EOS RP external flash suggestions
Started 1 month ago | Questions
Michael R A A New Member • Posts: 2
Hi, I recently upgraded to the Eos RP from Eos rebel t2i. I had a very nice external flash "Sigma EF-610 DG" that worked perfectly with the t2i producing excellent results with very little effort. Most of the time I would just use full Auto and the Flash auto adjusts it's output perfectly. Now the flash, although in perfect condition and fully ETTL II compatible, still does not seem to work properly with the RP. No matter what mode I try or setting I chose, it always fires with full power and overexposes the photos.
So first part of my question, I know the flash is outdated and unfortunately discontinued from sigma, it has no option for firmware upgrade, but - is there anything I can try before buying a new flash? Eg. Adaptors, triggers, settings, magic tricks??
Second part, If I have to buy a new flash, I am looking into something cheap and lightweight like the godox tt350c, would it work properly with the full auto mode and auto adjust its power without me interfering? Because I read somewhere that the RP only allows ETTL with full auto shooting for canon ex/el flashes and nothing else - is this true?
Honestly I don't want to adjust anything when it comes to using the flash apart from aiming and bouncing off the lights  and I don't want to spend that much on a canon flash because I am only using the camera occasionally for events and gatherings and I don't know what to do with the old equipment, even shops refused to buy the old rebel saying it's too old
Any suggestions would be appreciated, thanks in advance.
Canon EOS 550D (EOS Rebel T2i / EOS Kiss X4) Canon EOS RP
KENTGA Veteran Member • Posts: 8,727
Re: EOS RP external flash suggestions
I have R5 and other mirrorless bodies and seldom use flash but my old pre- mirrorless flashes work with the new bodies but I don't try to "adjust" them.
Wish you well.
Kent
Here is a link to some of my travels since 2006. Feel free to comment.
https://www.flickr.com/photos/108062364@N04/albums
KENTGA = Kent from Georgia (metro Atlanta)
 KENTGA's gear list:KENTGA's gear list
Canon EOS 7D Canon EOS 6D Canon EOS Rebel SL1 Canon EOS 80D Tamron AF 18-270mm F/3.5-6.3 Di II VC LD Aspherical (IF) MACRO +14 more
drsnoopy Senior Member • Posts: 1,216
I’m guessing you don’t necessarily want the highest spec or the biggest price, so here’s a sensible suggestion - just buy a used EX series flash.  I have an old 430EX, a 430EX iii RT, and a 600EX ii RT.  They all work perfectly on my R5 and RP.  The 430 series are all a good size on the RP.  There is also a 320EX and 270EX, and also a 580 or 600 but I think those two would be rather large on an RP body.
There are 3rd party flashes that probably work, but you can never be sure of compatibility now or in the future.  With a Canon unit it will work on future bodies too (yes even with the new hotshoe).
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
koenkooi Contributing Member • Posts: 920
The Godox V350C worked well with my RP, but I prefer the EL100. It lacks the LCD, but it is a lost faster to reposition.
I do very much like the proprietary batteries in the Godox flashes, they last longer and recharge the flash faster than AA batteries.
 koenkooi's gear list:koenkooi's gear list
Canon EOS 7D Canon EOS M Canon EOS M6 II Canon EOS R5 Canon EF 85mm F1.8 USM +20 more
tkbslc Forum Pro • Posts: 17,522
Canon El-100
Canon EL-100 is the best match for the RP in terms of size and balance. Mine works great on the RP.
If you want to go low cost, Canon 430 EX is a nice option that is really cheap used.
Treidlia Junior Member • Posts: 40
Re: Canon El-100
On my RP I have some problems with overexposure and inconsistent exposure using yongnuo flash which worked really well with previous 60D.
in external speed light menu in camera, switching from evaluative to average metering for Ettl helps.
Gwand Junior Member • Posts: 39
The Canon 430EX III RT is perfect for the RP and can be used as a master should you decide to expand. It is on sale refurbished at Canon’s website for $209.
 Gwand's gear list:Gwand's gear list
Canon EOS R5 Canon EOS R7 Sigma 50mm F1.4 EX DG HSM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM +7 more
OP Michael R A A New Member • Posts: 2
Thank you all for your suggestions, I will look for good offers on the Canon EL100 / godox tt350c and update. Thanks again
SteveinLouisville
SteveinLouisville Senior Member • Posts: 1,586
I have both of these and the EL-100 is shirt pocket size and works fine. The tt350c is slightly larger but much more capable, plus it's cheaper.
 SteveinLouisville's gear list:SteveinLouisville's gear list
Canon EOS RP Canon EOS R7 Canon EF 17-40mm f/4.0L USM Canon EF 40mm f/2.8 STM Canon EF-S 24mm F2.8 STM +9 more
kli
kli Veteran Member • Posts: 4,589
... is there anything I can try before buying a new flash? Eg. Adaptors, triggers, settings, magic tricks??
Not if you want TTL. You could use a single-pin adapter, and maybe use it as manual-only, but it's pretty much a no-go as you suspected.
Should. But I'd recommend learning to shoot flash with the camera in M mode, so you can fully control flash/ambient balance, rather than leaving it up to the camera.
No. There's currently a bug with the R5/R6 bodies that eTTL II fires at full power if you're trying to use TTL+HSS simultaneously. But without HSS, TTL works fine, and in M, HSS works fine. And it's only those two camera bodies.
Whatever you do, avoid the EL-5. That one will only work on an R3/R7/R10/R8, etc. body with the new multi-function hotshoe.
If you don't want to have to do the aiming, you could also look at the 470EX-AI (no it does not take years of experience to learn to choose a bounce direction (eyeroll).
This is just me, but instead of a TT350-C, if you can take the additional weight/bulk (it's sized much like a 580EX II or 600EX II-RT, I'd suggest looking at the $130 TT685 II-C or finding a used TT685C instead of the TT350.
The head swivels 330º on the Mk II, 360º on the Mk I, and it has twice as much light output, both of which make them better bounce-flash units than a TT350 or your Sigma 610 DG.
If you never plan on using a flash off-camera with remote radio control, you could also look at the Nissin i400/i40/i600/i60A. 360º swivel and more power/light output (runs on 4xAA) than a 2xAA-powered unit like the TT350 or the EL-100.
The EL-100 is probably the best fit, weight/features wise, but has no built-in radio remote control if you eventually want to go Strobist (at which point, Godox gear is hella less expensive than Canon RT gear).
Now you now why a lot of folks get an older camera body infrared-converted.
 kli's gear list:kli's gear list
Fujifilm X100T Canon EOS 5D Mark II Canon EOS 50D Panasonic Lumix DMC-GX7 Canon EF 135mm F2L USM +12 more
