Skunk Cabbage
joelbolden Regular Member • Posts: 195
Skunk Cabbage
The first wildflowers of the year here in Central Pennsylvania arestarting to bloom. The cold hardy Skunk Cabbage first emerges as Spathes. Within the Spathe is a heat generating(thermogenic) growth called a Spadix, which keeps the interior at a toasty 70 degrees(f) regardless of the outside temps. When it senses it's safe, the Spathe opens up revealing the Spadix which is covered with tiny white flowers which are pollinated by flies/bees. It then grows out to be a large green leafed plant. The early stages always look  like something from "The Alien" to me. Pentax Kiii/55-300PLM,
Spathes
Spadix and flowers
 joelbolden's gear list:joelbolden's gear list
Konica Minolta DiMAGE Z6 Konica Minolta DiMAGE A2 Fujifilm XP120 Pentax K20D Pentax K-7 +16 more
ozdean
ozdean Forum Pro • Posts: 28,665
Re: Skunk Cabbage
Interesting Joel - I guess it stinks?
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-5 IIs Pentax K-3 Mark III Pentax smc DA* 55mm F1.4 SDM Pentax smc DA 15mm F4 ED AL Limited +14 more
OP joelbolden Regular Member • Posts: 195
Re: Skunk Cabbage
Since it appears so early in the year, and the flowers need to be pollinated, they normally start out be releasing a decaying meat scent to attract dung beetles and blowflies. It can switch on two other scents; a garlic scent and a flower scent as the season progresses. Later in the year, I've seen honey bees, bumble bees and solitary bees feeding on the flowers.  The leaves have a skunk like flavor when mature and because they contain oxalic acid which can burn skin,  most animals won't eat them and they can blister human skin This is one plant that intends to survive!! Some people do boil the young shoots several times and rinse them. At that point they're edible....not worth the effort. The plant is used in modern herbal medicene as a anti-spasmodic and anti-inflammatory. A drug called Dracontium was made from it and was listed as a cure for insanity.
jimrpdx
jimrpdx Veteran Member • Posts: 3,954
Re: Skunk Cabbage
Ah, that's the drug all the camera companies bought up and made disappear..
 jimrpdx's gear list:jimrpdx's gear list
Olympus E-M1 Sony a7 II Pentax K-S2 Pentax 18-50mm F4.5-5.6 Panasonic 12-60mm F3.5-5.6 OIS +2 more
