R7 and Macro
Started 1 month ago | Questions
Marceppy Forum Member • Posts: 58
R7 and Macro
Hi Folks,
I am thinking about upgrading from a DSLR to a R7 for macro work.  Ive been reading lots of threads about the R7 - mostly used for sports or birding.  The issues seem to be more with fast moving subjects and the ES and EFCS (rolling shutter), noisy mechanical shutter and vibration.  One application I plan on will be with LED lighting indoors (flash not available with EFCS).  However, one of the cons noted was banding with artificial lights.  So, I curious if anyone has had experience with LED lights and the R7 or other R bodies and EFCS.  Thanks!
 Marceppy's gear list:Marceppy's gear list
Canon EOS-1D Mark IV Canon EOS R7 Canon EF 100mm F2.8L Macro IS USM Canon MP-E 65mm f/2.5 1-5x Macro Canon EF 24-70mm F2.8L II USM +1 more
Canon EOS R7
Gwand Junior Member • Posts: 39
Re: R7 and Macro
Flash does work with EFCS but not with full electronic shutter
 Gwand's gear list:Gwand's gear list
Canon EOS R5 Canon EOS R7 Sigma 50mm F1.4 EX DG HSM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM +7 more
BobKnDP Senior Member • Posts: 3,140
Re: R7 and Macro
Edison base LEDs presumably flicker at 120Hz from the rectified AC. The amount of flicker may vary among makes.
I've used consumer LED "bulbs" for lighting, with EFCS on an R5. I didn't get any noticeable banding. Exposure times were 1/60 and 1/80 second.
I presume that purpose-made LED sources for photo work drive the LEDs with filtered DC. Those wouldn't flicker at all.
danferrin Contributing Member • Posts: 730
Re: R7 and Macro
I think the banding issue with artificial lights depends on the quality of the lights.  I haven’t tried them with my R7, but I have some Westcott Solix led lights that I’ve used with my R5 and EF100 l macro, and never had a problem.  Also have a Genaray Full Moon led light that I’ve used a lot without any banding issues.
My life is a circle of confusion - photography is my meditation.
See my work at http://www.danferrinphotography.com
 danferrin's gear list:danferrin's gear list
Canon EOS 60D Canon EOS 7D Mark II Canon EOS RP Canon EOS R5 Canon EOS R7 +20 more
R2D2 Forum Pro • Posts: 26,531
Re: R7 and Macro
Marceppy wrote:
Hi Folks,
The R7 is my dedicated macro camera.  I keep the RF 100 f/2.8L pretty much “permanently” attached, and I use LEDs the majority of the time because I like to use the Focus Bracketing feature (it’s eShutter only).
Most portable LED panels that are made for photography and video don’t flicker (check to be sure though).  I really like the Aputure Amaran AL-F7 LEDs.  Very powerful with continuously variable output and color.  I also just bought the Comer Radiance 360  LED.  It’s even more powerful, but a little smaller in surface area.  Both purchased from B&H.
Here’s a picture of the Aputures…
Bracket from FleaBay.
R2
OP Marceppy Forum Member • Posts: 58
Re: R7 and Macro
Thanks I appreciate the information.  The birding, wildlife, sporting, landscape R7 thread had pushed me back towards a 5dM4 due to the comments about the image issues with the R7.  Some of what was being discussed did not relate to a macro setup so I thought Id ask the folks that have experience.
I spoke with CPS last week and specifically about the R7 flash capability in EFCS which was --  "it does not trigger flash speedlights. "   If you have found a way to make it work .. please explain in detail.
Any experience pro or con for using the R7 or other Rs for macro would be appreciated.
