XF 50mm f2 pincushion distortion
al404
al404 Contributing Member • Posts: 827
Just got an used XF 50mm f2 and as usual I'm checking that the lens it is fine
It doesn't seem to be decentrerei but it shows a pincushion distortion
I did take several shot at 67cm measured from the back of the camera to the target
I did Jesus target distance, level the camera... it always show up
Can't think at furore target to try
I'm using an X-T2 but in Capture One it loads lens correction and I can see it as I see in camera
Is it a defective lens or just an issue of 50mm f2 ( at lest at close distance ) ?
target it is a scaled A4 image of a 10€ bill ( not real size bill )
 al404's gear list:al404's gear list
Fujifilm X-T3 Fujifilm X-T5
Fujifilm X-T2
dwalme Regular Member • Posts: 414
Re: XF 50mm f2 pincushion distortion
This lens is not optically designed to be distortion free.
https://www.opticallimits.com/fuji_x/1014-fuji50f2?start=1
There are two lens correction profiles in Capture One. One they create but they also allow you to select the manufacturer profile which will load the correction data from the lens/camera that is embedded in the RAW metadata.
 dwalme's gear list:dwalme's gear list
Sony a1 Fujifilm X-T5 Fujifilm XF 14mm F2.8 R Fujifilm XF 50-140mm F2.8 XF 90mm +9 more
Erik Baumgartner Senior Member • Posts: 6,894
Capture One’s or the “Manufacturer’s” correction profile? Try both.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
XenonDeathFlash Forum Member • Posts: 65
Have you adjusted the distortion slider in the Lens Correction tab to 100?
