A Pollen
Started 1 month ago | Discussions
SigmaTog
SigmaTog Senior Member • Posts: 1,114
A Pollen
5
A Pollen
100 x magnification + 100% crop.
jim mij Senior Member • Posts: 1,027
Re: A Pollen
I use nasal spray daily to block out such nasty things
Jim
 jim mij's gear list:jim mij's gear list
Canon EOS M6 II Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF-S 60mm f/2.8 Macro USM Kenko Teleplus Pro 300 AF 1.4x Canon EF-M 22mm f/2 STM
grsnovi Veteran Member • Posts: 3,030
Re: A Pollen
Is this a stack of multiple images?
Have you previously described your rig for getting 100x magnification?
Nice image!
 grsnovi's gear list:grsnovi's gear list
Panasonic Lumix DMC-GX85 Sony SLT-A65 Sony a7R III Panasonic Lumix DC-GX9 OM-1 +11 more
SigmaTog
OP SigmaTog Senior Member • Posts: 1,114
Re: A Pollen
Nice image!
Yes, This is 21 stacked at 1.125um steps, with a Nikon 100x microscope objective.
Awesome rig!
What brand rails are you using? The one I have works but it doesn't have micrometer adjustment - which would be nice.
I usually try to dial in focus manually so I get peaking and then adjust the focus rail to advance the peaking from near to far. So far that has been working OK for my casual attempts.
SigmaTog
Re: Awesome rig!
The stage is Chinese micro adjustable xyx & rotation.
The camera has an older linear actuator that has 1.125um steps & is manually turned.
For 100 x magnification you need every thing to be rock stable.
Even playing music is out of the question, as it will vibrate the camera & you can see the micron movements to the beat !
macrouser
macrouser Senior Member • Posts: 3,979
Re: A Pollen
That is amazing.  Can you tell us the species the pollen is from?
 macrouser's gear list:macrouser's gear list
Sony SLT-A77 Sony a7R III Sigma 150mm F2.8 EX DG Macro HSM Sony FE 90mm F2.8 macro Sony FE 70-300mm F4.5-5.6 G OSS +2 more
SigmaTog
Re: A Pollen
Yes, I am told it is Conyza canadensis or similar.
Top 600mm.
