Seeking Advice on Using Fully Articulating Screen for Street Photography
sshapiro Senior Member • Posts: 1,018
A few months ago, I purchased an X-H2S to use for sports, action, wildlife, and event photography. I also have an X100V that I primarily use for street photography and an X-T3 that I use for a bit of everything, including street photography when I want to use Fujifilm F1.4 lenses.
I have become very comfortable with the controls of the X-H2S and tend to use the camera more than my X-T3. The X-H2S works great for almost everything I do, except for street photography; I find the fully articulating screen, when extended, is difficult to work except when the camera is held vertically. Here are some of the issues I have when the screen is extended to the left side of the camera:
  1. Accessing the screen touch functions is difficult and slow because I am right handed and have an injury to my left hand.
  2. I have problems getting the scene framed properly when I am looking to the left of the lens.
  3. I am concerned that the screen is more likely to break than if it were located behind the camera.
If anyone has advice on how to overcome, or at least mitigate, any of the items I listed I would appreciate the guidance.
Thank you in advance.
Fujifilm X-T3
nurseMarty Regular Member • Posts: 326
Re: Seeking Advice on Using Fully Articulating Screen for Street Photography
You can use any camera for street photography.
I don’t like using a flip screen for street photography. I wouldn’t suggest using the XH2 as a street photography camera. Good news though. You have the X 100 V. That is the perfect camera for street photography. Want to use a lens longer than 23 mm? Use the XT3. They both have the tilty screen. Either of these bodies would serve
Congratulations on the several Fuji bodies that you have. Use anybody that you have for street photography. Have fun.
Mask On Nurse Marty (Ret)
OP sshapiro Senior Member • Posts: 1,018
I would like to consolidate the number of camera bodies I have, and I like the X-H2S for all my other photography, but the answer might be that the flip screen won't work for my street photography when I use the F1.4 lenses.
Morris0
Morris0 Forum Pro • Posts: 32,175
Have you tried flipping the screen around and then back to the body so it's in the same position as a fixed LCD?
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
Morris
Yes, I generally have the screen in that position, but there are circumstances when it's useful to be able to look down at the screen when the camera is close to my chest. The flip screen is a very different experience, for me, than the tilt screens I am used to. But I am hoping that I can get comfortable using the flip screen because I like the X-H2S controls and features.
DarnGoodPhotos Forum Pro • Posts: 11,881
The only way to overcome your articulation screen issues is to keep using it until it feels comfortable.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
Yeah, you probably right about that, but I am old and stubborn.
Morris0
sshapiro wrote:
Morris
Rather than using the touch screen, try using the joystick to chose where you focus.
Morris
Jeff Biscuits Senior Member • Posts: 1,166
Personally, if I’m shooting street and the camera isn’t to my eye, then I’m shooting without looking at the camera at all. It takes a while to become accustomed to framing that way, but once you do, it works, especially if you have a relatively wide lens that will afford some cropping. When shooting like this I’ll either be manually prefocused, or using a relatively large AF area (normally the 5x5, sometimes the 3x3).
But it does take a little practice. If you try it you’ll louse it up at first, guaranteed. Just keep learning from the results and it won’t take long to get more reliable results.
 Jeff Biscuits's gear list:Jeff Biscuits's gear list
Ricoh GR Digital II Ricoh GR Digital IV Fujifilm X20 Fujifilm XF10 Ricoh GR IIIx +14 more
biza43 Forum Pro • Posts: 15,074
My advice is to keep practicing until you find what the best option for you is. If you want to take shots with the camera off your face, you simply have to adjust. With my XT4 I sometimes use the screen, sometimes do not.
If you practice and learn to see the way your lenses see, you don't need the screen when the camera is not up to your face.
www.paulobizarro.com
http://blog.paulobizarro.com/
 biza43's gear list:biza43's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
Yawlen Z
Yawlen Z Regular Member • Posts: 184
Trying on a used FAS camera I noticed rather fast that this wouldn't become a favorite layout any time soon. But if you should care to combine street photography with compositions in square format, the whole issue evaporates really. Or could be a sensible tactic if you need to grow into a love of your H2S. (And even more since it can do 5:4 and 4:3 also?)
Fuji Maine Senior Member • Posts: 1,702
I can't offer any advice with street photography but I wanted to weigh in on the fear of breaking the screen. I had the same concern, especially because I do a lot of wedding work which has several points during a given day where I'm having to move pretty quick from one spot to the next if not run. I'm not exactly being easy about flipping the screen and have lots of times where I'm just leaving it out, bumping it against things and people bumping into me. A couple xt4's later and now the XH2s and I have yet to break a screen and now don't even think about it. It will probably happen one of these days but it has proven stronger than I thought it would be.
Foskito
Foskito Senior Member • Posts: 1,412
The flip screen won't work for your street photography when you use the f1.4 lenses but it works with other lenses?
Another solution might be using the good old EVF.
 Foskito's gear list:Foskito's gear list
Canon EOS 5D Leica M8 Panasonic Lumix DMC-G1 Leica M9-P Canon EOS 6D +14 more
What I was trying to communicate is that I use the X100V as my primary street photography camera but switch to the X-T3 or X-H2S when I need faster primes. The F1.4 primes are useful at night vs. the X100V F2 lens.
Foskito
Tilt-screen is better for street no doubt. Sadly Fuji jump on the videographer/youtuber band wagon and left still-shooters relegated to the XE-XP/X100.
Morris0
I do this as well and use a wide lens so I don't need perfect framing and can crop later.  Shooting at f8 allows for some focus slop and I set the camera up to focus on the nearest subject while f8 helps have a recognizable background.
Morris
Mczar2u Regular Member • Posts: 227
I found that attaching  the left  strap end (using PD anchors) to the base rather than the eyelet makes it easier to flip the screen to the left.-on a X-T4     ....but it may not solve your challenge using left hand
Mario
X-T5 has a tilt screen.
Foskito
You are right.
