BIF: why these shots are so bad ?
Started 1 month ago | Questions
Seb P
Seb P New Member • Posts: 21
Hello all,
here you are a burst of shots (taken with my R10 & RF100-400mm).
According to you, why most are so bad in original size ?! (lack of contrast, bad focus whereas AF zone seems well positioned, no sharpness)
Only the last one seems correct...
Thanks for your advices
 Seb P's gear list:Seb P's gear list
Canon PowerShot S120 Canon EOS R10 Canon RF 100-400mm F5.6-8 IS USM Canon RF 24mm F1.8 Macro IS STM
Distinctly Average Senior Member • Posts: 2,527
Re: BIF: why these shots are so bad ?
17
A lot of this has to do with lighting. Evaluative metering sees the whole scene and is trying to meter accordingly and not for the bird. Black or white birds are notoriously hard and require good lighting to get the best out of the shot. While it was a bright day, that probably made it worse contrast wise. I often shoot swift for instance and overcast or when the sun is low are by far the best conditions. My local spot I position myself with both wind and sun behind me and only shoot black coloured birds when the lighting is right. That means as the sun is dropping or rising. The wind direction means more chance of getting the bird straight on instead of a birds butt. Also in that kind of light the contrast brings out the detail and makes the subject look much sharper.
Just to add, some of this is guesswork based on my experience.  I am looking at your images on my phone but have forgotten my glasses so it is hard for me to see everything as well as I should
Seb P
OP Seb P New Member • Posts: 21
Thanks a lot for your answer and advices.
The light must be the main reason, you're right.
Other think: do you think the light and the bird color could disturb AF accuracy ? I didn't upload all the shots but the blurry shots are very very numerous !
It is hard to say. It could be settings, panning technique or the lighting. It is hard for me to look closely for subject blur as per my above comment. I am sure others on here can help there.
spec68 Contributing Member • Posts: 530
I agree it's a combination of bad light and an all black subject. Going off your data shooting at 1/2000 ISO 500, F8 it must have been quite bright out -- like noon sun. Sure looks like it in your last couple of shots. Try again shooting in softer morning or late afternoon light or on a cloudy day.
Seb P
Thanks Distinctly Average & spec68.
Spec68, ok regarding lack of contrast and sharpness but can this explain the autofocus errors ?
(photos taken at 9:30 a.m.)
Dareshooter Veteran Member • Posts: 5,842
Look at where the focus reticule is in relation to the subject. Much of it falls outside so there's more room for AF error.
drsnoopy Senior Member • Posts: 1,216
To me the lighting looks good but the images are probably underexposed by 1-3 stops due to the bright sky,  This should not be an issue, especially if you use RAW, you can raise the exposure when processing.  If shooting dark birds against a bright sky, dial in +1 stop exposure compensation.
The shutter speed and ISO seem fine to me.  Sometimes it’s a good idea to set your shutter speed and aperture but use auto ISO.
The main issue is the AF box, which has mostly missed the subject - this implies it won’t be accurately in focus.  Were you using tracking? If so, try eye detection, which works well on birds in flight.
Also your subject is quite small in the frame, which doesn’t help with getting sharp results.
With more practice, and getting closer, you’ll soon get better results.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
Karen Casebeer
Karen Casebeer Contributing Member • Posts: 902
I'm guessing that you're a lot further away than 400 mm.  Were you using auto ISO?  I use this lens and body too.  One thing I've learned is to set my ISO manually, starting at 400 and up it incrementally until I get the shutter speed I want for the subject.  This is shooting in Av mode.
 Karen Casebeer's gear list:Karen Casebeer's gear list
Canon EOS M50 II Canon EOS R10 Sigma 30mm F1.4 (E/EF-M mounts) Canon EF-M 18-150mm F3.5-6.3 IS STM Canon RF 100-400mm F5.6-8 IS USM
Seb P
Thanks for your answer.
Yes, i shoot with tracking and eye detection (AF area : full or flexible, i'm not sure) and auto iso (manual speed and aperture).
I don't understand why the AF box is wrong placed. Because during the shot the box seems to follow correctly the subject ... Is it too fast maybe ?
Seb P
Can you post your case settings? Also, have you tried setting your case to auto?
What was the percentage of in focus shots? How much did you have to crop to see that?
Seb P
Yes I shoot in auto ISO. I don't understand why manual ISO could be improve the situation ? You get best results with ISO set manually ?
focal lenght used : 259mm for this shot. But I'm not sure to undestand your remark.
gmcooper Regular Member • Posts: 471
If you try to take a picture of a black cat, you will often get something like this, the more so the further away the cat is. Or a pair of solid black boots. It's hard under the best of circumstances to capture detail in an apparent black object.
 gmcooper's gear list:gmcooper's gear list
Canon EOS 5D Mark II Canon EOS M Canon EOS 5DS R Canon EOS M3 Panasonic Lumix DMC-GX85 +5 more
Seb , in the heat of the moment it’s all too easy to slight shift the camera off the subject and also just pressing on the shutter button could cause the slightest bit of camera movement.
Seb P
During this burst, i thing 6/10 shots are blurry. (even when the subject is coming to me, no very fast lateral movement). The images are not cropped at all.
I use the Case "Auto".
Seb P
yes but i thought that the whole point of automatic subject tracking was that you just had to follow the subject in the viewfinder with the shutter button left pressed during the burst and the camera did the rest ...
Lateral movement is often a lot easier for the camera to track than a bird flying at you.
I think you probably just need practice and better conditions. Black subjects can be a nightmare. We’ve all been there and had the same struggles. Some days you get everything right, other days it doesn’t go so well. In better light with less cropping you will almost certainly have a much higher hit rate. Personally I look at the bad days as an excuse to go out and shoot more. It is a challenge that I relish. Sometimes it is disheartening, but then another day you come home with an image that the moment you take it the smile begins.
Seb P
3 others shots (in the same burst). 2/3 are blurry (#1 & #3). But the subject is toddler.
Seb P
Thanks. I hope it's as you said and that my camera & lens are ok ...
