M6ii
Started 1 month ago | Questions
ericka287 Regular Member • Posts: 102
M6ii
My  M6ii is on eco mode sitting idle with EX 430 flash attached on tripod waiting for birds to come; every few minutes the camera turns on and off again without me touching the camera . Is this normal or is this behavior extra ordinary? Thanks for your input.
 ericka287's gear list:ericka287's gear list
Canon PowerShot G12 Canon PowerShot G1 X Canon EOS M3 Canon EOS M6 II Canon EF-S 60mm f/2.8 Macro USM +8 more
R2D2 Forum Pro • Posts: 26,528
Re: M6ii
Does it do the same thing without the flash?
R2
jim mij Senior Member • Posts: 1,035
Re: M6ii
The last time I tried that I had to keep the camera active (and or its wifi link to my phone) by pressing something (eg focus) every couple of minutes. the battery seemed to last a couple of hours which was longer than my patience
If i lost wifi i had to go out into the garden to get things going again
Jim
 jim mij's gear list:jim mij's gear list
Canon EOS M6 II Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF-S 60mm f/2.8 Macro USM Kenko Teleplus Pro 300 AF 1.4x Canon EF-M 22mm f/2 STM
OP ericka287 Regular Member • Posts: 102
Re: M6ii
I forgot to tell you that my M6ii was connected to Anker power bank. I tried this also without 430EX ii and the camera still cycles on and off in ECO mode; WiFi & blue tooth was disabled.......But  when I use the EPE17 battery the camera is OK in ECO mode; all is fine. This seems to be coused by the Power Bank. Thanks for your input.
Re: M6ii
Thanks.  Interesting!  You’re talking about using the “fake battery” style power supply (with adapter), right?  Is it the USB style?  Can you try plugging it into a wall outlet with a USB power block as a supply?
I wonder if it’s a function of the camera or the power bank/supply.  I’m still out of town right now, but I should try it with mine when I get home.  It can be powered from any 5v USB source (“fake battery” style).
See if you can do any more experiments.  I take it you want the camera to be in “standby” so that you can wake it and take pictures when opportunity arises?
R2
Shooters on My Squad Regular Member • Posts: 379
Re: M6ii
I use the M6II as a webcam connected to a charger with a fake battery. The only thing that gets in the way is the screen automatically turning off after a certain time, and I think you cannot completely disable it (from what I remember half an hour is the maximum setting where I would then need to half-press on the shutter again to see something on the display).
But I haven’t seen it go on & off again while using it in such a setup. Did you get genuine Canon accessories? Does the power bank deliver enough juice all the time?
 Shooters on My Squad's gear list:Shooters on My Squad's gear list
Canon PowerShot G5 Ricoh GR III Olympus TG-6 Canon G5 X II Ricoh GR IIIx +41 more
Re: M6ii
I was useing the Anker power bank with the LPE 17 battery adapter & voltage adapter from 5 v to 8.4v     I'm not sure if the Anker power bank charges via the USB input; I don't use this methood because the camera must be off to charge the battery defeating the purpose of having the camera always on in stand by mode.
