Quintesential M43 lenses
grsnovi Veteran Member • Posts: 3,030
Re: Quintesential M43 lenses
I started my MFT with Lumix so my remaining 4 Panasonic MFT lenses are what I have. This week I took delivery of an OM-1 and at the moment I have the 12-35/2.8 mounted. My plan for the OM-1 is better birds and once I get things sorted I'll be using the PL 100-400.
I doubt that the 25/1.7 or the 30 macro will end up on the OM-1.
At some point I'll probably add some M.Zuiko glass.
- G
 grsnovi's gear list:grsnovi's gear list
Panasonic Lumix DMC-GX85 Sony SLT-A65 Sony a7R III Panasonic Lumix DC-GX9 OM-1 +11 more
kcdogger Veteran Member • Posts: 4,357
Ones I really like (and use a lot) - Oly 12-100 (a no brainer)
PL12-60
PL 50-200
Ply 40-150 f4
Pan 15
Sigma 56 f1.4
Oly 12-45
Not so much - Oly 40-150 f2.8 (Sharp, but big and heavy)
John
 kcdogger's gear list:kcdogger's gear list
Olympus TG-6 Panasonic ZS100 Olympus Stylus 1 Sony RX100 VII Panasonic Lumix DC-ZS80 +37 more
RSTP14 Veteran Member • Posts: 6,370
17mm/1.8
12-45mm/4
56mm/1.4
......  wait, these are all the M43 lenses I have although I might get the 17mm/1.2 instead of the 1.8 if money no object.
Roger
 RSTP14's gear list:RSTP14's gear list
OM-1 Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-45mm F4 Pro +4 more
Michael Benveniste
Michael Benveniste Veteran Member • Posts: 6,379
No Quintessential lenses here
To my mind, one of the great things about the M43 system is there is no quintessential or "must have" lenses. No matter what your subjective preferences are, it's likely you'll find one or more lenses that will be a "fit" for you.
I only have 5 M43 lenses. My favorite is one which hasn't been mentioned in this thread yet -- the Panasonic 8-18mm f/2.8~4. I'm a fan of ultra-wide-to-wide-normal lenses, and the 8-18mm is right in my sweet spot for speed, size, and optical performance. Is it Quintessential?  Hardly.  But it's the first lens I'd replace.
Light travels at 2.13085531 × 10^14 smoots per fortnight. Catch some today!
 Michael Benveniste's gear list:Michael Benveniste's gear list
Nikon Coolpix 995 Nikon D800 Nikon 1 V2 Panasonic Lumix DMC-GX85 Nikon D7200 +46 more
generationfourth Regular Member • Posts: 301
Pl 9mm f/1.7 trust me
8
Even if you have any of the other UWA m43 options, even if you don’t like UWA fov, like myself, the new 9mm embodies what m43 is all about. Great value and a ton of fun thrown on a small body. The ultra close focus distance + capturing the subject’s full environment + the option to blur the crap outta the background all creates very unique composition opportunities that I never even thought of.
aside from the 9mm I’ll add the usual suspects: 20 1.7, and 14-140. A truly underrated lens: p35-100 2.8
 generationfourth's gear list:generationfourth's gear list
Panasonic Lumix DMC-GF1 Olympus E-M1 III Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 Panasonic 12-35mm F2.8 +4 more
NowHearThis
NowHearThis Veteran Member • Posts: 4,616
Since 2017…
I’d say my PL12-60/2.8-4 and P42.5/1.7 have performed flawlessly.  Both are very sharp and great at what they are designed for.  The PL has a super wide area of pin sharpness and even borders I consider great.  The 42/1.7 is flawless from F2 and still very good wide open - Id consider it excellent and flattering for portraits wide open.
As an honorable mention and probably a surprise to some would be the Olympus 14-42 II R.  This feather weight kit lens, while lacking features of expensive glass, still produces great results optically. It’s likely the best $300 kit lens and the absolute best kit lens you can get for  body+$100.  It punches above its weight and is a nice companion to Pen/EM5/EM10 bodies.  I’m glad I still have access to an EM10+14-42 II R for when I want to go super light.
NHT
 NowHearThis's gear list:NowHearThis's gear list
Panasonic Leica 12-60mm F2.8-4.0 ASPH Olympus E-M1 III Panasonic Lumix G 42.5mm F1.7 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS
Dave in Wales
Dave in Wales Contributing Member • Posts: 901
PhotoMac503 wrote:
The Olympus 12-100 is the best lens I've ever used in any format.
Seconded.
bbbbbbbbbbb Senior Member • Posts: 2,239
Re: Olympus 25 mm f/1.8
Samuel Dilworth wrote:
The ones I’d go out and buy after a robbery might be slightly different than the ones I’d call universally quintessential.
I’ll tell you two lenses I did buy twice (after foolishly selling them rather than getting robbed):
  • 12–40 mm f/2.8
  • 30 mm f/3.5 mm macro.