Ive been back and forth on the fence with the R7 and a DLSR
JayLT4 Regular Member • Posts: 288
Re: R7 and Macro
CPS likely misinterpreted what you said and spoke about the fully electronic shutter rather than the EFCS. The EFCS certainly does trigger the flash, and you actually need to use it to get the highest sync speed of 1/320th, the mechanical shutter has a max sync speed of 1/250th, per the manual;
https://cam.start.canon/en/C005/manual/html/UG-04_Shooting-1_0140.html
I use the R7 and R5 for macro all the time, they're great, but just like most things, switching to mirrorless does need some adjustments.  The EVF versus OVF can be difficult for some as you need to remember to turn off the exposure simulation setting when using a flash.  However the EVF does still have some nice advantages, as it will show the magnification meter (basically focus distance meter) in the EVF so you know how much closer you can get without guessing.
I guess I'm one of the few that mostly use AF when shooting macro, but usually what I shoot like to move around and fast AF can be helpful, and the R5/7 are very fast focusing, especially with the RF 100mm (but still very fast with the EF 100mm L in my experience as well).
Overall, I don't miss my 90D or 5Ds.
 JayLT4's gear list:JayLT4's gear list
Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon MP-E 65mm f/2.5 1-5x Macro Canon EF 16-35mm F4L IS USM +4 more
charlyw64 Contributing Member • Posts: 717
Re: R7 and Macro
What image issues? As often on these forums IMHO the "problems" are blown out of proportion. You have a fast mechanical shutter working at up to 15 fps, the shutter shock of the fully mechanical shutter (in case you are worried about that) is still smaller than the mirror slap on many if not all DSLR. For birding, wildlife you won't be using lenses faster than f/2 where the shadow of the second shutter curtain in EFCS would influence the bokeh highlights, so you can easily use EFCS without any problems. Yes, the sensor readout in fully electronic shutter is slow and limited to 12 bit A/D conversion (EFCS and mechanical shutter work with 14 bit A/D conversion). The place where the slow sensor readout becomes problematic will be the pre burst shooting (where you may lose the odd shot from the burst when parts of the subject move too fast for the sensor readout or your panning screws up the background) - but that option doesn't exist in the DSLR at all, so that is a rather moot point to revert to a previous technology because a new option isn't without limitations.
Here is a rather level headed post regarding shutter shock https://www.canonrumors.com/forum/threads/shutter-shock-on-the-r7.41622/
I am predominantly shooting macros and still bought the R7 because it does everything I'd ever need. That being said I have not even looked at the flash capabilities as I never use flash for my macro shots, I use natural light and diffusors/reflectors to shape the light, the convenience of now finally being able rotate the camera using my lens tripod ring without restrictions on the macro rails because the relevant side of the camera doesn't extend that much outside the rotation axis - as did the 7DII - is a welcome bonus for me. The biggest drawback of the R7 vs. the 7DII was the different remote release connector, the bluetooth remote release isn't really helpful as it is too restricted regarding release capabilities, the camera connect app is too finicky regarding connection stability.
The focus bracketing is something I consider for times when I need to refocus after the wind died down for a moment - I will get a lot of unusable shots but the electronic shutter doesn't mechanically wear out and 12 bit A/D conversion normally is plenty for the lighting setup I work with. Previously I lost quite a lot of opportunities due to the need to refocus and take the shot whenever the wind died down (and the subject settled down) before the wind again moved my subject. The focus stacking though I consider a useless gimmick. Focus stacks do not work for my subjects (insects and native orchids) at all, so that is a feature that may impress NOOBs but the only lens that this could work with doesn't even have an autofocus motor (MP/E 65mm f/2.8, at 5:1 magnification ratio the subject size vs. magnification changes in a macro stack between overlapping subject areas is small enough to not completely mess up the stack)...
Why wouldn't EFCS trigger the flash, it's even listed as achieving the fastest sync speed of 1/320th of a second:
koenkooi Contributing Member • Posts: 920
Re: R7 and Macro
Marceppy wrote:
Hi Folks,
I am thinking about upgrading from a DSLR to a R7 for macro work. [...] (flash not available with EFCS). However, one of the cons noted was banding with artificial lights. So, I curious if anyone has had experience with LED lights and the R7 or other R bodies and EFCS. Thanks!
