Re: Great camera, just way overpriced.
5
richard cohen wrote:
There are 3 really great cameras out there that are vying for the best all around...the R3, A1 and Z9. The latter two have two advantages...first and foremost they have a large resolution advantage which for some kinds of shooting like wildlife, makes the R3 almost irrelevant.
The Z9 has a 37.6% linear resolution advantage, and the A1 has a 44% linear resolution advantage. Whether that makes the R3 irrelevant obviously depends on your priorities, what wildlife you shoot, and what lenses you have. Given that I've seen plenty of amazing wildlife shots from the R3, I'm guessing that, for many wildlife shooters, at least, the R3 is far from irrelevant. For sports and event shooters, unless focal length limited, 24MP is more than enough.
Second is price...the other cameras are less expensive.
No they aren't. At least not when I checked just now. Given that you used the present tense, I assume you simply don't know how much the three cameras currently cost. The Nikon currently retails for around $5500, the Canon for $6000, and the Sony for $6500. This makes the Sony the clearly overpriced one out of the three, especially considering that it doesn't have a built-in grip. To get the Sony in a comparable configuration to the other two, you'd have to pay $6850 (the grip costs around $350). That's $850 more than the Canon, and $1350 more than the Nikon. Ouch!
There is no reason the R3 should cost more than the others
And it doesn't cost more than the Sony, as I just showed. In fact it's $850 cheaper.
either new or used imo...and we are rapidly heading that way. I've seen big discounts on new ones and in the used market, all three cameras are now well below $5k. I've been tempted to try the R3 but the price never seemed to make sense to me. I guess I'm holding out for the R5ii which should be here later this spring. I like the smaller form factor.
So, to correct what you said, what we have is a resolution advantage for the Nikon and Sony. How significant that is depends on personal preference. We have a cost advantage for the Nikon, and, to a lesser extent the Canon, over the vastly overpriced Sony. The Canon has a burst speed advantage over both the others. It shoots 30fps in full RAW. The Sony can only do 30fps in lossy RAW, and the Nikon can only do 30fps in JPEG, and 20fps in RAW. The Canon is also the only one with eye-control AF. And the Canon is the lightest of the three. The Canon, with batteries, is 1015gm, the Sony, with grip and two batteries, is 1112gm, and the Nikon, with batteries, is 1340gm (this is all according to the specs listed on DPR for the cameras, and specs listed on B&H for the Nikon grip and extra battery).
Each camera has some advantages and some disadvantages over the other two. For me (not much of a wildlife shooter), if someone offered me one of these three cameras for free, I would unhesitatingly take the Canon. Likewise, if I had up to $6850 to spend, I would buy the Canon and use the other $850 for lenses, etc., rather than spend it all on the Sony, or spend $5500 on the Nikon and have $1350 left over for other things.
They are obviously all excellent cameras, and I wish I could justify spending that much on one of them, but the balance of features seems, to me at least, pretty heavily in favor of the Canon (unless MP is more important to you than pretty much anything else, as opposed to being one consideration among many).
“When I die, I want to go peacefully in my sleep like my grandfather. Not screaming in terror, like the passengers in his car.” Jack Handey
Alastair
http://anorcross.smugmug.com
Equipment in profile
