Canon R7, Ef 100-400 ii and 1.4 Tc Bif Photos. Are these acceptable?
Started 1 month ago | Questions
OlcayK
OlcayK Forum Member • Posts: 89
Hi,
I just got the EF 100-400 ii lens and the 1.4 tc mark iii. I was shooting with rf 100-400 but needed something weather sealed and this lens seemed to be the best option as I couldn't afford the rf 100-500.
So this is just the second day out with the combo. No birds around so trying it with some seagulls and just took these shots of the grey heron. Here I'm sharing some shots from a burst. How should I feel about these shots? Are these accaptable or should I expect more?
Thses are not edited, just cropped to %100 and exported as jpeg from lightroom. As you can see some are in focus some are not.
I use double bbf one for eye af and the other one is a spot af. I used eye af for taking the shots. f9, 1/1600, ISO 640-800. EFC shutter mode. H+. Case 2 with tracking set to -2.
So far, other than shooting some boring bif pictures I couldn't find anytihing to shoot. I dont want to regret my purchase. I really want to like the lens and tc combo.
What do you think about the pictures?
 OlcayK's gear list:OlcayK's gear list
Canon EOS R7 Canon RF 100-400mm F5.6-8 IS USM
Canon EF 100-400mm F4.5-5.6L IS II Canon EOS R7
Steve Fink Senior Member • Posts: 1,652
Re: Canon R7, Ef 100-400 ii and 1.4 Tc Bif Photos. Are these acceptable?
Not a fan of the cropping.  When you say %100 crop, does that mean you no cropping, untouched cropping?  If so, you probably needed to drop the full zoom back a bit.
I have the RF 100-400mm and tried the RF 1.4x with it.  I didn't like the combo and returned the RF 1.4x.
For longer telephoto needs, I use my RF 600mm F11.    The 1.4x paired with the 100-400mm is not that much different in aperture value (I forget the number), but offers a smaller telephoto reach (560mm).  These two lens were not that expensive, offer good AF and IQ, for the price, IMO.
YMMV
Steve
Minds are like parachutes, they only work when they are open - Unknown
Mark B.
Mark B. Forum Pro • Posts: 29,742
Are these cropped, or did you downsize them to 1.7mp?  Either way, they're all soft.  I guess what you consider acceptable is up to you.
expro Senior Member • Posts: 2,273
I would expect the eyes to be pin sharp.
if these are 100% crops then you must have been a long way away with that combo. Nothing can replace getting closer.
light looks pretty flat.
plus the other problem is that herons can be pretty boring subjects unless you get them catching their dinner
 expro's gear list:expro's gear list
Canon EOS R3 Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 14-35mm F4L IS USM
Victor Engel Forum Pro • Posts: 20,968
In my testing with EF 100-400 II lens and a bunch of different teleconverters, including the Mark III Canon ones, there was no improvement with any of them over using the lens by itself and resizing. That was using a Canon 5DS. The pixel pitch on the R7 is smaller than with the 5DS, so I would expect no improvement on the R7 either. The lens simply isn't sharp enough to gain an advantage with the TC. But maybe you have a sharper lens than I have. It doesn't appear so, though, from the photos.
Victor Engel
 Victor Engel's gear list:Victor Engel's gear list
Canon EOS 5D Canon EOS 5D Mark II Canon EOS 600D Canon EOS 5DS Canon EF 50mm F1.8 II +13 more
jim mij Senior Member • Posts: 1,035
For your first outing I’m glad you got something to show, my early shots were all birds on a branch. I’ve never had much luck with TCs though, images seemed soft so it sits in the drawer
Jim
 jim mij's gear list:jim mij's gear list
Canon EOS M6 II Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF-S 60mm f/2.8 Macro USM Kenko Teleplus Pro 300 AF 1.4x Canon EF-M 22mm f/2 STM
KevinRA Senior Member • Posts: 1,457
Some of these - I'd say yes OK and as expected.
https://1.img-dpreview.com/files/p/E~forums/66890948/82ffd85795fe4dba8e529ea4d3f64214
So the R7 is in effect already a 1.4X TC over a 7D or 7DII - which the 100-400 when it came out was designed for. So in effect 1.4X TC on the R7 is like a 2X on the 7D - and the rule then was only the best prime lenses were really worth it with 2X TC's.
You are also at ISO 640-800 - so at pixel level will see some noise at 100% on the R7. Take the sharpest ones - put through DXO deep prime XD with lens sharpness off - then try topaz sharpen AI to sharpen up and some of these will then likely look OK.
I never bother with the 1.4X TC on the EF100-400 with the M6II, R10 or R7. Not worth it.
 KevinRA's gear list:KevinRA's gear list
Canon EOS M6 II Canon EOS R5 Canon EOS R7 Canon EOS R10 Canon EF-S 60mm f/2.8 Macro USM +14 more
OlcayK
OP OlcayK Forum Member • Posts: 89
The bird was small in the frame so zoomed to 1:1 and cropped. Applied the same crop to all the frames.
