Abbazz
Re: Definitive solutions to the NX Mini Problem
sillycornlotty wrote:
While it is fun to own a nx nx-m adapter, from a collector's point of view. I have found using adapter on this camera might entirely defeat the purpose of being nx mini.
The NX Mini with an NX adaptor and the NX 30mm f/2.0 lens remains very compact. The 30mm offers the same angle of view as a 81mm lens on a 24x36 camera: it's an ideal portrait lens,with a fast 2.0 aperture and a perfectly usable autofocus...
The NX 45mm f/1.8 becomes a great fast telephoto (120mm eqv.). The 60mm Macro looks a little goofy on the small camera but it is a long focal (160mm eqv.) macro lens with optical stabilization, something very useful for portraits of skittish critters.
You have a very tiny camera body, then an adapter half the weight of the body, and a lens heavier than the two aforementioned. Practically speaking, it no longer feels like a mini anymore as the combo would make it excessive front heavy.
I used to pair my nikon j5 with FT1 adapter plus various dslr lens, but ended up realizing that kind of setup defeat the purpose of being Nikon1 user, so i have sold many dslr lens already and decided to only use N1 native lens to stay light.
The big difference here is that NX lenses are fully functional on the Mini: aperture control, autofocus and optical stabilization, all work as intended.
There are also many limitations to use larger format lens on smaller sensor cameras. As APSc lens were designed to perform the best on APS-C bodies, you could expect image quality to degrade when using them on smaller format bodies.
You can indeed only use the best lenses, as the 1" sensor has a much higher pixel density. For exemple, in y opinion, the 50-200mm is not good enough to be useful on the Mini. But there are a few great lenses designed for the NX that work well on the Mini: 30mm, 45mm, 60mm Macro, 85mm. Even the lowly 20-50mm is quite good.
Cheers!
Abbazz
