davesurrey wrote:
Does anyone have first hand experience of using any of the many non-Canon adapters?
The Canon one does seems a lot more expensive than many of the non-Canon ones I see advertised.
But do they work as well eg AF, AE etc?
There were problems reported on this board by members trying out non-Canon adapters. This occurred at a time when Canon didn't seem to have any stock available quite a few years ago. I believe that one EF-EF-M adapter made by Viltrox was lightweight and did not fit tightly (it would rattle) and this caused an issue with contracts not connecting properly. The Canon version fits very snug. This is important because a loose fitting will allow heavier lenses to pull at the fitting, causing any gap to potentially widen.
EF-to-EF-M lens mount with the "foot" removed to streamline it.
Making use of the Adapter foot - which was fitted to a Manfrotto mini-tripod. You really don't want a heavy lens hanging off the front of any camera without some support.
Using the EF-to EF-M adapter to mount a folding Manfrotto Mini Tripod which was then used as a carry handle with some larger lenses.
Accessing the battery door on the M6 with the adapter foot - with the EF 24mm f/1.4L lens.
Some non-Canon versions don't have the tripod-foot included. Some older versions from Canon didn't include the tripod foot in the box either after Canon stopped supplying it for a while. The foot is removable but it is also useful with fitting mini-tripods or simply attaching larger lenses so the camera isn't just "hanging off the back" of the lens and that both lens and camera are uniquely supported by the adapter. That member with a Viltrox adapter said he replaced it eventually with a Canon version which apparently worked fine. I've also noticed issues where people used non-Canon RF-EF adapters on their EOS R cameras and found that the batteries would mysteriously drain overnight when using them. There may have been an EOS M user who experienced the same. Replacing the adapter with a Canon version resolved the issue.
The Canon EF-to-EF-M Mount Adapter - has a removable tripod mount "foot" on the bottom. This can be surprisingly useful. There's even another tripod mount underneath it when removed. Removing it can streamline the fitting but it can also be used to fit other accessories.
There were some reports of a non-Canon adapter causing problems with contacts not meeting one another. This resulted in AF problems for the user. This problem is common with a lot of the cheaply made versions where the contacts are poorly made. Internal reflections have been reported from some of the non-Canon versions where the interior wasn't baffled or matted enough to stop stray light reflections.
The Canon version (from memory) has a weather seal on one end which (when coupled with a sealed EF-L-series lens) should complete the weather seal. It also uses thicker coatings on the gold contacts which are sprung more tightly and are not as prone to "sticking" when lenses are fitted. If a contact isn't sprung tight enough, it sometimes wont push up against the contact on the lens and that results in failure to communicate with the body.
If you only have one or two lenses to adapt and they're quite lightweight, it may not really matter all that much if you use the Canon brand or not, although I'd personally pass on the Viltrox brand myself due to the lose fittings. But if you use heavier lenses with a lot of glass in them, or if you have a few different lenses that you might wish to use on your EOS M camera, then it's worth getting the Canon branded version simply because of the rigidity, solid construction and reliability.
