Using LED ring lights (not flash) for macro insects
Started 1 month ago | Discussions
Antique Eruption
Antique Eruption Regular Member • Posts: 165
Hello, I have been using a Vivitar 55mm f2.8 macro on my Fuji system a little while, and would like to bring a bit more light to bear on the subjects I photograph. I'm CLUELESS about flash and don't want to go through that learning curve at this stage in my photography life. Also, whilst I am now using Topaz DeNoise for other nature photography, I am yet to use it with macro. I will do that as I start getting back out into the garden for some macro opportunities, but I'd like to explore ring LED lighting that can attach to the front filter mount so that I have a little less noise to clean up in the first place. However, I read that a constant light source can introduce softness. What experience do the macroistas here have of this phenomenon? Would the IBIS in my camera resolve that issue (likewise solid technique) or is the reported problem more to do with the use of a steady light? Again, I am not seeking to use flash. Any assistance would be appreciated.
Richard Dutton Contributing Member • Posts: 572
Re: Using LED ring lights (not flash) for macro insects
I have a Neewer one somewhere. Its called a flash but it just a continuous LED ring light with the option on switching it on/off from the flash trigger.
The problem I had was that it actually back lit into the lens mount on some lenses and caused flare. Needs a baffle. I used to use it just as an off camera light source.
Another problem was that the light output wasnt very high. I struggled to get 10ev on a meter on close subjects with poor natursl lighting..
Will be interesting to see if anyone has used these successfully.
I think the LED panels are better being bigger.  For a compact solution I do use a flash on a bracket with diffusers - in my case with a Nikon TTL cable - then another flash unit stood off and used as a slave to the main one.
Havent used any lights recently - just tried to use available light at wider apertures and stacking - not too successful - flash is easier.
jim mij Senior Member • Posts: 1,027
6
Like you I was worried about flash and bought a led ring, after a short while I succumbed and bought a flash, macro results have never been better, and flash is very easy to setup
try camera and flash on manual, f8, 1/160, iso 100, take a pic and increase/decrease flash power till your happy
there are lots of you tubes on it, try micael widell
Jim
 jim mij's gear list:jim mij's gear list
Canon EOS M6 II Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF-S 60mm f/2.8 Macro USM Kenko Teleplus Pro 300 AF 1.4x Canon EF-M 22mm f/2 STM
Antique Eruption
OP Antique Eruption Regular Member • Posts: 165
I was looking at the godox light72 (if I remember the name correctly). Thought it might give me a stop or two to play with. I appreciate folk saying flash is easier, but I'm an absolute beginner in that regard.
Antique Eruption
With the best will in the world, not the answer I wanted to hear 😂. But you've been there and I need to accept that. Thank you.
Joseph S Wisniewski Forum Pro • Posts: 35,461
Softness is from shutter speed is from lack of energy
Yep.
I haven't seen very many commercial LED ringlights that can put out enough power to get up into the shutter speed range needed for the sharpest macro shots.
Remember, pictures are taken by energy (in watt-seconds). That's power x duration. If your small ringlight puts out 2 watts (common in ringlights that run of AA batteries) and you shoot at 1/250 sec, you've got a whole 0.008 watt-seconds of energy. A single "speed light" style flash typically can pop 80 watt-seconds into a full power flash, and that's with a duration of about 1/800 second. So, nearly 4x the blur-killing speed, and 10,000 times more energy to let you use smaller apertures and lower ISOs.
Even if you used a very slow, blurry 1/10 second with the ringlight, that's only 0.2 watt-seconds. The flash would still give you 400 times more energy.
Seriously, the "learning curve" to learn how to use a real flash and get sharp, well lit, controlled results is a lot shorter than the learning curve to pile hack after hack trying to get sharp shots from insufficient light.
Now, there are devices called "hybrid" LED ringlights that can light the LEDs steadily with 1-2 watts, but can also store a few watt-seconds of energy in a capacitor and dump that into the LED ring in a short pulse to get a higher energy dose for your exposure. Some do around 4 watt-seconds, which is still substantial at macro distances.
But you still need to learn flash if you want to use a hybrid flash.
Not with your lens. For IBIS to work properly, it needs to know the amount the sensor needs to shift with a given shift of lens angle or position. In order to make that happen, the camera needs exact information on focus distance and lens rear node to sensor distance. Modern autofocus macro lenses provide that information to your camera, but your old Vivitar can't.
If you want actual help from a stabilization system, you really need to look at the Fuji 60mm f/2.4 or 80mm f/2.8.
Why not? It's an optimal solution to your problem, and it won't scare the bugs before you're ready to shoot. Like I said: you've got to learn something, either flash or "heroic" levels of camera holding and LED lighting.
The term "mirrorless" is totally obsolete. It's time we call out EVIL for what it is. (Or, if you can't handle "Electronic Viewfinder Interchangeable Lens" then Frenchify it and call it "LIVE" for "Lens Interchangeable, Viewfinder Electronic" or "Viseur électronique").
Stanley Joseph Wisniewski 1932-2019.
Dad, so much of you is in me.
Christine Fleischer 1947-2014.
My soulmate. There are no other words.
Rahon Klavanian 1912-2008.
Armenian genocide survivor, amazing cook, scrabble master, and loving grandmother. You will be missed.
Ciao! Joseph
www.swissarmyfork.com
 Joseph S Wisniewski's gear list:Joseph S Wisniewski's gear list
Nikon D90 Nikon D2X Nikon D3 Nikon D100 Nikon Z7 +48 more
So what if you're a beginner?
