ND filters for RF 14-35mm f/4?
Started 1 month ago | Discussions
pawn Veteran Member • Posts: 3,261
Hi
I have been using B+W screw-on ND filters (3, 6, 10 stops) with EF 16-35mm f/4.  These filters work great.  I recently bought RF 14-35mm f/4.  The lightroom profile for the lens cleans up distortion and vignette nicely.  What ND filters are recommended for this very wide angle lens w/o introducing additional vignettes?
Duy
PIOT Regular Member • Posts: 211
Re: ND filters for RF 14-35mm f/4?
I have B+W MRC Nano Master * but 82mm for my Nikon 14 -30 mm ( this lens have filter size 82mm ) and is really good filter. I have 0.9 and 1.8 - not color cast at all
https://www.bhphotovideo.com/c/product/1670023-REG/b_w_66_1101582_77mm_mrc_nano_master.html
If you have problems with cleaning filters before, get this new Nano MRC,  and never look back
I have some filters from other brands like Nikon, Tiffen, Hoya, older B&W, Lee, Sony (Zeiss) but this really clean super easy compare to all others
BBR5 Regular Member • Posts: 212
I believe at least one, and perhaps two, standard thickness 77mm filters should work OK.  You should be able to verify that with the filters you currently use with the  EF16-35 f/4
robgendreau Forum Pro • Posts: 10,917
pawn wrote:
Hi
Duy
I use clip filters that fit behind the lens with the 16-35. https://kolarivision.com/kolari-magnetic-clip-in-filters/ Obviously they have no vignetting effects.
 robgendreau's gear list:robgendreau's gear list
Pentax 645Z
Sgt_Strider Senior Member • Posts: 2,674
I know variable filters will be thicker, but wouldn't that be a better choice since daytime brightness can vary greatly?
BobKnDP Senior Member • Posts: 3,140
robgendreau wrote:
pawn wrote:
Hi
Duy
Interesting.
I wonder how they preserve the ability to focus at infinity? A glass window would displace the focus a little.
Adding a little positive (lens) power to the windows could fix that, I suppose.
dluery Junior Member • Posts: 39
I use Formatt Hitech Firecrest filters on my RF 14-35 f/4.  The Firecrest filters, including ND, are available in as "SuperSlim" and I have not had any vignetting problems.
 dluery's gear list:dluery's gear list
Canon EOS 5D Mark IV Canon EOS R Canon EOS R5 Canon EOS R7 Canon EF 70-200mm f/2.8L USM +17 more
OP pawn Veteran Member • Posts: 3,261
Thx PIOT
Thx Sgt_Strider
"thicker" would not work for me due to severe vignetting
Thx BBR5
What I have works well with EF 16-35mm f/4 but causes a lot of additional vignetting at 14mm
Thx PIOT
If you want to save some money... ( is the same filter you can check SKU number )
https://www.glazerscamera.com/products/b-w-77mm-master-nd-1-8?_pos=7&_sid=8366aaac1&_ss=r
https://www.glazerscamera.com/products/b-w-77mm-master-nd-0-9?_pos=4&_sid=748dceaa9&_ss=r
robgendreau wrote:
pawn wrote:
Hi
Duy
Thx robgendreau
Thx PIOT
The B+W that you mentioned works at 16mm but causes additional vignette at 14mm
