2x magnification
Started 1 month ago | Discussions
Jason Yao New Member • Posts: 9
2x magnification
I currently own a Nikon D7500 and a nikon 105mm f2.8 micro VR that is 1x magnification and I want to go a step further to 2x magnification with the same image quality but just increased magnification. Preferably just add on to the front of the lens.
Thought of extensions tubes but will lose a lot of light.
Thought of close up lens filters but will lose image quality.
Don't want to get a laowa because I would find it irritating to keep switching lenses. Sooner or later will just use 1 and stick to it and forget about the other.
Any suggestions will be helpful because this has been my own issue for the past 4 months
Nikon D7500
jarlrmai Regular Member • Posts: 110
Re: 2x magnification
No matter how you get there you lose light when you increase magnification. Due to the bellows effect.
Dedicated 2x optics tend to correct better at 2x but you still lose the light
Richard Dutton Contributing Member • Posts: 572
Yes you are going †o lose light whatever.
You should be able to get good image quality certainly in centre frame with a good achromat. The Nisi 58mm is easily available and is 5 dioptres. Use a step down ring 62 to 58. You should get near to 2:1 with that according to the calculators but in my experience they overestimate and probably 1.7:1 is nearer to what you will get.
The Raynox DCR-150 ( 4.8 dioptres ) and DCR-250 ( 8 dioptres ) have excellent image quality. They are three element designs I think. Lose yet more light.
Some other views using TC's instead here
Lots of other threads about getting higher mags from the 105 on this and other forums e.g. this thread
Joseph S Wisniewski Forum Pro • Posts: 35,461
No optimal solution...
There's no "add on to the front of the lens" that will let you keep your lens's VR or it's superb optical quality. You need about 7 diopters of "closeup lens" to get the 105mm down to 2:1, and that means the closeup lens would be almost as strong a lens as the 105mm f/2.8 itself, and it would account for about half the optical quality. It would have to be almost as complex as the 105/2.5 itself to get the same image quality. 2 or 3 element "achromat" closeup lenses are not going to make the trip.
Not "a lot", but often enough to be annoying. You'll also lose your VR.
Yep.
Why would you have to keep switching lenses? The Laowa 100mm f/2.8 focuses all the way from infinity to 2x magnification. If you don't mind the loss of VR and AF, you can use it as an alternative to the Nikon.
Yep.
The term "mirrorless" is totally obsolete. It's time we call out EVIL for what it is. (Or, if you can't handle "Electronic Viewfinder Interchangeable Lens" then Frenchify it and call it "LIVE" for "Lens Interchangeable, Viewfinder Electronic" or "Viseur électronique").
Stanley Joseph Wisniewski 1932-2019.
Dad, so much of you is in me.
Christine Fleischer 1947-2014.
My soulmate. There are no other words.
Rahon Klavanian 1912-2008.
Armenian genocide survivor, amazing cook, scrabble master, and loving grandmother. You will be missed.
Ciao! Joseph
www.swissarmyfork.com
 Joseph S Wisniewski's gear list:Joseph S Wisniewski's gear list
Nikon D90 Nikon D2X Nikon D3 Nikon D100 Nikon Z7 +48 more
You can always get more light. What you can't get is...
You can always get more light. What you can't get easily is more image quality and more working distance.
You need somewhere in the near vicinity of 7 diopters to get a 105mm Nikon to go to 2:1. The reason you don't need 10 diopters is that the lens shortens its focal length as it focuses closer. At infinity, it's a 105mm lens with its rear node 105 mm from the sensor, but at 1:1 it's more like a 70mm lens with its rear node 140mm from the sensor (magnification = (140mm/70mm) - 1 = 1).
You're stuck with the 140mm, that's internal to the lens, so to get 2:1 you have to shrink the 70mm to  46.7mm (140mm / (2 + 1) = 46.6mm). That's 1000/46.7 = 21.4 diopters. The 105mm which has shrunk to 70mm is about 14.3 doppters, leaving you 7.,1 diopters short of a full load.
The problem is that, when two lenses go walking, the stronger one does the talking. In other words, the one with the most diopters dominates the image quality.
But in this case, neither lens really dominates the balance. The 105 at 14.3 diopters isn't really that much stronger than the Raynox at 8 diopters. So your image quality is about half one, half the other. And "the other" is a simple 3 element/2 group achromat with a little bit of field flattening. It's nothing like the optical quality of the 105mm f/2.8 VR with 14 elements in 12 groups correcting field flatness, barrel, pincushion, spherical aberration, lateral and longitudinal chromatic aberration, comma, etc.
You're also dropping the working distance of 140mm from the front node (about 100mm from the front element) down to about 70mm from the front node, or around 45mm from the front of the Raynox.
So you've really killed both the image quality and the working distance with a closeup "filter".
The optimal solution is a lower-power closeup lens (less destructive of image quality) and a short extension tube. Just working the numbers in my head, a 24mm tube and a 3.3 diopter closeup filter will hit 2x with a lot less loss of image quality or working distance.
Ciao! Joseph
Re: You can always get more light. What you can't get is...
Thanks Joseph for a very illuminating discussion of the issues.  On my own account I will go away and do some research.
Very very useful.
I have used that combination of short tube and an achromat myself but happened on that  by accident not by design.  I do use achromats but typically a 3 dipotres like the Nikon 6T on longer telephotos e.g. 70-300 or 300 just to get a bit closer in and not to 1:1.  That said, I was about to play around with my Tamron SP90 to just get a bit more magnification than 1:1 so I will play around with the sort of combination you mentioned.
cheers
Richard
macrouser
macrouser Senior Member • Posts: 3,979
I use that filter on my Sony FE 90 mm lens nearly every day.  The image quality is excellent and I get a bout 1.8:1 magnification.  With the 105 lens you should get very close to 2:1 magnification.
 macrouser's gear list:macrouser's gear list
Sony SLT-A77 Sony a7R III Sigma 150mm F2.8 EX DG Macro HSM Sony FE 90mm F2.8 macro Sony FE 70-300mm F4.5-5.6 G OSS +2 more
I may have confused things - I don't have the Nisi 58mm 5 dioptre ( yet ).  I was just trying today a Nikon 6T ( 2.9 dioptres ) on my Tamron SP90/ 2.8 0n a FF body.
Quick check:  mag is 1.45:1 and resolution looks fine and certainly good enough for me.  The working distance is about 90 mm at MFD.  Field looks pretty flat. As a bonus - the AF-C does work well once in the focus zone - even on a Z6.
Just wanted a bit more magnification at the moment and this will do since its easy to take on/off.
In any case I do close ups on a D500 or a Nikon 1 in preference to FF and  so I have the additional crop factor "mag" of 1.5 or 2.7 X if needed.
Richard