I've personally used the R7, in EFCS mode, with an EL-100 speedlite. And it worked as it should.
 koenkooi's gear list:koenkooi's gear list
Canon EOS 7D Canon EOS M Canon EOS M6 II Canon EOS R5 Canon EF 85mm F1.8 USM +20 more
Steve Balcombe Forum Pro • Posts: 15,571
Re: R7 and Macro
I've been one of the more vocal critics of the R7's very slow sensor readout speed and the resulting rolling shutter problems. But these are only relevant when shooting subjects which move fairly fast (bird-in-flight wings, dragonfly-in-flight wings, various sports subjects) and when panning. The R7 is a superb camera for static macro and near-macro subjects.
There's nothing to explain, it's just not true. Flash doesn't work with ES (Electronic Shutter) but it works as normal with EFCS (Electronic First Curtain Shutter) and traditional mechanical shutter.
However there is a macro-related problem to be aware of, which is that the in-camera focus bracketing feature, which is really good for some macro subjects, works only with Electronic Shutter and therefore not with flash. It's hard to criticise the R7 for this, because very few bodies support flash with electronic shutter. The R3 does, and the Nikon Z9, but the one which is most relevant for macro is the OM-1.
There are of course other focus bracketing techniques, and/or you may be able to use continuous lighting, so this is still not necessarily a deal breaker.
There is no reason that I can think of to favour a DSLR for macro, other than price, and this is only because DSLRs are generally older models at discounted prices. But even here the difference is not huge - the 90D's street price is £1,100, vs £1,349 for the R7.
Full frame would not be my choice for most macro work. Is there a reason why you specifically mention the 5D4?
I see you've used Olympus before - it would definitely be worth checking out the OM-1 before you decide. More expensive though.
drsnoopy Senior Member • Posts: 1,216
Re: R7 and Macro
Marceppy wrote:
Hi Folks,
Flash is of course available (and I have used it) with EFCS, but not with ES. Your info from CPS is simply wrong. I suspect your interest is automatic focus bracketing, as that uses ES and is incompatible with flash in the Canon system.  I have used a rechargeable LED light panel with my R5, and RP, no issues with banding or flickering.  You won’t have any trouble with an R7.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
KevinRA Senior Member • Posts: 1,457
Re: R7 and Macro
+1
Well your entitled to your opinion even if I think a bit harsh - IMHO focus stacking can work well with orchids and insects in the field with some effort put in, such as with Helicon Soft - with images looking fine at A3 size prints free of artefacts normally with some work.
Now get that for extreme > 1X macro.
Semi-macro 0.5-1.0 life size and the amazing range of macros available can work just fine with focus stacking.
 KevinRA's gear list:KevinRA's gear list
Canon EOS M6 II Canon EOS R5 Canon EOS R7 Canon EOS R10 Canon EF-S 60mm f/2.8 Macro USM +14 more
Re: R7 and Macro
KevinRA wrote:
+1
I haven't seen a single artefact free image at that size which didn't took days to invent the areas that the focus stack can't capture for physical reasons...
As I said, I have been photographing macro for 20 years now and even dabbled in focus stacking at times before cameras could try it themselves - and I haven't seen a single successful image from others or myself where there weren't major artefacts from halos around elements closest to the camera where they overlapped background elements, to multiplication of limbs because of movement (proboscis or feelers are the most likely culprits), to unnatural background translations, to the lack of any sense of depth in the subject (you can't tell which feeler for example is oriented towards the camera or away from it and where it is attached to the insect... Nothing can prevent those issues and the reason the worst (the halos around overlapping elements that obscure the elements further away) are not happening is due to high (or low) magnification ratio, when the magnification ratio is high the effective aperture is big compared to the size of the subject which will render those elements completely transparent and (more importantly) the magnification ratio doesn't significantly differ from the stack layer that contains the sharp element compared to the sharp layer that contains the element further away. IMHO stacks are a matter for technical documentation but in aesthetic photography they are lacking in oh so many ways that they are not worth pursuing (unless you need to do technical accurate documentary shots)...
