spring is coming, today was good and bad
Started 1 month ago | Discussions
jim mij Senior Member • Posts: 1,027
Spring is around the corner, thats obviously the good part, and today i found a ladybird so i dug out the macro lens flash and diffuser and did a shoot, and i got a pic of the ladybird taking off from a orchid, result...
Now for the bad... for some reason when i was culling the pics i managed to delete everything on the sd card, i tried cntrl z and even looked in the recycle bin (empty)
Panic set in. I downloaded a data recovery app and ran that, it pulled 150 images, but the one i was really after was corrupt (so were 10 others). I tried again, same result
I downloaded a second data recovery app and ran that, it also pulled 150 images, but again the one i was after was corrupt
In despair i tried again using a deep scan, this pulled 600 images, you can guess the one of interest was still corrupt
Dejected by now  I decided to see what else was restored, and as it happens a complete second copy of ALL of todays images, what joy
It wasnt till i tried to zoom in that i saw these were actually just thumbnails, with a much much reduced  file size, and no chance of post processing
Still it enough for a memory of what got away, and a very important lesson for implementing a better workflow
And another good thing, I saved a bee by giving it a drink, no photos though
roll on spring
Jim
 jim mij's gear list:jim mij's gear list
Canon EOS M6 II Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF-S 60mm f/2.8 Macro USM Kenko Teleplus Pro 300 AF 1.4x Canon EF-M 22mm f/2 STM
macrouser
macrouser Senior Member • Posts: 3,979
Re: spring is coming, today was good and bad
The unfolding of the wings happens very quickly.  Congratulations on getting that.
 macrouser's gear list:macrouser's gear list
Sony SLT-A77 Sony a7R III Sigma 150mm F2.8 EX DG Macro HSM Sony FE 90mm F2.8 macro Sony FE 70-300mm F4.5-5.6 G OSS +2 more
OP jim mij Senior Member • Posts: 1,027
Thanks, I’d like to say it was experience expertise and patience but we both know it was just luck with unusable shots either side of the launch, but I’ll keep trying…
Jim
