 and the 17. In my experience the trio is quite homogeneous and deliver equal results.
Thomas Kachadurian
OP Thomas Kachadurian Veteran Member • Posts: 3,734
NikonBiologist wrote:
I have the PL 25 1.4 but rarely use it and keep thinking I should sell it and get the 15 1.7. Seems well liked here!
Oh, and I really like my 12-100 and 300 f4. I'd probably replace the 300 first, though since my Olympus/OMDS gear is meant for wildlife in my kit.
I have both and the 15mm gets 10 times the use of the 25mm.
www.kachadurian.com
Call me crazy. I happen to like photos of cats.
 Thomas Kachadurian's gear list:Thomas Kachadurian's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica Summilux DG 25mm F1.4 +7 more
yardcoyote Forum Pro • Posts: 15,754
Olympus 25mm f/1.8 and Olympus 60mm f/2.8 macro.
Instagram: @yardcoyote
 yardcoyote's gear list:yardcoyote's gear list
Fujifilm X10 Fujifilm X100T Fujifilm X-Pro1 Pentax K-5 IIs Fujifilm X-M1 +20 more
JosephScha Veteran Member • Posts: 7,249
You wrote:
"Laowa 7.5mm f2
Panasonic Leica 15mm F1,7
Olympus 40-150mm f2.8
Eventually I'd fill in with others, but I could get by with just those.
What are yours?"
Pana Leica 9mm f/1.7
Pana Leica 15mm f/1.7  (I agree with you on this one)
Pana Leica 25mm f/1.4
Panasonic 42.5mm f/1.7 (amazing lens for it's price)
Panasonic 14-140mm zoom (for daylight shooting).
I also own the 60mm Sigma f/2.8 and the 100-300mm zoom, but I rarely use them.  I am sure I could get by with the 4 primes I listed and the 14-140 for just about everything.
js
 JosephScha's gear list:JosephScha's gear list
Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 +7 more
MOD Tom Caldwell Forum Pro • Posts: 46,360
Usual issues
5
The usual issues emerge from this sort of question - listings of things that we personally know.
Not that this is a bad thing but it is a bit like relying on testimonials for Dr Goodenough's Excellent Snake Oil.  Your are not going to know for sure until you try it and even then the results will still be debatable.
Tom Caldwell
mightygodking New Member • Posts: 3
Re: Usual issues
My list is relatively short - just the 12-100mm f4 and the Oly 14-42mm pancake zoom. The big one lives on my EM5 and the wee fella lives on my EPM2.
I have other lenses I quite like - the Oly 17mm f1.8 is my favorite of the Oly cheap-but-great primes, and I rely on my Panasonic 100-300mm for when I want to shoot birds. But both of those lenses are targets for upgrading, because in future I know I want to get the Panasonic 9mm f.17 and a better telephoto zoom, so they aren't "essentials."
 mightygodking's gear list:mightygodking's gear list
Olympus E-M5 III Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital 17mm F1.8 +3 more
unhappymeal Senior Member • Posts: 2,625
Big and expensive? ;).
A_Mist
Quite the opposite, for what it is.
12-100 has 24-200mm FL (FF equiv), constant f4 aperture, top-notch IQ and build quality, blazing fast AF, best-in-class weather sealing, sync-IS, MF clutch and fn-button. It also focuses to semi-macro territory.
Gyroscope
Gyroscope Junior Member • Posts: 32
I have the laowa 7.5 and 10 f2 lenses, the leica 15 f1.7 and the leica 25 f1.4. I love having these small fast primes and they all have 46mm filter threads to make it simple using a a Nisi 75mm filter holder. None are weathersealed unfortunately, the only downside but I have my S1r for bad weather shooting.
I find myself rather intrigued with the olymous 12-100 though. It seems to be held in universally high regard which is not necessarily a given for a lens witb such a large range. Might be an option for some travel I have in my future.
 Gyroscope's gear list:Gyroscope's gear list
Pentax 645Z Panasonic Lumix DC-G9 Panasonic Lumix DC-S1R Pentax smc D FA 645 55mm F2.8 AL (IF) SDM AW HD Pentax D FA 645 Macro 90mm F2.8 ED AW SR +7 more
glassoholic
glassoholic Veteran Member • Posts: 7,641
Re: Pl 9mm f/1.7 trust me
Oly 12-100 Pro, PL 8-18, PL 100-400, Oly 8mm FE Pro 1.8, Oly 60 macro and PL 15 1.7.
The rest is just adding options like faster aperture, alternative rendering or even more extreme focal lengths (Laowa 6mm, 2x converter with 300 Pro etc).
A second option: Pana 14-140, Oly 12-40 Pro, Oly 17 1.8 and BC 9mm f8.0 FE is a simpler, travel orientated outfit.
Addicted To Glass
M43 equivalence: "Twice the fun with half the weight"
"You are a long time dead" -
Credit to whoever said that first and my wife for saying it to me... Make the best you can of every day!
ahaslett
ahaslett Forum Pro • Posts: 12,662
Today there is a £175 cashback, so it's only £1,024. 561g seems reasonable for a decent super-zoom.
The obvious comparator would be the Tamron 28-200/2.8-5.6 which costs £799 (without discount), has a shorter range, captures more light, and weighs 18g more.
My impression is that both give pretty good IQ, at least owners rave about both of them. You get Dual IS with the Olympus, a lens Fn button, and a snap focus ring. Weathersealing is also a differentiator.
I'd pick the Panasonic 12-35/2.8 and 35-100/2.8 over either of them. IRL I have different kit again. We all make different choices for our own reasons.  Having options is good.
My MFT kit comes in at 3 sizes: tiny, small and smaller than my FF kit. I don't think MFT kit is especially cheap for its IQ and shooting envelope. You can get really good bargains on used MFT kit, if you want small, cheap and decent. Panasonic mk i lenses are especially attractive.
Andrew
Infinite are the arguments of mages. Truth is a jewel with many facets. Ursula K LeGuin
Please feel free to edit any images that I post
 ahaslett's gear list:ahaslett's gear list
Sigma DP1 Merrill Sigma DP3 Merrill Olympus E-M1 Sony a7R Panasonic Lumix DMC-GM1 +33 more
5
Some people love it, I'm not one of those people. Every time I buy this lens, my reaction is "But why?". Why would I pay the size, mass and cost penalty when it doesn't absolutely blow the 14-140 II out of the water, it doesn't get me a lot more aperture and it's not optically as good as the 12-40 f/2.8 or 12-60 f/2.8-4. Maybe someone can explain the magic to me, but this is the second time I've purchased the lens and I'm pretty cold to it. It doesn't help that the lens + OM-1 takes up almost my entire Peak Design 5 L sling.
Andrew
This is the second time I purchased the 12-100 and I'm shooting it beside the 14-140 II. I'm...not really impressed. Is it better? Yeah. Is it 500 € and 250+ grams better? Nope.
ahaslett
Andrew
I've been shooting my £90 40-150 R against my £924 40-150/2.8.  Did that extra £90 add value to my kit overall - absolutely.  Would I be happy only having the plastic fantastic - absolutely not.  Was the extra weight and cost of the Pro lens worth it over a good condition used 35-100/2.8 mk i - only just.
Andrew
thinkinginimages
thinkinginimages Senior Member • Posts: 2,495
I have the Panasonic 45-150, a nice little kit lens. Not extraordinary except for being ordinary. I call lenses like these "utility lenses".
If I used that range more often I might consider something "more". I'd miss this lens if I didn't have it, only because for the few times I need a little extra reach - it's there, gets the job done, then "naps" quietly in the cabinet until I need it again.