So I wouldn't get my hopes up if I were the OP that focus stacking solves any problems unless his subjects are those 0.01% of subjects that don't have any overlapping areas and which look good artificially flattened as if they had been pressed flat in a specimen collection book from a 19th century botanist...
Re: R7 and Macro
The positive feedback is certainly reassuring and appreciated.  The LED lighting information is good to know.
When I spoke with CPS, perhaps I didn’t ask the right question regarding the flash. I may call again they are helpful.
I have the MP-e65 1-5x macro lens and the Macro Twin Lite MT-26EX-RT that I use often with the 1DM4.  Any experience using the latter lens and flash with the R7?  I’d be using a ef-R adapter.  Will also be using the ef 100mm f2.8 macro lens, and extension tubes.
Re: R7 and Macro
There are two types of LED lamps, one is driven from just a simple electronics from the mains power supply where a simple capacitor has the task to remove the mains frequency - which results in those lights being pulsed at 100/120 Hz (double the mains frequency). Then there are LED lights with dimming functions, that too is created by pulsing the LED. They too are often found in household lighting. And then there are the high CRI video LED panels, they are built to be used with video cameras and hybrids like the R7, they are delivering a very constant light output that doesn't fluctuate enough to be noticeable in video or photography.
Maybe you were misunderstood (or the person answering wasn't familiar yet with the design change that EFCS has undergone for mirrorless cameras). On DSLR the EFCS didn't trigger the basic flash guns because the flash trigger was linked to the first mechanical shutter curtain. Now the flash trigger is linked to the a separate electronics triggered alongside the electronic first shutter curtain. The reason it doesn't work for fully electronic shutter is the long readout speed of the rolling shutter which is too long compared to the flash duration.
The 100mm f/2.8L IS USM is working nicely, just like the Sigma 150mm f/2.8 EX DG OS HSM (what a mouthful of acronyms)... The MP/E lens will be working as normal, I have seen so many examples in the macro photography forums I frequent, just not the flash gun (it must work else I would have seen complaints about it on the technical forums that accompany the image forums)...
CamerEyes Regular Member • Posts: 266
Re: R7 and Macro
Marceppy wrote:
Hi Folks,
No issues whatsoever in using my R7 indoors, with practically any kind of lighting on EFCS. Even the "dreaded" weird bokeh - I couldn't reproduce it for the life of me.
 CamerEyes's gear list:CamerEyes's gear list
Sony a7C Canon EOS R7 Canon EOS R6 Mark II Canon EF 50mm f/1.2L USM Canon EF 50mm F1.4 USM +12 more
Re: R7 and Macro
charlyw64 wrote:
KevinRA wrote:
+1
technically correct I appreciate and seen it plenty of times - often can be largely remediated I'd suggest to adequate level....
It's a discussion forum - all entitled to different perspectives.
Mine is otherwise for much more than 0.01% subjects unless one is pixel peeping at 200% or viewing an A0 print.   (Somethings yes one cant get good results - but sometimes I think especially with Helicon one can adequately and be useful and artistic).
Re: R7 and Macro
Thanks for all the replies, great help.  Canon CPS did confirm flash availability with the R7 and my EX series flashed would work.
dwkdnvr Regular Member • Posts: 263
Re: R7 and Macro
It really does seem that the R7 and OM-1 are the 2 bodies to look at if you're considering the areas where crop has advantages or at least where the downsides are mitigated - telephoto/wildlife and macro.  The OM-1 is more expensive, but has the very good Oly 60mm macro available which evens out the pricing if you're pairing the R7 with either of the 100mm lenses.
I'm considering the R7 + RF 100-400 + a macro, but was considering the EF-S 60mm on an adapter. Probably not close to the performance of the 100's, but at $300-ish used it's an easier first step and it does seem to be one of the better regarded EF-S lenses.
Re: R7 and Macro
My copy of the EF-S 60mm is sharper than my (now sold) copies of the EF100 non-L and EF100L, when used on an M6II. I sadly didn’t compare it to the RF100L when I rented an R7.
The EF-S 60mm is an older lens, from a time where Canon had significant copy to copy variations, so YMMV.
