philzucker wrote:
Bas Hamstra wrote:
I cleaned the glass surface with kleenex tissues, that was a terrible Idea. Specs and dirt all over the place, probably from the kleenex itsself, on the surface, in the waterdrops, everywhere. Next time I will definately do other cleaning, microfiber cloth etc (also tried a vacuum cleaner, BAD IDEA!)
Good to know that others have the same problems! I like the results very much, Bas, a nice idea put to good use.
Care to enlighten us how you put the (water?) drops on the glass (pipette?) and how you placed the glass in relation to background object? Also the lighting chosen (source, angle) would be nice to know.
A lot of questions you of course don't have to answer, but I'm curios.
Thanks for sharing your pictures!
Phil
Hi Phil,
Thanks Phil, for your kind comments, much appreciated. For the water droplets I use the nose-spray bottles that come with a pipet (in stead of sprayer) and I use distilled water. I am getting a bit handier at making smaller droplets this way.
The idea is to have layers, ideally 3 layers, that is two glass layers and a background layer. The top layer is glass and contains the droplets. Second layer is glass and contains the object to be reflected. The third layer is the background. Where the object does not cover the glass, the background "shines through". If you do nothing with the background (no lighting) it will be black because of light falloff.
Then I light the object from aside, with a grid in place to make the light more directional, the object must be lit, but not the first glass surface.
Then the idea is to have the object blurred (totally, somewhat, that's to play with) in direct sight and to have the reflections sharp (or the drops surface, or nothing). Now you can play with distance of camera to droplets and F-stop and get very interesting effects. Ideally you could also vary the distance between the two glass plates, but I don't have that yet.
Kind regards,
Bas