The zoom I sold because I was confident I could replace it with the 12–45 mm f/4. That didn’t work out: the f/4 lens was not quite fast enough indoors or to create deliberate-looking out-of-focus blur with human-scale subjects at human-scale distances. Felt like the shooting window was ultimately a bit narrow on the 4/3″-type sensor.
The macro I sold because I thought I could duplicate its usefulness to me with other lenses (that didn’t work out either).
Another lens I regret selling but didn’t replace was the 25 mm f/1.8. What a gem that is. That would be on my universally quintessential list. It’s so good and so small and so nice to use.
Just curious as to why you repurchased the 30mm macro rather than the 60mm macro?
 bbbbbbbbbbb's gear list:bbbbbbbbbbb's gear list
Olympus E-M1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro Olympus M.Zuiko Digital 45mm F1.8 Olympus E-450 +8 more
alan scott Regular Member • Posts: 493
If I had to start from scratch I'd re-acquire in this order:
- 12 - 100
- 9/1.7
-15/1.7
- 42.5/1.7 chosen over the olympus because of the OIS on the GM5
- 60/2.8
I currently use two bodies; EM1 (iii) and a GM5.  The 12-100 practically lives on my EM1 and each of these primes works on either body.  The GM5 plus a prime will fit in my coat pocket.
Alan Scott
"Everything we hear is an opinion, not a fact. Everything we see is a perspective, not the truth" - Marcus Aurelius
 alan scott's gear list:alan scott's gear list
Panasonic Lumix DMC-GM5 Olympus E-M1 III Panasonic Lumix G 20mm F1.7 ASPH Panasonic 12-35mm F2.8 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +17 more
Samuel Dilworth
Samuel Dilworth Senior Member • Posts: 1,391
5
I have always liked short macros. Typically that’s been the second lens I buy for a system.
I don’t use these lenses to photograph live critters (working distance needed to avoid scaring them away) or flowers (narrow angle of view needed to exclude unwanted background).
I use them partly as a general purpose lens that can occasionally focus closely, for photographing objects like a small but not tiny bicycle part or a dessert plate or the texture of a surface.
In these cases the short focal length has the benefit of allowing me to adjust the position of the subject with one hand while looking through the camera to see the effect; a 60 mm would put me too far away, so I’d have to get up and guess what the adjustment looks like or at least stretch awkwardly while trying to look through the viewfinder (or rear screen).
I do also sometimes use them to photograph very small mechanical things like watch parts or the wear faces of a ball bearing or something like that.
Moreover, short macros are cheaper and smaller and lighter than long ones. The 30 mm f/3.5 is so extremely small and light that I can carry it around with me just in case I need it. That’s another nice benefit.
Hope that satisfies your curiosity (which is welcome!).
Wingsfan
Wingsfan Contributing Member • Posts: 686
Two, for my needs
In the end, it's these two lenses that comprise 99% of my photography....
Olympus 12-40f2.8
Olympus 40-150F2.8
I have 8 or 9 other lenses, including 3 other pro lenses, but these 2 pretty much take care of everything.  I've actually recently started not taking these lenses places, and using some of my other pro zooms and prime lenses, just to give myself a little bit more of a challenge if I'm casually shooting.
 Wingsfan's gear list:Wingsfan's gear list
Olympus XZ-1 Canon PowerShot G7 X Nikon Coolpix S9100 Nikon Coolpix 4100 Panasonic ZS100 +24 more
unhappymeal Senior Member • Posts: 2,625
Thomas Kachadurian wrote:
Everyone will have their own opinion on this, but as a guy firmly, and probably for the rest of my life in the M43 camp, there are a few lenses that never let me down. If I am unhappy with an image from these lenses, it's the light, the subject, or my talent, not the lens.
If someone robbed me of all my lenses (and I have more than 10), these are what I would buy the next day:
Laowa 7.5mm f2
Panasonic Leica 15mm F1,7
Olympus 40-150mm f2.8
Eventually I'd fill in with others, but I could get by with just those.
What are yours?
Tom
PL 200mm f/2.8
Olympus 75mm f/1.8
Olympus 60mm f/2.8
PL 9mm f/1.8
Panasonic 20mm f/1.7
I would probably add the 14-140 II or 12-100. I just purchased the 12-100 (again) to test it beside the 14-140 II. I never felt like the added mass was worth the IQ and wider FOV over the 14-140 II. Let’s see if having a body with Sync IS changes my mind this time around.
