Firmware option gone from menu?
Started 1 month ago | Questions
Tess651 New Member • Posts: 4
HI
I've just got a Canon M camera and all was fine until I cleared all settings after downgrading from 2.0.3 to 2.0.2 so I could add magic lantern . Now the Firmware update selection isn't showing in the menu in any mode, including A, camera or video? Any ideas?
JustUs7 Senior Member • Posts: 4,327
Re: Firmware option gone from menu?
Menu options disappear in full auto.  Are you in green auto or M mode?
 JustUs7's gear list:JustUs7's gear list
Canon EOS 1000D Canon EOS Rebel SL1 Canon EOS RP Canon EOS M6 II Canon EF 75-300mm f/4.0-5.6 III +10 more
OP Tess651 New Member • Posts: 4
Tried in all 3 modes and the firmware option has simply gone.
Advi
Advi Regular Member • Posts: 456
Have you tried P A S M?
Program
Aperture
S (shutter speed or Tv time value)
Manual
Bye
 Advi's gear list:Advi's gear list
Canon EOS M50 Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 15-45mm F3.5-6.3 IS STM Canon EF-M 18-150mm F3.5-6.3 IS STM
Program
Aperture
Manual
Tes I've tried in all of the modes
nnowak Veteran Member • Posts: 9,075
I just tested this on my M running 2.0.2.  Top dial is set to the middle position (not green mode and not video).  I cleared all regular and custom settings.  After clearing settings, the camera reverted to CA (creative auto) mode.  Tapped the touchscreen to switch to M (manual) mode.
Below is what I am seeing on my camera after this process
Are you seeing the same number of tabs across the top?
Thanks so much, that worked. You are a star!
pat1978 New Member • Posts: 1
Tess651 wrote:
HI
Have you figured out the problem? I am having the same problem!
OnTheTrail Regular Member • Posts: 105
pat1978 wrote:
Tess651 wrote:
HI
It shows up for me in P mode, under the wrench icon, screen 5 at the bottom. I’m running V 1.0.4
 OnTheTrail's gear list:OnTheTrail's gear list
Olympus XZ-1 Sony RX100 III Canon EOS 60D Canon EOS Rebel SL1 Canon EOS M6 II +19 more
pat1978 wrote:
Tess651 wrote:
HI
Yes, see my post above
https://www.dpreview.com/forums/post/66872964
