fp + M42 Chinon 55/1.4
Started 1 month ago | Discussions
dr.noise
dr.noise Veteran Member • Posts: 3,779
10
I tested M42 Chinon 55/1.4 (multicoated one) with fp.
These Chinons often have balsam separation (seems like a common issue with this model) so it partially affects bokeh lights, otherwise images are good.
 dr.noise's gear list:dr.noise's gear list
Sigma DP2s Sony DSC-RX0 Sigma SD10 Olympus OM-D E-M10 II Sigma fp
xpatUSA
xpatUSA Forum Pro • Posts: 23,016
Re: fp + M42 Chinon 55/1.4
Quite a classic bokeh "swirl" here and there ... balsam separation or lens design?
what you got is not what you saw ...
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
dr.noise
OP dr.noise Veteran Member • Posts: 3,779
The swirl is by design. It's the same as any other Tomioka 55/1.4 lens.
You can see balsam separation effect on the bokeh circles here:
https://www.dpreview.com/forums/post/66867250?image=4
Inside each bokeh circle there is small black outline. Its shape is exactly how balsam separation line goes inside the lens. What's interesting, the bigger the bokeh circle, the less effect is observed. When circles are small, the defect is much more noticeable, it becomes more "focused".
xpatUSA
Thanks. Perhaps not unlike the Helios M42 55mm or the original Zeiss design.
Interesting indeed ...
