Birds at the local canal and nature reserve
Antique Eruption
Antique Eruption Regular Member • Posts: 167
35
Taken on my X-T3 with XF100-400mm. I left the teleconverter off due to poor light. Even then, with high ISO, I had to rely on some pretty slow shutter speeds. I was photographing the birds in, or under cover of, foliage. Testing times! Autofocus handled it all pretty well though. Ended up running the images through Topaz DeNoise. It's a necessity this time of year in the UK. Worth mentioning that the choice of wide apertures and close-ish proximity has of course led to OOF areas on the birds. I like the effect, but it probably isn't for everyone.
Robin
Blue Tit
Great Tit
Robin again
And again
And again again!
Fujifilm X-T3
Alan Hewitt Photo
Alan Hewitt Photo Contributing Member • Posts: 907
Re: Birds at the local canal and nature reserve
Great work! It's also a good example of  how good the XF100-400mm can be!
I often hear this and like you, I'm of the opinion that as long as the head, beak and eye are sharp - this is usually where we look at a bird photograph and it's composed well - then I'm not usually bothered about wings, legs trailing out of the depth of field. It's a very fine line between closing the aperture down to get front to back subject depth of field to also making foreground and background distractions more problematic.
Freelance wildlife photographer, filmmaker, photography safari & workshop guide, writer. Fujifilm UK Ex-X-Photographer!
INSTA1: alanhewittphoto
INSTA2: bts_alanhewittphoto
 Alan Hewitt Photo's gear list:Alan Hewitt Photo's gear list
Fujifilm X-T2 Fujifilm X-H1 Fujifilm X-H2S Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 50-140mm F2.8 +2 more
Antique Eruption
OP Antique Eruption Regular Member • Posts: 167
Thanks Alan - I agree about that balance between sharp focus in the right places and potentially distracting backgrounds. I have a few tricks up my sleeve to remove some distraction in LR (inverted subject masks, negative texture and sharpness, etc.), and Topaz also helps massively. The trick then is trying to avoid over smoothing. Keeps me honest, trying to walk that particular line!
Morris0
Morris0 Forum Pro • Posts: 32,175
Excellent set
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
Antique Eruption
Morris0 wrote:
Excellent set
Morris
Thank you Morris.
Giantcappuccino
Giantcappuccino Regular Member • Posts: 205
Excellent set!
I especially like the 4th one - a robin in deep thought.
I always like bird pictures when they seem to be pondering something.
Cheers!
Jason
 Giantcappuccino's gear list:Giantcappuccino's gear list
Fujifilm X-T20 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Fujifilm XF 23mm F2 R WR
Elchanan Contributing Member • Posts: 777
Fabulous! Thanks for sharing.
jim mij Senior Member • Posts: 1,060
Nice set, noise reduction seems to work and shows details too. I like #4 the best
Jim
 jim mij's gear list:jim mij's gear list
Canon EOS M6 II Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF-S 60mm f/2.8 Macro USM Kenko Teleplus Pro 300 AF 1.4x Canon EF-M 22mm f/2 STM
Antique Eruption
Giantcappuccino wrote:
Excellent set!
Cheers!
Jason
Thank you, my wife very much likes that one too.
Antique Eruption
Thank you.
Antique Eruption
Thank you, I think I'm beginning to get a feel for the noise reduction.
Lukus
Lukus Regular Member • Posts: 200
Nice birdies and well done on the subtle use of AI noise reduction. So, so much better than smudging all life out of an image and turning it more into a CGI render than a photograph.
 Lukus's gear list:Lukus's gear list
Fujifilm X-T2 Fujifilm X-H1 Fujifilm X-H2S Fujifilm XF 56mm F1.2 R Fujifilm XF 50-140mm F2.8 +4 more
ddtan Senior Member • Posts: 1,055
Thanks for reminding me not to be afraid of a slow shutter speed 1/125 with my 100-400.
 ddtan's gear list:ddtan's gear list
Fujifilm X-T30 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +4 more
Antique Eruption
Thanks - I've had to walk a tightrope but I think I'm there or thereabouts. Happy to go out taking pics in the kind of weather I wouldn't have before.
Antique Eruption
With perching birds it's doable. Get a fair few bin jobs but enough survivors! Good luck with it.
theironmadchen
theironmadchen Contributing Member • Posts: 807
Love these shots - really great work dealing with the lack of light. And that robin (same one for all shots?) seemed to be quite curious in what you were doing
Cathy
 theironmadchen's gear list:theironmadchen's gear list
Fujifilm X100V Fujifilm X-T1 Fujifilm X-H2S Fujifilm XF 35mm F1.4 R Fujifilm XF 50-140mm F2.8 +2 more
ChrisGibbons001
ChrisGibbons001 Regular Member • Posts: 234
Brilliant set
@bychrisgibbons
@chrisgibbonswildlife
 ChrisGibbons001's gear list:ChrisGibbons001's gear list
Fujifilm X-T5 Fujifilm XF 23mm F2 R WR XF 150-600mm
tri x
tri x Contributing Member • Posts: 756
Fab set and great presentation via your editing, so well done.
Cheers John
 tri x's gear list:tri x's gear list
Fujifilm X100V Sony a7R III OM-1 Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Sony FE 90mm F2.8 macro +3 more
allenns
allenns Contributing Member • Posts: 775
Very nice and am sure satisfying with such clarity. Superb lens as well and good value todays' prices. Worth blocking them together on an A4 print and framing it.
 allenns's gear list:allenns's gear list
Panasonic Lumix DC-GF10 (GF90) Sony a7 IV Fujifilm X-T5 Sony FE 28-70mm F3.5-5.6 OSS Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS +6 more
Antique Eruption
Cathy
Thank you. It was probably after seeds! I think it was the same one throughout. Very inquisitive.
