Not enough light
Started 1 month ago | Discussions
Jason Yao New Member • Posts: 9
Not enough light
I got a Laowa 25mm with the ring light but realized I do not have enough light. Are there any flashes that are powerful enough to also support the lens at 5x magnification as well as 2.5x magnification without overexposing or underexposing?
grsnovi Veteran Member • Posts: 3,030
Re: Not enough light
What are you shooting?
In the studio or outside?
 grsnovi's gear list:grsnovi's gear list
Panasonic Lumix DMC-GX85 Sony SLT-A65 Sony a7R III Panasonic Lumix DC-GX9 OM-1 +11 more
Richard Dutton Contributing Member • Posts: 572
there is an interesting article touching on the challenges of using these high mag lenses in Photography Life. A suggestion or two there about lighting:
https://photographylife.com/reviews/venus-laowa-25mm-f-2-8-2-5-5x-ultra-macro/2
Not something I have experience with myself.
Mostly Bugs
The article assumes you're mostly shooting bugs (although one example image is of a steel rule laid flat - for the life of me I'm not sure why that was used as a focus stack image).
BBbuilder467 Veteran Member • Posts: 7,057
If that lens has manual stop-down, you have to manipulate everything yourself.
If you haven't mastered using a manual speedlight at 1:1, you have nothing to relate to.