OlcayK
Yes when you zoom so much it starts to look noisy. Normally I do the same as you mention. Run through dxo first and then edit in lightroom. So 1.4 tc doesn't improve iq. I should use it when the bird fiils the frame then. Maybe one stop closing at f11?
OlcayK
These are cropped and I tried to put the bird in the center when cropping. Personally I was expecting a better quality. I just asked to be sure if I was doing something wrong or these are as good as it gets.
OlcayK
Are there sample variations in this lens? I read the first version really suffers from this.
So no gain with the tc at all? I saw some great images on the net even with the 2.0 tc.
CameraCarl Veteran Member • Posts: 9,193
Can you post some uncropped images for comparison? And some without the converter.
Adam2 Veteran Member • Posts: 7,615
Well that's difficult to say as the photos need some PP and it's impossible for me to assess whether atmospherics were at play.  Although GBH's are slow moving birds, you might want to up your Tv for maximal sharpness.  Finally, you might find the 600/800 f/11 more useful if you are on a budget.
Hi
Problem with f/11 is on the R7 you are now into more significant diffraction softening territory.... plus one stop worse noise and dynamic range over f/8.
I own and like the EF 100-400 and dont want to shell out for the RF 100-500.  I just accept smaller but sharper and high hit rate images when using it without a TC on R10/F7/M6II
If you compare the 5DSR with a 2X converter, this would equate to a R7 with a 1.4X converter.
You can see here the IQ is just not quite there - compare to the 600II plus 1.4X as another another way to get to 800mm in this 5DSR test. This is under test conditions, in the field likely a little worse since focus errors may also creep in.
https://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=972&Camera=979&Sample=0&FLI=6&API=3&LensComp=748&CameraComp=979&SampleComp=0&FLIComp=1&APIComp=0
Now it is not that the EF100-400 II is not a good lens - without the 1.4X TC even on a R7 it is quite good. Compare to a lousy lens as in this comparison even without TC:
https://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=972&Camera=979&Sample=0&FLI=5&API=0&LensComp=776&CameraComp=979&SampleComp=0&FLIComp=4&APIComp=1
(R7 = 5DSR with 1.4X TC in centre)
BobKnDP Senior Member • Posts: 3,140
Just to be clear:
Are the posted images just crops, or have they been reduced in size as well?
I think there are variations with any lens. The manufacturers try to reduce variation, but it's inevitable. Subtle variations in refraction from the mixing process of the glass, for example, or wear on the machines that grind the lenses, or small changes in assembly done by people using their hands.
The gain is that you get an enlarged image. But you can also enlarge an image made without a TC in post, and that's what my comparison was. In every case I tested, the upsized image was equal to or better than the equivalent one made with a TC. There may have been a couple of marginal tests, but I figured with the loss of a stop of light, it wasn't worth it to explore any further.
I did a similar test using my 600mm f/4 III lens, and I got different results. What it boils down to is that the 100-400 II lens I have doesn't resolve more detail than the resolution of the 5DS but the 600mm does.
Victor Engel
Ephemeris
Ephemeris Senior Member • Posts: 1,186
We use the same lens and the Mkiii teleconverter on an R5 regularly. This is becuase we are often quite far away from the subjects and still require cropping even with the converter.
We have two setups the same and have toyed with the idea of an R7 but have so far not been convinced it will earn it's body cost (even second user).
The zoom is required due to the target getting closer otherwise a larger white may be a better option.
At the moment we get good results and also use stills (we use a monochrome output) from the 8MP video. This is purely as a backup in case a shot is missed it badly focussed.
I did follow your posts on this topic in the past. One element is that with the converter, we can still use the crop mode and at least in my mind focus tracking has a benefit - something cropping alone can't do
Robbey TC
Robbey TC Forum Member • Posts: 82
It might be that you are at the absolute limit for the rig and parameters you have chosen
Any tiny camera shake is going to be magnified dramatically for every 100mm gained (perhaps 4 fold)
You are shooting (hand-held I assume) at nearly 900 EFOV at 1600 Tv and then cropping too much.
I do think the images are OK for the set-up you have and the method you have used.
Try a few test shots with a tripod, with and w/o the TC, and at least 4000 SS and see how you go against shooting the same scene hand-held at various SS with the TC.
A target such as a bank note at 100 feet (30M) would be a good place to start.
I would enjoy seeing the results.
Learning all the time ... trying to get better pictures ... enjoying life
 Robbey TC's gear list:Robbey TC's gear list
Canon EOS R7 Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 50mm F1.8 STM Canon RF-S 18-150mm F3.5-6.3 IS STM
Good to know.  Obviously you couldn't get closer in this particular case.  Small in the frame is not a fair test to many/most cameras IMO.  If you get another chance, try to get closer.  Perhaps a non-cropped image, for comparison sake, might help.
Steve