TorsteinH
TorsteinH Senior Member • Posts: 1,650
RSTP14 wrote:
17mm/1.8
12-45mm/4
56mm/1.4
Even if I just have been outside with my very old 50-200mm I would say that 12-40mm f2.8 , 17mm 1.8, 45mm f/1.8 and 40-150mm f/ 4- 5.6 are my go to lenses. Now I just miss a realy wide lens. ( and more money....😎)
Torstein
 TorsteinH's gear list:TorsteinH's gear list
Olympus E-M1 II Olympus M.Zuiko Digital 45mm F1.8 Olympus 12-40mm F2.8 Pro Panasonic Lumix G 25mm F1.7 ASPH Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +4 more
Mike Micro 43 Regular Member • Posts: 131
Mine would be:
Panasonic 20mm F/1.7
Samyang/Rokinon 7.5mm F/3.5
Panasonic 12-60mm F/3.5-5.6
Olympus 12-40mm F/2.8
Olympus 40-150mm F/4-5.6
Mike.
Sam Bennett
Sam Bennett Veteran Member • Posts: 4,955
17/1.2, 45/1.2, 40-150/2.8..
6
What are yours?
  1. 17/1.2 - My favorite "general purpose" prime. Superb optical quality, absolutely gorgeous bokeh wide-open (where I sit with it probably 95% of the time). Wide enough to get good "context" in environmental portraits while the DoF is shallow enough to help with a bit of separation.
  2. 45/1.2 - My favorite portrait lens ever. Like the 17, the rendering on this lens wide open is just stunning, and coupled with the "compression" that comes from using a longer focal length from further back, the results are even more impactful.
  3. 40-150/2.8 - This is the lens that "kept" me in the micro four thirds system. This really comes down to the versatility that it brings with the 80-300 equivalent focal length range at a constant f/2.8. No FF lens can match that coupled with it's incredible build, weather sealing and relative compactness. While not as "eye popping" as the other two lenses listed, it's optical quality is great as well!
Sam Bennett
Instagram: @swiftbennett
 Sam Bennett's gear list:Sam Bennett's gear list
Olympus E-M1 III Olympus PEN E-P7 Olympus 40-150mm F2.8 Pro Olympus 7-14mm F2.8 Pro Olympus 17mm F1.2 Pro +12 more
Promeneur Contributing Member • Posts: 624
thinkinginimages wrote:
No love for the Lumix 14-42 II? This little competent underdog gets taken for granted because it's a kit lens. I use it a lot and have no complaints.
I was not aware that the Lumix 14 - 42 II is still available new or bundled in a kit?
I rediscovered the Lumix 25 1.7 recently. I forgot the sharpness and smooth bokeh of this reasonably priced single focal length lens.
My experience is the same.  I need to get out and use it more.
Of course, the venerable Lumix 12-32.
I don't think people realize how long these lenses have been around. 8-10 years. Wow.
Gone but not forgotten: The 14-42 PZ (power zoom) X version. There's also the 45-175 PZ. I had the 14-42 PZ on a 1st gen Blackmagic Pocket Cine, a sweet, smooth zooming, portable combo.
I have the Lumix X Vario PZ 14 - 42mm and it is becoming a favorite.  It's not that much larger than the P12 - 32mm.  It has also been maligned due to past issues with shutter shock on some models when it came out.  I think the range also overlaps what a lot of people already have in their kit, it's a bit pricey, and I have never seen it go on sale.
imrryr3859
imrryr3859 Regular Member • Posts: 189
25MM 1.2 PRO
56MM 1.4 SIGGY
12/40 2.8 PRO
25&45 1.8
honorable mantin to the sweety 40/150 plastic fantastic
 imrryr3859's gear list:imrryr3859's gear list
Olympus 12-40mm F2.8 Pro Olympus OM-D E-M10 II Olympus E-M5 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +4 more
PL8 - 18mm.  It covers most of my travel needs.  It was my most used lens on a seven week trip in Tasmania.  It is weather sealed and does not trombone, so I would still be comfortable using it in all but the most torrential downpour on a none weather sealed camera body.
PL15mm.  For all the same reasons everyone else chooses this lens.
Lumix G X Vario PZ 14 -42mm.  It picks up when I need more reach.  Lumix cameras have a setting called "Power Zoom Lens" where you can set up "Step Zoom" and "Zoom Resume", and "Zoom Speed" for photo and video.  You can set it to 14, 18, 25, 35, & 42mm.  It's a nice feature that I have set up.  Great vacation lens or for walking around with my GX85.
PL50 - 200mm & 1.4TC.  Just a wonderful lens and so versitile!
thinkinginimages
thinkinginimages Senior Member • Posts: 2,495
The 14-42 II is still for sale.
I didn't use the PZ much for stills. I picked one up when I was testing the Blackmagic Pocket Cine. A power zoom and this video camera seemed like a great combo. (It was!)
https://shop.panasonic.com/cameras-and-camcorders/lumix-camera-lenses/micro-four-thirds-lenses
Strange, I'm not seeing it available on the Panasonic site? I'm looking at this lens, just in case. H-FS1442AKA  Out of stock on Amazon and the other vendor directs to an error on two different browsers.  Doesn't come up on B&H either.  That's why I think it might be discontinued now?
I read that the PZ seems to be geared more towards video.  I also have a hard time seeing a difference in IQ between it and my copy of the P12 - 32mm.
