Quick look at dealing with Green Purple Blotches
Started 1 month ago | Discussions
EEvan
EEvan Regular Member • Posts: 343
The blotches are probably the thing that annoyed me most when I started to use this camera.
Weirdly I don't seem to have as much of a problem now with them and looking through my last couple sets they aren't as prominent.
But I did notice a few in an image and thought I'd share my lazy approach to dealing with them.
The blotches on the street are kind of annoying
Quick mask of the area in a new layer
Using either the HSL editor, color balance editor, or Color Editor adjust the area to give a more even tone and reduce the appearance of the color. Adjust to taste
Less annoying blotches
Less distracting result
And this is of course not the best or only solution. But it's been the fastest way for me to reduce blotches when they bother me
SigmaChrome Forum Pro • Posts: 15,728
Re: Quick look at dealing with Green Purple Blotches
Neat!
Which camera?
Vitée
Capture all the light and colour!
http://www.pbase.com/vitee/galleries
 SigmaChrome's gear list:SigmaChrome's gear list
Sigma DP1 Sigma DP2 Merrill Sigma DP3 Merrill Sigma dp0 Quattro Sigma SD14 +42 more
xpatUSA
xpatUSA Forum Pro • Posts: 23,016
Nice.
What Application?
What Layer mixing Mode and Opacity?
what you got is not what you saw ...
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
D Cox Forum Pro • Posts: 32,979
I would set the paint brush to Color mode, alt-click on a Good place to set the colour, and paint over the bad area.
Setting the opacity of the brush to, perhaps, 20% allows you to build up the correction slowly.
Don
Sigma fp
Scottelly
Scottelly Forum Pro • Posts: 18,026
I presume you're using a recent version of SPP, but just in case you're not, I believe Sigma did improve the way the color noise tool handles those blotches, at least with Quattro raw files anyway.
Scott Barton Kennelly
https://www.bigprintphotos.com/
 Scottelly's gear list:Scottelly's gear list
Sony SLT-A65 Nikon D810 Sigma sd Quattro H Nikon AF-S Nikkor 200-400mm f/4G ED-IF VR Sony DT 18-55mm F3.5-5.6 SAM +27 more
xpatUSA
Looks like mis-coloration to me rather than the classic Foveon blotching - possibly due to the lighting.
Here's the pavement selection histogram expanded in Levels and then the Chroma increased to bring out the hues:
fronko Regular Member • Posts: 493
Don
don posted this method before. i tried it and it worked really well.
