Hood for Canon M32/1.4 lens
Started 1 month ago | Discussions
AbuMahendra Regular Member • Posts: 106
Can anyone recommend an affordable, third-party hood for the M32/1.4 lens? Also, what other M lens hood, if any, fits also the M32/1.4 lens?
Brian Slater Regular Member • Posts: 432
Re: Hood for Canon M32/1.4 lens
I use the JJC hood. No complaints.
 Brian Slater's gear list:Brian Slater's gear list
Canon EOS 6D Canon EOS M6 Canon EF 17-40mm f/4.0L USM Canon EF 70-200mm F4L USM Canon EF-S 60mm f/2.8 Macro USM +4 more
GregoryA
GregoryA Contributing Member • Posts: 602
I agree with the  jjc hood  advice.  This is mo go to for many  of  my  lenses.
 GregoryA's gear list:GregoryA's gear list
Canon G3 X Canon G7 X II Canon EOS 6D Canon EOS 7D Mark II Canon EOS 5DS R +28 more
Larry Rexley Senior Member • Posts: 1,238
I also use the JJC hood:
https://www.amazon.com/gp/product/B07MVZSZNP/
I also use a 43mm -> 55mm step up ring and a 55mm lens cap on the lens, and the hood fits right over those no problem.  Helps keep stray fingers off the glass, and the lens can use the same 55mm filters and lens caps as the EF-M 18-150mm and 11-22mm lenses.
 Larry Rexley's gear list:Larry Rexley's gear list
Canon EOS M6 II Canon EOS M200 Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM +21 more
OP AbuMahendra Regular Member • Posts: 106
Omg, that JCC job is bigger than the hood for my 70-200/2.8 monster! 😂😭
It’s virtually identical with the recommended Canon ES-60 hood, which is three times the price. It is a largish hood but is very effective, well-made, and reverses snugly over the lens. Reversed on the 32, my M6ii still easily fits in a small Lowepro Adventura SH-100ii bag.
JRET
JRET Contributing Member • Posts: 840
The 18-150 hood is an alternative.  Tight fit but works.
GENESIS 1:3
 JRET's gear list:JRET's gear list
Canon EOS M6 II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 18-150mm F3.5-6.3 IS STM Canon EF-M 32mm F1.4 +7 more
lumenite Senior Member • Posts: 1,207
EW-60F from China works as well.
 lumenite's gear list:lumenite's gear list
Canon EOS-1D Canon EOS M Canon EOS M5 Canon EF 28mm f/1.8 USM Canon EF 50mm F1.4 USM +7 more
I don't reverse. It's just not in my nature. Philosophically I affix the hood and leave it. The camera and/or lens go in the bag with the hood as is.
That's what I'm talking about!
Maxmolly7
Maxmolly7 Senior Member • Posts: 1,480
Yes, I can confirm this. The original hood is to bulky to store in my bag. I also prefer my hoods attached as ready to use.
May THE LIGHT be with you!
 Maxmolly7's gear list:Maxmolly7's gear list
Sony RX10 IV Sony RX100 VII Canon EOS M6 II Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM +16 more
I just ordered this job for $3.30.
KEG
KEG Veteran Member • Posts: 4,909
Out of curiosity I tried this on my 32 mm, didn't fit.
KEG
 KEG's gear list:KEG's gear list
Canon EOS M6 Canon EOS R Canon EOS M6 II Canon EF-M 32mm F1.4 Canon RF 50mm F1.8 STM +21 more
JRET
I have the same one pictured and when I first tried it I thought it wasn't going to fit either -- but, after getting it properly aligned, push firmly and it will go on.  It's definitely a tight fit.  Search the M Talk forums for a thread describing the tightness, yet working.
GENESIS 1:3
KEG
Ok, interesting
KEG
KEG
Required a bit of a push but fits.
KEG
JRET
Get a cheap one for the 32 & avoid mixing hoods between lenses.  I’m guessing that the “tight” hood will eventually stretch to better fit the 32 and be too loose for the “correct” lens.
GENESIS 1:3
JRET
I think i might have gone super cheap on the 32 hood & ordered one from eBay (Asia) for less than $2,  Took over 2 months to arrive.
GENESIS 1:3
I get that. In my case, I often want a minimal bag. I’ve become accustomed to reversing all my hoods from the 11-22 right up to long teles, and bayoneting them in quickly when shooting. Space inside a fitted hood is wasted during storage.
Marco Nero
Marco Nero Veteran Member • Posts: 7,582
EF-M 32mm f/1.4 lens + Canon EW-60F lens hood.
When the EF-M 32mm f/1.4 STM lens was released the matching lens hood (which is a barrel-type) was not shipped for quite some time. So wanting to protect my lens from damage, I bought an EW-60F lens hood which is made for the 18-150mm lens. It fits perfectly although the first time I fitted it I had to push it forward onto the lens' bayonette style fitting attachment on the front of the lens. It's robust, doesn't scratch easily, doesn't show scratches if it is scratched and was quite affordable when I bought mine. I like the look of the petal-style hoods more than the barrel or drum types and accessing a C-PL filter ring is easier.
I Regret that the angle of these images (below) makes the hood look much larger than it is on the lens. I have the camera/lens with hood on it sitting in front of me right now and the EW-60F lens hood looks smaller and shorter than it does in these photographs.
I've recommended this hood to other members of this forum in threads almost identical to this one and at least two other members here claim to use the same hood and like it. I think it's just the right size, it looks like it belongs on the lens and it's extremely robust. It rotates and then clicks into place - although I remember the first time I attached this hood to the lens that it required a little more pressure than expected. Even today, years later, the hood looks surprisingly new and the fitting is firm but loose enough to easily remove.
M6 + EF-M 32mm f/1.4 STM lens + Canon EW-60F lens hood.
Marco Nero.
 Marco Nero's gear list:Marco Nero's gear list
Canon EOS M6 Canon EOS Ra Canon EOS R6 Canon EF-M 32mm F1.4 Canon RF 85mm F1.2L USM +20 more