So what? Say it takes 10 hours to go from zero to results acceptable with flash, but it takes 50 hours to go from where you are now with continuous light to getting acceptable results from an LED ring light.
Which is the more efficient path?
Ciao! Joseph
Antique Eruption
Re: Softness is from shutter speed is from lack of energy
Yep.
Thank you Joseph. The truth hurts. I'll have a good think on this.
Antique Eruption
Re: So what if you're a beginner?
Aye, I'm hearing you.
Watch this, twenty mins is better than spending any money or making any decisions
https://youtu.be/YTl9-VWe1xg
Jim
Better the hurt now than...
Yep.
You're welcome, AE.
Look at it this way: it's better to experience the hurt now than after you've purchased equipment, put in hours, and gotten frustrated. This way, the only thing hurting is your preconceptions.
Ciao! Joseph
Look - and sorry - I dont know the Fujifilm system at all but basic TTL flash is just so easy with most systems that I suggest you look see what is available.
You can experiment later with manual control of the flash but TTL does give you a good starting point,
The most important thing is getting good diffusion of the flash output,  You can get cheap strap on diffusers for most heads.
I think LED arrays do work as panels  off camera but you are talking about having to setup a lighting system rather than just an on camera solution,
If you have good diffusion then an on-camera flash with TTL can work well.
richard
number_5
number_5 Contributing Member • Posts: 579
+1 on the flash. I spent quite a bit of research before I made any purchases, and a budget manual flash and a diffuser did the trick.
Antique Eruption
I'll do that, thanks. One thing I've never grasped with flash is the relatively low shutter speeds. If I'm extended to 1:1, I thought I'd have to increase shutter speed to counteract blur from my own movement. 1/160 sounds slow, particularly for moving crittters (or even static but moving limbs, etc.).
Flash speed, not shutter speed
If you're at a low ISO and an aperture of say f/8 or f/11 there's not much exposure from the 1/160 sec of ambient light. The flash duration is much faster, like 1/2,000 sec at 1/4 power. Flashes freeze motion: they're an essential part of high speed photography.
Ciao! Joseph
Re: Flash speed, not shutter speed
+ 1 of flash "freezing" movement (and shake), i just wish i'd bought a flash gun years and years ago
I was trying to get something small / second hand but they sent me a m43 instead of a canon one, i eventually bought a small godox 350
Jim
kli
kli Veteran Member • Posts: 4,587
One thing I've never grasped with flash is the relatively low shutter speeds. ...
Whenever you take an image with flash, you're combining two different exposures from two different sources of illumination: the ambient (all the existing light already in the scene) and the flash.
Ambient exposure is controlled by iso, aperture, and shutter speed (this you know).
But flash exposure is controlled by iso, aperture, power, and subject-to-flash distance.
If you are at or below sync speed, then shutter speed does not affect the flash exposure because the flash burst duration is much much shorter than your shutter speed (typically ranging from 1/1000s (full power) to 1/40,000 (1/128 power) on a full-sized speedlight.
And because you have these differences in control between your two light sources, you can balance the ambient against the flash however you want.
If you adjust your exposure so that flash is the primary source of illumination but there's still some ambient exposure, you can get images where the subject is "frozen" by the flash, while showing motion trails (slow sync flash). And when the flash fires (at the beginning or end of the exposure) changes the direction of the motion trails.
But if you can overpower the ambient light with your flash to the point of "killing" the ambient (i.e., all the exposure is only from the flash and none of it from the exposure; typically by underexposing the ambient around -5EV to -6EV so you get a black frame if the flash doesn't fire) then you can freeze motion with just the flash, which, remember can go from 1/1000s-1/40,000s (which is why flash is used for high-speed photography, for things like bullets going through apples :-). And with the light at macro distances, killing the ambient is more easily doable.
But this is also the main reason strobes are preferred over LEDs for this: you need a lot more light output to be at +5EV (32x) over the ambient.  Petapixel did a side-by-side of Godox's LED video lights and their strobes, at max. power and found that one of the full-sized speedlights metered at +1EV, while the LR150  bi-color 150 LED ringlight was at -5.3EV.  So just getting, say, a $65 TT600 is going to offer you something like +6EV (64x) more power/light to play with for this type of thing.  Even a  $200 1000 LED panel still only comes in at -2EV.  And a speedlight? Is the smallest and lowest powered strobe you can get.
LEDs are great if you'res shooting video and need continuous light, or you're doing tabletop product photography in a studio and need to see tiny angular adjustments as you're working and don't need much power to freeze motion or fill flash against sunlight.   But strobes will always give you a lot more light for your money.
 kli's gear list:kli's gear list
Fujifilm X100T Canon EOS 5D Mark II Canon EOS 50D Panasonic Lumix DMC-GX7 Canon EF 135mm F2L USM +12 more
kli
Flashes freeze motion...
...if you kill the ambient. Slow sync flash with motion trails can still happen if there's any ambient in the exposure.
Antique Eruption
I think I'm getting this a bit more now. Thank you.
kli
... I think I'm getting this a bit more now. Thank you.
You're welcome! I highly recommend the following two websites for wrapping your head around flash:
Yes, it's more complex than simple ambient-only exposure. But it's not rocket science or brain surgery, either. And learning flash can open up whole new worlds. IMHO, flash ismore transformative to your photography than getting a new lens.
