Canon DPP = JPG in Camera?
Started 1 month ago | Questions
Rufty Forum Member • Posts: 51
I used to shoot only RAW with my m50. Now, I find that sometimes I don't have the time for editing and that it would be nice to have the JPG.
My question: If I convert the cr3 files to jpg via batch export in DPP after shooting, without any editing, would the result be the same as if I had shot JPG? I feel like Canon should process them equally no matter if they are processed in-camera or post?
Thank you
 Rufty's gear list:Rufty's gear list
Canon EOS M50 Sony RX100 Canon EF-M 22mm f/2 STM +1 more
Canon EOS M50 (EOS Kiss M)
jim mij Senior Member • Posts: 1,035
Re: Canon DPP = JPG in Camera?
Sorry no idea, why not try it and see ?
Doing it in dpp will still take time (lots of it if you have many images)
why not shoot with raw+jpg you’ll have both
And although i primarily shoot jpg I still have to edit those but I find that quicker than editing raw
Jim
 jim mij's gear list:jim mij's gear list
Canon EOS M6 II Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF-S 60mm f/2.8 Macro USM Kenko Teleplus Pro 300 AF 1.4x Canon EF-M 22mm f/2 STM
Ali Senior Member • Posts: 1,969
+1 on this. Shoot both, keep the jpgs you like without having to do any post-processing, and for those shots where you need the raw, you still have it.
Is there really a speed difference in editing raw vs jpg? I find that if you need to edit, raw will usually give you much more flexibility, and the only cost I've seen is space.
(However I use Lightroom, not DPP)
 Ali's gear list:Ali's gear list
Sony Cyber-shot DSC-HX50V Olympus TG-5 Panasonic Lumix DC-ZS80 Canon EOS M6 II Canon EOS R5
Andy01 Veteran Member • Posts: 5,188
What I often do with DPP is to do a "bulk" correction (eg. lens correction or DLO) of RAW files by selecting all of the thumbnails and clicking on the Tool Palette to apply it to all images, then save as TIFF, and import the TIFF files into LR if I want to edit further. You could obviously also save as JPEG if desired.
I think that DPP does a better job of the corrections and RAW conversion than Adobe, and this gets the job done with just a few minutes of effort.
 Andy01's gear list:Andy01's gear list
Canon EOS M5 Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM +5 more
for me yes, but I’ve only recent started using raw again after giving it up when jpg became as good, several years ago.
it was 1 image with blown highlights in a bird that made me try raw again. In the dozens I’ve tried since I prefer my jpg edit to my raw edit , I tried luminar 4 and dpp 🙁
Jim
Supisiche Senior Member • Posts: 2,027
I think it will be 99% the same.
OP Rufty Forum Member • Posts: 51
I'm saving space on my sd card and probably gaining a little bit of buffer speed?
Greg Edwards Regular Member • Posts: 487
IIRC DPP uses the same processing algorithms as in camera jpeg processing, so in theory you should get exactly the same result from raw if left at default settings. DPP reads and applies settings that would have been applied if it were processed in camera, such as picture style and white balance etc.
DPP was my first foray into raw processing a few years ago. Whilst it produced great output, I found it very slow to work with, especially batch processing.
 Greg Edwards's gear list:Greg Edwards's gear list
Canon EOS M5 Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM Canon EF-M 55-200mm f/4.5-6.3 IS STM HP Photosmart B110 +3 more
J Peters Contributing Member • Posts: 759
+1 to this. I did a test years ago comparing in-camera versus DPP processing. The resulting jpeg file sizes were different by a few bytes, so clearly not identical, but I could see no differences. I suppose theoretically a newer version of DPP might do a subjectively better job than the firmware in the camera, which is less likely to have an update, so then there might be slight differences.
I don't edit every shot, so you could argue I could use RAW+jpeg mode. But in practice I shoot RAW only, edit the few I want to, and then batch-process the lot. Yes it takes ages, but I don't sit and watch it. I go and do something else for an hour.
JustUs7 Senior Member • Posts: 4,327
Slightly different.  White balance and picture style are the same, but the initial image is flatter than the jpeg until you make gamma adjustments.  I usually start by hitting the auto gamma adjustment button and fine tune highlights, shadows, and contrast from there.
Lens corrections, noise reduction, sharpening, etc - DPP4 shows all that in the preview.
 JustUs7's gear list:JustUs7's gear list
Canon EOS 1000D Canon EOS Rebel SL1 Canon EOS RP Canon EOS M6 II Canon EF 75-300mm f/4.0-5.6 III +10 more
Yes, that's my plan, too.
Thank you all for your answers!
Thanks Andy, thats a learning point for today, i didn't realise i could manipulate a batch at a time, i'll give it a try
Jim
It’s worth mentioning that a newer version of DPP can bring features that the camera may not have. For example, when I used to use DPP, it let me use the “Fine Details” picture style that my M3 camera didn’t support.
RLight Senior Member • Posts: 4,417
Thank you
Not quite. But 99.9%, and I gather that’s the point.
If you change zero settings, in my experience, DPP4 gives a touch more color depth. I will say DPP4 appears to be a computer emulator for DIGIC though, however the RAW conversion is better. This may just be due to my color depth settings, this can be adjusted in preferences.
 RLight's gear list:RLight's gear list
Canon EOS R3 Canon EOS R50 Canon RF 28-70mm F2L USM Canon RF-S 18-45mm Canon RF-S 55-210mm F5.0-7.1 IS STM
trungtran Senior Member • Posts: 1,747
Re: Nope
Visually it be hard to tell the difference but there are differences. You can just look at the file size and see they are not the same.
DPP is going to have more options. Over time the differences become even bigger as it improves while the camera stays stagnate with no more firmware updates.
 trungtran's gear list:trungtran's gear list
Olympus OM-D E-M10 Sony a7 II Canon EOS M6
Re: Nope
I’ve been using DPP4 since the G1X II came out, i used DPP3, before it. I can say with confidence, yes DPP4 honors SOOC rendering. In fact it does so too well, G1X mark II and all. That’s one I wish DPP4 did t copy so well. Prove me wrong. I’ll be waiting…
Color space and matching JPEG compression impacts file size, btw. There is no “8” jpeg compression on an M, for example. There is on my R3 though. It’s compressed, and more compressed. Large, medium, small in camera. File size isn’t alone a good metric here is the point I’m driving.
Re: Nope
You can look at the EXIF and the SOOC doesn't even have a program name.
1DSii above - SOOC is different to DPP3 and DPP4
M6 below - Camera compression is more aggressive than DPP
Using FastStone Viewer you can count the number of colors - The smaller the file the less colors are in the image.
Not all processors are equal. You might not be able to see it, but the difference is there.
https://hk.canon/en/support/8201532900
My point is that SOOC is not the same as processed DPP JPG.  You are fine if you shoot RAW since you capture all the data.
But if you shoot JPG, thinking it is the same as a DPP export, you are mistaken.
Re: Nope
Yes, 3 and 4 are different but you need to explain further, unless that was the point. I agree DPP4 is better than DPP3, with DPP4 being virtually identical to SOOC so long as you match the recipe, as described.
